Author Topic: Write file DOC with MSWORD.OLB without WORD.application installed.  (Read 837 times)
FELIX
I need to write a DOC file using only the MSWORD.OLB library file without WORD.application, without MSWord being installed.
I think there's an example here on this forum but I can't find it because it's been a long time since I saw it and I didn't need it at the time.
OK.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: Write file DOC with MSWORD.OLB without WORD.application installed.
« Reply #1 on: January 14, 2024, 09:59:56 PM »
Hi Felix,
There are 4 references to 'MSWORD.OLB'
Select 'TheSwamp' main page
Enter MSWORD.OLB into Search
Follow the breadcrumbs.
Regards,
Called Kerry in my other life
I live at UTC + 13.00
FELIX
« Reply #2 on: January 14, 2024, 10:23:54 PM »
Thank you kdub_nz for sending it but I had already researched this and they all use "(setq msw (vlax-get-or-create-object "Word.Application"))" which means that MSWord must be installed.
OK.
« Reply #3 on: January 15, 2024, 08:13:45 AM »
Word docs are just zipped XML, so you could write the XML as plain text and then zip it programmatically.
FELIX
« Reply #4 on: January 15, 2024, 09:10:08 AM »
XML are .DOCX files but I need it to be .DOC
OK.
BIGAL
  • 40 + years of using Autocad
« Reply #5 on: January 15, 2024, 09:18:03 PM »
Handy hint Lee same with Acad CUIX.
Can they not read the docx ? Docx was introduced in 2007 that is a lot of years ago.
Lots of free stuff out there if you trust to convert docx to doc. Do a google.
