Author Topic: Lee lisp FieldObjects not working in some files  (Read 755 times)
HasanCAD
« on: January 18, 2024, 04:13:55 AM »
I am wondering the lisp is working in most of files and not working in few numbers of files.
error
  1. Select field:
  2. Press any key to exit...
Lee lisp
http://lee-mac.com/fieldobjects.html
The cad file attached.
Thanks for your help
CodeDing
Re: Lee lisp FieldObjects not working in some files
« Reply #1 on: January 18, 2024, 11:30:33 AM »
HasanCAD,
It is working, but you just need to zoom out really far to see it (see attached image 'DifferentAreas').
This is happening because you are using a custom UCS that the program its not accounting for.
If you run the "UCS" command, then select the "World" option to reset the UCS, then it will appear correctly (see attached image 'AfterUCSReset')
Senior CAD Tech & AI Specialist
Need AutoLisp help?
Try my custom GPT 'AutoLISP Ace'
HasanCAD
« Reply #2 on: January 19, 2024, 07:57:40 AM »
Thanks CodeDing
Working good
