Author Topic: DWG Batch Conversion with Lisp ?  (Read 4931 times)
Re: DWG Batch Conversion with Lisp ?
« Reply #45 on: February 14, 2024, 10:47:12 PM »
but I'm pretty sure you don't need that much code to do what you want (seems to be a saveas would be just fine).
what I need to do is more complex
the Lisp contained in the SCR file is just a piece of the real Lisp
because I made a (partial) copy and paste (and all very quickly)
For this reason you will have found pieces of code that seemed superfluous
I'm sorry but we cannot answer questions without knowing the entire question.
Marc'Antonio Alessi
  • Marco
« Reply #46 on: February 15, 2024, 08:12:45 AM »
I have been using a script file (SCR) like this for many years:
_.OPEN
"C:/Temp/A001.dwg"
(load "_SCR_BatchExe") ; here you can do anything you want as long as it doesn't break the script
(if(=(getvar "DBMOD")0)(command "_.CLOSE")(command "_.CLOSE" "_Y"))
_.OPEN
"C:/Temp/A002.dwg"
... etc.
_.NEW
"C:/Temp/End.dwt"
(load "_SCR_BatchEnd"); reset variables etc.
(_SCR_BatchEnd nil); reset variables etc.
(alert "Elaborazione conclusa correttamente.")
(princ "\n-\n-\n-\n-\n-\n-\n-\n-\n-\n-\n-\n-\n-\n-\n-\n-\n-\n-")
domenicomaria
« Reply #47 on: February 15, 2024, 08:39:21 AM »
what is "_SCR_BatchExe" ?
Marc'Antonio Alessi
  • Marco
« Reply #48 on: February 15, 2024, 09:23:34 AM »
a lisp File, can be .LSP . FAS/(.DES for BricsCAD)
it is a file that when loaded executes various types of instructions (print, modify, export...)
domenicomaria
« Reply #49 on: February 15, 2024, 09:29:32 AM »
_.OPEN
"C:/Temp/A001.dwg"
_.OPEN
"C:/Temp/A002.dwg"
... etc.
_.NEW
"C:/Temp/End.dwt"
and what do I have to do to run this script?
drag it into acad ?
domenicomaria
« Reply #50 on: February 15, 2024, 09:53:47 AM »
however a few minutes ago I managed to use ACCORECONSOLE
with a simple BAT file and with an SCR file which is a simple LSP file
and I have for the moment understood that
no ARXLOAD
no (command "opendcl")
no comments
« Last Edit: February 15, 2024, 09:59:31 AM by domenicomaria »
Marc'Antonio Alessi
  • Marco
« Reply #51 on: February 15, 2024, 12:36:37 PM »
_.OPEN
"C:/Temp/A001.dwg"
_.OPEN
"C:/Temp/A002.dwg"
... etc.
_.NEW
"C:/Temp/End.dwt"
drag it into acad ?
(command "_.SCRIPT" "yourFile.scr") you can also Drag&Drop...
Marc'Antonio Alessi
  • Marco
« Reply #52 on: February 15, 2024, 04:41:07 PM »
no ARXLOAD
no comments
Do you know about ActiveX functions and accoreconsole?
domenicomaria
« Reply #53 on: February 15, 2024, 11:43:47 PM »
this is the code to make the BAT file i need :
  1. (defun :FILE-WRITE-ASCII (list-strings full-file-name / file-wstream )
  2.    (setq file-wstream (open full-file-name "w") )
  3.    (foreach item list-strings (write-line item file-wstream) )
  4.    (close file-wstream )
  5. )
  6.
  7. (defun :ACC-MAKE-DIR-BAT (folder-path full-accoreconsole-name full-scr-name full-bat-name )
  8.    (setq folder-path   (vl-string-right-trim "\\" folder-path) )
  9.    (setq full-scr-name (vl-string-right-trim ".SCR" (strcase full-scr-name) ) )
  10.    (:FILE-WRITE-ASCII
  11.                         (list
  12.                            "echo on"
  13.                            ""
  14.                            (strcat "set accoreexe=" "\""  full-accoreconsole-name "\"" )
  15.                            ""
  16.                             (strcat "set \"source=" folder-path "\"")
  17.                            ""
  18.                            (strcat "set script=" "\"" full-scr-name "\"")
  19.                            ""
  20.                            "FOR /f \"delims=\" %%f IN ('dir /b \"%source%\\*.dwg\"') DO %accoreexe% /i \"%source%\\%%f\" /s %script%"
  21.                            ""
  22.                            "pause"
  23.                         )
  24.                         full-bat-name
  25.    )
  26.    full-bat-name
  27. )
  28.
  29.
  30. (startapp full-bat-name)
and this is the SCRIPT ...
if you set  k-vla = t
it doesn't work ! ... (it does nothing)
  1. (setvar "layerfilteralert" 0)
  2. (setq k-vla nil)
  3.
  4. (defun LM:DWGVERSION ( dwg / des vrs )
  5.     (cond
  6.         (   (not (and (setq dwg (findfile dwg) ) (setq des (open dwg "r") ) ) )
  7.         )
  8.         (   (wcmatch (strcase dwg t) "*`.dw[gst]")
  9.             (setq vrs (strcase (substr (read-line des) 1 6)))
  10.         )
  11.         (   (wcmatch (strcase dwg t) "*`.dxf")
  12.             (repeat 7 (read-line des))
  13.             (setq vrs (strcase (read-line des)))
  14.         )
  15.     )
  16.     (if (= 'file (type des)) (close des))
  17.     (cdr
  18.         (assoc vrs
  19.            '(
  20.                 ("AC1032" . "2018")
  21.                 ("AC1027" . "2013-2015")
  22.                 ("AC1024" . "2010-2012")
  23.                 ("AC1021" . "2007-2009")
  24.                 ("AC1018" . "2004-2006")
  25.                 ("AC1015" . "2000-2002")
  26.                 ("AC1014" . "Release 14")
  27.                 ("AC1012" . "Release 13")
  28.                 ("AC1009" . "Release 11/12")
  29.                 ("AC1006" . "Release 10")
  30.                 ("AC1004" . "Release 9")
  31.                 ("AC1003" . "Release 2.60")
  32.                 ("AC1002" . "Release 2.50")
  33.                 ("AC1001" . "Release 2.22")
  34.                 ("AC2.22" . "Release 2.22")
  35.                 ("AC2.21" . "Release 2.21")
  36.                 ("AC2.10" . "Release 2.10")
  37.                 ("AC1.50" . "Release 2.05")
  38.                 ("AC1.40" . "Release 1.40")
  39.                 ("AC1.2"  . "Release 1.2")
  40.                 ("MC0.0"  . "Release 1.0")
  41.             )
  42.         )
  43.     )
  44. )
  45.
  46.
  47. (defun :LAYER-FILTERS-DELETE ()
  48.    (vl-catch-all-apply
  49.       '(lambda   ()
  50.           (vla-remove
  51.              "AcLyDictionary"
  52.           )
  53.        )
  54.    )
  55.    (princ "\nAll layer filters have been deleted.")
  56.    (princ)
  57. )
  58.
  59. (if k-vla (:LAYER-FILTERS-DELETE) )
  60.
  61.
  62. (setenv "DefaultFormatForSave" "64")
  63.
  64.
  65. (setq curr-dwg-name (getvar "dwgname") )
  66. (setq curr-full-dwg-name (strcat (getvar "dwgprefix")  curr-dwg-name) )
  67. (princ (strcat "\nthe " curr-dwg-name "\n version is : " (LM:DWGVERSION curr-full-dwg-name ) ) )
  68.
  69.
  70. (setq new-dwg-name       (strcat (vl-filename-base (getvar "dwgname") ) "---[ACAD-2000].dwg") )
  71. (setq new-full-dwg-name (strcat (getvar "dwgprefix")  new-dwg-name) )
  72.
  73. (setenv "DefaultFormatForSave" "12")
  74.
  75.
  76. (if k-vla
  77.    (vla-SaveAs (vla-get-activedocument (vlax-get-acad-object)) new-full-dwg-name acR15_DWG)
  78.    (if(findfile new-full-dwg-name )
  79.       (setq cmd-r (vl-cmdf "_save" new-full-dwg-name "y") )
  80.       (setq cmd-r (vl-cmdf "_save" new-full-dwg-name    ) )
  81.    )
  82. )
  83.
  84.
  85. (if cmd-r
  86.    (princ
  87.          (strcat   "\n\nsave as ACAD 2000 version : "
  88.                   "\n\nThe active DWG has been saved as : \n\n< " (strcase new-dwg-name) " > ."
  89.                   "\n\nIts verified version is : " (LM:DWGVERSION (strcat (getvar "dwgprefix") new-dwg-name ) )
  90.          )
  91.    )
  92.    (princ (strcat "\n\nAn error occurred attempting to save \n\n< " new-dwg-name  " .")   )
  93. )
  94.
  95.
  96.
  97.
  98. (setenv "DefaultFormatForSave" "64")
  99.
  100.
  101. (if k-vla
  102.    (vl-cmdf "close")
  103. )
  104.
consider that in the script there are some superfluous instructions
because I used this code in the defun s::startup
to perform the same task in a different way.
Because by changing S::STARTUP in acaddoc.lsp there are NO LIMITS !
But ACCORECONSOLE is much faster because it doesn't have a graphical interface ...
« Last Edit: February 15, 2024, 11:58:44 PM by domenicomaria »
domenicomaria
« Reply #54 on: February 16, 2024, 05:10:41 AM »
and NO special character in the file and path names
such as    °
(that are allowed in windows)
domenicomaria
« Reply #55 on: February 16, 2024, 07:11:50 AM »
however the code strictly necessary for the script is only that below :
  1.    (setenv "DefaultFormatForSave" "64")
  2.
  3.    (vl-cmdf "_qsave")
  4.
  7.
  8.    (setq new-dwg-name      (strcat (vl-filename-base (getvar "dwgname") ) "---[ACAD-2000].dwg") )
  9.    (setq new-full-dwg-name (strcat (getvar "dwgprefix")  new-dwg-name) )
  10.
  11.    (setenv "DefaultFormatForSave" "12")
  12.
  13.    (if(findfile new-full-dwg-name )
  14.       (setq cmd-r (vl-cmdf "_save" new-full-dwg-name "y") )
  15.       (setq cmd-r (vl-cmdf "_save" new-full-dwg-name    ) )
  16.    )
  17.
  18.    (setenv "DefaultFormatForSave" "64")
Marc'Antonio Alessi
  • Marco
« Reply #56 on: February 16, 2024, 03:08:10 PM »
@Domenico: have you never tried the vlax-...   functions in Core Console?
domenicomaria
« Reply #57 on: February 16, 2024, 03:59:45 PM »
Not for the moment ...
... soon i will give it a try
ciao
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #58 on: February 16, 2024, 07:37:04 PM »
I thought vlax-.. didn't work in accoreconsole.
?? has that changed ?
or have I been delusional for the last 12 (or so ) years.  :|
Called Kerry in my other life
I live at UTC + 13.00
domenicomaria
« Reply #59 on: February 16, 2024, 11:32:37 PM »
sorry... it doesn't work... as expected...
so ACCORECONSOLE can be very useful on many occasions
but there are also many limitations to take into account...
« Last Edit: February 16, 2024, 11:36:12 PM by domenicomaria »
