Author Topic: NetTopologySuite Operation is not valid due to the current state of the object  (Read 252 times)
sigster
Hi
I am reading SHP file with NetTopologySuite
Here I get error Operation is not valid due to the current state of the object
>> Dim ms = CType(tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForWrite), BlockTableRecord)
 can anyone help how i can fix this Please
System.Text.Encoding.RegisterProvider(System.Text.CodePagesEncodingProvider.Instance)
            Dim factory As GeometryFactory = New GeometryFactory()
            Dim shapeFileDataReader As ShapefileDataReader = New ShapefileDataReader(slod, factory)
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Layer_name = Trim(Layer_name)
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Try
                    While shapeFileDataReader.Read
                        Dim ptColl As Point3dCollection = New Point3dCollection()
                        Dim plineLst As List(Of Polyline) = New List(Of Polyline)()
                        For i As Integer = 0 To shapeFileDataReader.Geometry.NumGeometries - 1
                            Dim coors As Point2dCollection = New Point2dCollection()
                            For Each coord As Coordinate In shapeFileDataReader.Geometry.GetGeometryN(i).Coordinates
                                Dim pt As Point2d = New Point2d(coord.X, coord.Y)
                                coors.Add(pt)
                            Next
                            If coors.Count > 1 Then
                                Dim pline As Polyline = New Polyline()
                                Dim id As Integer = 0
                                For Each pt As Point2d In coors
                                    pline.AddVertexAt(id, pt, 0, 0, 0)
                                    id = id + 1
                                Next
                                plineLst.Add(pline)
                            End If
                        Next
                        If plineLst.Count > 0 Then
                            For Each pline As Polyline In plineLst
                                ' pline.Layer = Layer_name
                                ms.AppendEntity(pline)
                                tr.AddNewlyCreatedDBObject(pline, True)
                            Next
                            tr.Commit()
                        End If
                    End While
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    ed.WriteMessage(ex.Message)
                Finally
                End Try
            End Using
sigster
tr.Commit() was in the wrong place
   End While
   tr.Commit()
huiz
  • Certified Prof C3D
I would say, right before the End Using. Or include the transaction inside the Try.
