Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Hard Purge Inquiry: UnPurgeable Text Style
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Hard Purge Inquiry: UnPurgeable Text Style (Read 470 times)
chilldaddy
Guest
on:
March 19, 2024, 02:09:23 PM »
Goal:
Find methods to help assemble a new LISP program or find an existing LISP program to perform the following:
Purge an undesired text style that is referenced by an object style or other data not visible and proving
impossible to purge
Please provide:
Links to and/or actual LISP programs that perform this PURGE.
LISP tips and/or instruction on links to methods to create a HARD PURGE (object style in use) LISP program.
Logged
ribarm
Gator
Marko Ribar, architect
WWW
Re: Hard Purge Inquiry: UnPurgeable Text Style
Reply #1 on:
March 19, 2024, 03:23:55 PM »
To purge specific style, you'll have to change all objects residing that specific style to newly created one, or like in code to "Standard" text style... Then use PURGE command - style option - all styles...
Code - Auto/Visual Lisp:
[Select]
defun
c:change_all_txt_to_standard
ss i e ex
prompt
\n
Select text entities..."
if
setq
ss
ssget
"_:L"
list
cons
0
"*TEXT"
repeat
setq
i
sslength
ss
setq
e
ssname
ss
setq
i
1-
i
setq
ex
entget
e
entupd
cdr
assoc
1
entmod
subst
cons
7
"Standard"
assoc
7
ex
ex
if
command
s
command
s
"_.-purge"
"_st"
"_n"
vl-cmdf
"_.-purge"
"_st"
"_n"
princ
The code is untested, but I hope you understand something so you can change it to your needs...
M.R.
Last Edit: March 19, 2024, 03:30:45 PM by ribarm
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
kozmos
Newt
Reply #2 on:
March 20, 2024, 01:31:13 AM »
Purge TextStyle is quite complicated as other than text, attributes, dimstyles, leaderstyles, tablestyles and some mtexts with control characters will use it too. Unless all of the used parties are taken care of, the textstyle may remain unpurgable.
Last Edit: March 20, 2024, 01:39:45 AM by kozmos
Logged
KozMos Inc.
BIGAL
Swamp Rat
40 + years of using Autocad
Reply #3 on:
March 20, 2024, 07:50:22 PM »
Dont forget Civ3D styles they will lock a text style as non purgeable.
Logged
Needs a day job
Reply #4 on:
March 21, 2024, 09:59:49 AM »
There is this recent post too:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/create-auto-visual-lisp-to-combine-text-styles/m-p/12654620#M463597
Logged
ribarm
Gator
WWW
Reply #5 on:
March 21, 2024, 12:42:28 PM »
With Ron's comment and his example I cobbled something that should work, but it needs testings from OP...
[Select]
defun
c:change_all_to_standard_purge_styles
lay laylst ss i e ex
while
setq
lay
tblnext
"LAYER"
not
lay
if
4
logand
4
cdr
assoc
70
lay
setq
laylst
cons
cdr
assoc
2
lay
laylst
foreach
lay laylst
if
command
s
command
s
"_.-layer"
"_u"
lay
vl-cmdf
"_.-layer"
"_u"
lay
if
setq
ss
ssget
"_X"
repeat
setq
i
sslength
ss
setq
e
ssname
ss
setq
i
1-
i
setq
ex
entget
e
if
assoc
7
ex
entupd
cdr
assoc
1
entmod
subst
cons
7
"Standard"
assoc
7
ex
ex
if
command
s
command
s
"_.-purge"
"_st"
"_n"
vl-cmdf
"_.-purge"
"_st"
"_n"
foreach
lay laylst
if
command
s
command
s
"_.-layer"
"_lo"
lay
vl-cmdf
"_.-layer"
"_lo"
lay
princ
M.R.
Logged
Marko Ribar, d.i.a.
M.R. on Youtube
danAllen
Newt
Reply #6 on:
March 21, 2024, 02:10:28 PM »
I use code from this:
https://www.theswamp.org/index.php?topic=14247.msg172118#msg172118
Logged
ribarm
Gator
WWW
Reply #7 on:
March 21, 2024, 04:49:29 PM »
OK, Dan...
[Select]
defun
c:PurgeAllTextObjectsStyles
vl
load
ChangeAllTextObjectsStyle laylst lay
defun
vl
load
nil
or
cad
cond
not
vl-catch-all-error-p
vl
catch
all
apply
function
vlax-get-acad-object
nil
setq
cad
t
vl-load-com
setq
cad
or
doc
setq
doc
vla-get-activedocument
cad
or
alo
setq
alo
vla-get-activelayout
doc
or
spc
setq
spc
vla-get-block
alo
defun
Doc StyName
tempObjType ColCnt RowCnt
vlax-for
Blk
vla-get-Blocks
Doc
if
vla-get-IsXref
Blk
:vlax-false
vlax-for
Obj Blk
setq
tempObjType
vla-get-ObjectName
Obj
cond
vl-position
tempObjType '
"AcDbText"
"AcDbMText"
"AcDbAttributeDefinition"
vla-put-StyleName
Obj StyName
wcmatch
tempObjType
"AcDb*Dimension"
vla-put-TextStyle
Obj StyName
tempObjType
"AcDbBlockReference"
foreach
Att
vlax-invoke
Obj 'GetAttributes
vla-put-StyleName
Att StyName
foreach
Att
vlax-invoke
Obj 'GetConstantAttributes
vla-put-StyleName
Att StyName
tempObjType
"AcDbTable"
setq
ColCnt
0
repeat
vla-get-Columns
Obj
setq
RowCnt
0
repeat
vla-get-Rows
Obj
vlax-invoke
Obj 'SetCellTextStyle RowCnt ColCnt StyName
setq
RowCnt
1+
RowCnt
setq
ColCnt
1+
ColCnt
or
and
cad doc alo spc
vl
load
while
setq
lay
tblnext
"LAYER"
not
lay
if
4
logand
4
cdr
assoc
70
lay
setq
laylst
cons
cdr
assoc
2
lay
laylst
foreach
lay laylst
if
command
s
command
s
"_.-layer"
"_u"
lay
vl-cmdf
"_.-layer"
"_u"
lay
ChangeAllTextObjectsStyle doc
"Standard"
if
command
s
command
s
"_.-purge"
"_st"
"_n"
vl-cmdf
"_.-purge"
"_st"
"_n"
foreach
lay laylst
if
command
s
command
s
"_.-layer"
"_lo"
lay
vl-cmdf
"_.-layer"
"_lo"
lay
princ
M.R.
Last Edit: March 22, 2024, 02:56:44 AM by ribarm
Logged
Marko Ribar, d.i.a.
M.R. on Youtube
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
