Author Topic: Text in cell as field - Quickfield addon  (Read 845 times)
brodaa4
  • Mosquito
« on: January 21, 2024, 05:07:33 PM »
I'm trying to figure out how to edit LEE MAC's Quick field Program to use the text value in mouse selected table cells to create a field and then insert it as attribute. Im thinking that i should read values with VLA but got lack of knowledge.
I will be grateful for any help.
It's Alive!
  • Retired
  • AKA Daniel
Re: Text in cell as field - Quickfield addon
« Reply #1 on: January 21, 2024, 07:10:23 PM »
I have an arx that may work, if you’re using AutoCAD 2021-2024
It was designed for mtext, not sure if it will update with blocks since they’re cached
It's Alive!
  • Retired
  • AKA Daniel
« Reply #2 on: January 21, 2024, 08:14:16 PM »
seems to work with attributes
brodaa4
  • Mosquito
« Reply #3 on: January 24, 2024, 03:16:02 PM »
Autocad was the issue, I've got GstarCad that dont support ARX. But ill try to test that on trial.
Thanks very much for answer.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: January 24, 2024, 08:59:12 PM »
GstarCad’s GRX has the evaluator, but it doesn’t have the dialog hook yet. Send them a support request.
