1. Insert multiple vertices at fixed distance intervals
2. Globally insert vertices based on equal fractions
3. According to equal fractions, insert vertices into each segment equally.
(defun c:XDTB_PLBatInsPnt (/ e mode dis pts div)
(if (not #xd-var-global-poly-inspnt-mode)
(setq #xd-var-global-poly-inspnt-mode "A")
(xdrx-begin)
(and (setq
e (car
(xdrx-entsel
(xdrx-string-multilanguage
"\n拾取多段线<退出>:"
"\nPick a Polyline<Exit>:"
'((0 . "*polyline"))
(xdrx-entity-redraw e 1)
(xdrx-initget "A F")
(or (and (setq mode
(getkword
(xdrx-string-formatex
"\n模式[定距(A)/等分(F)]<%s>:"
"\nMode [Fixed distance (A)/Equal division (F)]<%s>:"
(xdrx-initget)
(setq #xd-var-global-poly-inspnt-mode mode)
t
((= #xd-var-global-poly-inspnt-mode "A")
(and (setq dis
(getreal
(xdrx-string-multilanguage "\n间距<退出>:" "Gap<Exit>:")
(setq pts (xdrx-curve-getpointsatdist e dis))
(t
(if (setq div (getint (xdrx-string-multilanguage
"\n等分数<退出>:"
"\nDivide Nums<Exit>:"
(if (and (xdrx-initget "Y N")
(= 1
(xdrx-yesorno
"\n全局等分"
"\nGlobal Divide"
1
(xdrx-initget)
(setq pts (xdrx-curve-getsamplepoints e div))
(setq allsegs (xdrx-getpropertyvalue e "allsegs")
pts (mapcar '(lambda (x)
(xdrx-curve-getsamplepoints x div)
allsegs
pts (xdrx-points-removedup (apply 'append pts))
(if pts
(and (setq inx (xdrx-getpropertyvalue e "onseg" x))
(xdrx-polyline-addvertexat e (1+ inx) x)
(cdr pts)
(xdrx-prompt
"\n插入了 %d 个顶点."
"\n%d vertices inserted."
(length (cdr pts))
(xdrx-prompt
"\n给定条件下没有获取到插入点,重试."
"\nThe insertion point was not obtained under the given conditions, try again."
;(xdrx-entity-redraw e)
(xdrx-end)
