(defun c:xdtb_dimres (/ #endpoint #startpoint ang
box dimexo dimlinepnt e e1
e2 e3 e4 e5 i int1
int2 pnt scl ss ss1 styl
style txt v x xdir xline1pnt
xline2pnt ydir
(defun xd::dim:isexplodegroup (txt / box xdir ydir ss)
(defun _isparallel (e v)
(xdrx-getpropertyvalue e "startpoint")
(xdrx-vector-isparallel
(xdrx-getpropertyvalue e "getfirstderiv" #startpoint)
v
(defun _isperp (e v)
(xdrx-vector-isperpendicular
v
(defun _xlinepnt (e pnt)
(xdrx-getpropertyvalue e "startpoint" "endpoint")
(if (< (distance #startpoint pnt) (distance #endpoint pnt))
#endpoint
#startpoint
(if (and (setq box (xdrx-text-box txt)
xdir (xdrx-vector-normalize
(mapcar '- (nth 1 box) (nth 0 box))
ydir (xdrx-vector-normalize
(mapcar '- (nth 2 box) (nth 1 box))
(setq ss (xdrx_entity_prevEntities txt 5))
(= (length ss) 5)
(xdrx-object-iskindof (setq e1 (nth 0 ss)) "acdbblock*")
(xdrx-object-iskindof (setq e2 (nth 1 ss)) "acdbblock*")
(xdrx-object-iskindof (setq e3 (nth 2 ss)) "acdbline")
(xdrx-object-iskindof (setq e4 (nth 3 ss)) "acdbline")
(xdrx-object-iskindof (setq e5 (nth 4 ss)) "acdbline")
(_isparallel e3 xdir)
(_isparallel e4 ydir)
(_isparallel e5 ydir)
(progn (setq styl (getvar "dimstyle")
style (xdrx-object-get "dimstyle" styl)
dimexo (xdrx-getpropertyvalue style "dimexo")
scl (xdrx-getpropertyvalue style "dimscale")
int1 (xdrx-get-inters e3 e4 1)
int2 (xdrx-get-inters e3 e5 1)
dimlinepnt (car int1)
xline1pnt (_xlinepnt e5 (car int2))
xline2pnt (_xlinepnt e4 (car int1))
ydir (xdrx-vector-normalize (mapcar '- xline2pnt dimlinepnt))
xline1pnt (mapcar '+
xline1pnt
(xdrx-vector-product ydir (* dimexo scl))
xline2pnt (mapcar '+
xline2pnt
ang (angle (car int2) dimlinepnt)
(list (list dimlinepnt xline1pnt xline2pnt ang) ss)
(xdrx-begin)
(xdrx-prompt
(xdrx-string-multilanguage
"\n**请设置好当前的标注样式,按当前标注样式恢复炸开的标注对象**"
"\n**Restore the exploded dimension object according to the current dimension style**"
(if (setq
ss1 (xdrx-ssget
"\n请选择炸开后的文字<退出>:"
"\nPlease select the exploded text <Exit>:"
'((0 . "*text"))
(setq i 0)
(mapcar '(lambda (x)
(if (setq ss (xd::dim:isexplodegroup x))
(progn (setq i (1+ i))
(xdrx-entity-delete ss)
(xdrx_dimension_MakeRotate
(cadr (car ss))
(caddr (car ss))
(car (car ss))
(last (car ss))
(xdrx-entity-matchprop x (entlast))
(xdrx-setpropertyvalue (entlast) "color" 256)
(xdrx-entity-delete (cons x (last ss)))
(xdrx-pickset->ents ss1)
(xdrx-prompt
(xdrx-string-formatex
"\n共选择了 %d 个文字,其中发现炸开组 %d 个,恢复了 %d 个标注对象."
"\nA total of %d texts were selected, among which %d exploded groups were found and %d annotation objects were restored."
(sslength ss1)
i
i
(xdrx-end)
