Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Determine if Dynamic Block has an Alignment Paramter
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Determine if Dynamic Block has an Alignment Paramter (Read 344 times)
cmwade77
Swamp Rat
on:
February 26, 2024, 06:29:57 PM »
I would like to know if there is a way to determine if a dynamic block contains an Alignment parameter? I tried searching for a parameter with the name Alignment, but unfortunately Alignment parameters can't be named and don't get the hardcoded name Alignment listed. This is what I tried:
Code - C#:
[Select]
private
static
bool
HasAlignmentParameter
BlockReference blockRef
if
blockRef
IsDynamicBlock
foreach
DynamicBlockReferenceProperty prop
in
blockRef
DynamicBlockReferencePropertyCollection
if
prop
PropertyName
Equals
"Alignment"
, StringComparison
OrdinalIgnoreCase
return
true
return
false
Logged
gile
Gator
Marseille, France
WWW
Re: Determine if Dynamic Block has an Alignment Paramter
Reply #1 on:
February 27, 2024, 04:10:14 AM »
As far as I know, the .NET API does not expose this.
You can get it by inspecting the BlockTableRecord DXF data (see the attached (work in progress) extension methods).
Here's a testing command:
Code - C#:
[Select]
CommandMethod
"TEST"
public
static
void
Test
var
doc
Application
DocumentManager
MdiActiveDocument
var
db
doc
Database
var
ed
doc
Editor
var
promptEntityOptions
new
PromptEntityOptions
\n
Select Block: "
promptEntityOptions
SetRejectMessage
\n
Selected object is not a block reference."
promptEntityOptions
AddAllowedClass
typeof
BlockReference
true
var
promptEntityResult
ed
GetEntity
promptEntityOptions
if
promptEntityResult
Status
PromptStatus
OK
return
using
var
tr
db
TransactionManager
StartOpenCloseTransaction
var
br
BlockReference
tr
GetObject
promptEntityResult
ObjectId
, OpenMode
ForRead
var
btr
BlockTableRecord
tr
GetObject
br
DynamicBlockTableRecord
, OpenMode
ForRead
try
if
btr
GetDynamicPropertiesData
tr
Any
tvs
tvs
Any
tv
tv
new
TypedValue
0
"BLOCKALIGNMENTPARAMETER"
ed
WriteMessage
\n
Select block reference has an alignment parameter"
else
ed
WriteMessage
\n
Select block reference has none alignment parameter"
catch
System
Exception
ex
ed
WriteMessage
\n
{ex.Message}"
tr
Commit
Last Edit: February 27, 2024, 05:35:23 AM by gile
Logged
cmwade77
Swamp Rat
Reply #2 on:
February 28, 2024, 12:32:39 PM »
Wow, thank you, no wonder why I couldn't find it in a google search. This seems like such a basic thing, you would expect it to be there.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
