Batch increment prefix and suffix numbers +1 for each click
(defun c:XDTB_TxtAddPSuffix ( / e Message Title txt)
(setq xd-text-prefix-odcl-data '("YWt6A7YgAABCeUbGBuKTJiMVIjtmADAy7RfFuNgkU/zkpPS/mMo3LaUqOtp03BMyM3RU9K4SSAuT"
"GF1kk5wzUMIWP7pFUYK8ZZGCekG+ZT9vahHCL26Cf/woETq78biJ44NGTbFQGYhKFcg2CEdhsefn"
"CZiywrGNwBnI0uIhP5OWQS1mR4ekfdExMTBxYrkMep6VAB7tIssGqUaIn25wph1iDfZP/22M4e7F"
"g/yNjCrhY7rCqvJ787SLfriaQvR8GJtBUcsSCVUUDzKO4tPhaXWkJNPVK8smk1nolT+lDRKl8TQX"
"IBKY25vmywR8Ze+tr/Svax5FMvpgqgCzkRvAvqgEF9Pk5zhR4uEnOCrBgT/y5CmuKf3v8KCCnZ8V"
"jcZ7a0VdNUzc9OIdQvBZmgBgO7/PIml7UR5Z2C64Y0yYzMI/f1vm2UMlqRrJK2yC2url07fW8Zcl"
"AjHdQJOflc2ICsliO9cr6q/pmoLyiIcvrNnjx3F2ATaGA7wBBx3ERJXm2A562DyRp2mHhpEaC8sN"
"DXiDc4muq6PnlFDhHP2tZrjui1HDqOnJSQRN4rK9zqKbUO/l1CXwzoEQQCBNCGYxtwc3Mur7bliZ"
"w4gLn9et2cT+951qu3cxt41H5nOKJJGu2sA7hhO8EWyYF1VLaN/0MW8gFjI2iuVQtFzrQTiGR5SR"
"Ih2w1IYCLKFQhLGqgNn4bSqPUBSBNUxgJaA8SwQelPGyKszgZWuJBzWmjZOyp3uNUNeyBfpJ7+Ho"
"Q2XHN7IeNvA50xDqmoAwR+GKBsEjpcM2CMhbmxFWQOieGWuh6Z7FaoGWi3UNPSzAKbWRM45wuzn2"
"rTl3MWzA+U5cAcLnZisJFA1dw8u9ziUvHabe+5NPEhLLFSDQwooubdMMJ6sAL3ak7M5fERx8TR/n"
"rjKedYs4WFRt5/ewPL48vzzsv6XZngWFCRZfYvCJwdSbX58e3x/Izg76+tjFkmRyBSHuJ0ThJVLC"
"8+cbbBhTtAtCttfDqqlWH1lNhS3D2cmfY6sM+e1d9C0mHJXN6XFYiBKDCMOAndqhDUTQd5Spj6RV"
"r7wVCS3B8GmBdKH1iVVg3yvwd6E6gwE4po8ECzHNvQWxNroRMSyd8ZuK1k5+oRFx3X0ABfY44rcR"
"tZwQFwBlVRgTcNtGfRXinLIsARl3oTHGPubrkBu8cdEPdEuRiemtpOknwvkL3ZHWAhqyJOz7S/3B"
"qAT3NfBYct1XMIngAIDVeSEGmonnsiQP36S+b1L7heG+mQBvQAkROERNK+gjGKDwcE6tGZwrH1i4"
"iNUPNxjd7rQ01RJHjLSLce0qKKeWRR4PVoSQJenCUDWgBIjtR4XPIdbwfKRRpnAYQWtKG0FpBZAN"
"O82clHCeLD0NlVvfcrY4njVTMvW+MwUzldzCtKPcqxtSQwghjFyyKIyOx4RHAtAnkAhJJadomDBF"
"57RuFO9JGR9WjPiJ7ETTgjKu7skO3nGTaAtUDAoEyVZq9ywI7aT0MuLuDry8d/S9cLUa+WMEafIa"
"UiLijvpcY1k+cGXBrwww9jzvzvXFHVNdU1kmgROac5I7yW0JCd1oCUkl5mgJvdTPtEZMR1MPWgP5"
"RNJigekDGCjwrsANNGKqewznQGrLHsy9OtV6IxqoZLqjaEfVseII3dCAgHvqrJ5c"
(defun c:xd-text-prefix-form#OnInitialize (/)
(if (not (xd::doc:acadischs))
(progn (dcl-Control-SetCaption xd-text-prefix-ok "OK")
(dcl-Control-SetCaption xd-text-prefix-exit "Quit")
(dcl-Control-SetCaption xd-text-prefix-title "Prefix")
(dcl-Control-SetCaption xd-text-postfix-title "Suffix")
(dcl-Control-SetCaption xd-text-prefix-no-title "Start No")
(dcl-Control-SetTitleBarText xd-text-prefix-form
"Add Suffixes To Text"
(if (or (not xd-text-start-no)
(not (xdrx_string_regexps "^[0-9]+$" xd-text-start-no))
(setq xd-text-start-no "1")
(dcl-Control-SetText xd-text-prefix-no xd-text-start-no)
(if (and (= (type xd-text-prefix-value) 'str)
(setq xd-text-prefix-value (xdrx-string-replace xd-text-prefix-value " " ""))
(dcl-Control-SetText xd-text-prefix-text
(if (and (= (type xd-text-postfix-value) 'str)
(setq xd-text-postfix-value (xdrx-string-replace xd-text-postfix-value " " ""))
(dcl-Control-SetText xd-text-postfix-text
(defun _do-ok ()
;(xdrx-begin)
(while (setq e (car
(xdrx-entsel (xdrx-string-multilanguage "\n拾取文本字符串<退出>:"
"\nPick Text String <Exit>:"
'((0 . "*TEXT"))
(if (or (xdrx-object-isa e "AcDbText")
(xdrx-object-isa e "AcDbMText")
(progn (setq txt (xdrx-getpropertyvalue e "textstring"))
(if (/= xd-text-prefix-value "")
(setq txt (strcat xd-text-prefix-value xd-text-start-no txt))
(if (/= xd-text-postfix-value "")
(setq txt (strcat txt xd-text-postfix-value xd-text-start-no))
(if (/= xd-text-start-no "")
(setq xd-text-start-no (itoa (1+ (atoi xd-text-start-no))))
(xdrx-setpropertyvalue e "textstring" txt)
;(xdrx-end)
(defun c:xd-text-prefix-ok#OnClicked (/)
(setq xd-text-prefix-value (dcl-Control-GetText xd-text-prefix-text)
xd-text-postfix-value (dcl-Control-GetText xd-text-postfix-text)
xd-text-start-no (dcl-Control-GetText xd-text-prefix-no)
xd-text-start-no (xdrx-string-replace xd-text-start-no " " "")
(if (and (/= xd-text-start-no "")
(progn (setq Message (xdrx-string-multilanguage "起始序号必须是正整数!"
"The starting sequence number must be a positive integer!"
Title (xdrx-string-multilanguage "XD温馨提示" "XD Warm reminder")
(dcl-MessageBox Message Title 2)
(dcl-Control-SetFocus xd-text-prefix-no)
(if (and (= xd-text-prefix-value "")
(= xd-text-postfix-value "")
(progn (setq Message (xdrx-string-multilanguage "前后缀不能同时为空字符串!"
"The prefix and suffix cannot be empty strings at the same time!"
(if (= xd-text-prefix-value "")
(dcl-Control-SetFocus xd-text-prefix-text)
(dcl-Control-SetFocus xd-text-postfix-text)
(progn (dcl-form-close xd-text-prefix-form) (_do-ok))
(defun c:xd-text-prefix-exit#OnClicked (/)
(dcl_project_import xd-text-prefix-odcl-data)
(dcl-Form-Show xd-text-prefix-form)
