Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Setting Civil 3D Pipe Fitting Label Style Error
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Setting Civil 3D Pipe Fitting Label Style Error (Read 1114 times)
sdunn
Newt
on:
March 15, 2024, 11:08:13 PM »
I am getting an "does not fall within the expected range" when trying to change a fitting label style. The new label styleid is of an existing label style. Has anyone run into this issue?
Code - C#:
[Select]
if
lab
GetType
labSource
GetType
if
Oid
ObjectClass
DxfName
"AECC_FITTING_LABEL"
lab
StyleId
labSource
StyleId
Logged
King Gator
C3D user & customizer
Re: Setting Civil 3D Pipe Fitting Label Style Error
Reply #1 on:
March 17, 2024, 12:42:11 AM »
Stacy, I see the same thing and have not found a resolution.
Logged
It's Alive!
Retired
Needs a day job
AKA Daniel
WWW
Reply #2 on:
March 17, 2024, 10:15:41 AM »
Can you use 'is derived from'?
Logged
https://github.com/CEXT-Dan/PyRx
https://pyarx.blogspot.com/
sdunn
Newt
Reply #3 on:
March 19, 2024, 02:41:14 PM »
I am not sure how to use "is derived from" in this case. I am checking that the source label is the same type as the selected label before changing its styleid.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
