Author Topic: [XDrX-PlugIn(77)] Polyline POLY to ARC POLY  (Read 304 times)
xdcad
« on: January 03, 2024, 11:47:12 PM »
(defun c:xdtb_poly2arc (/ tol ss inx ents pts _arc garc gpl)
  (xdrx-begin)
  (if (not #xd-var-global-fitarc-tol)
    (setq #xd-var-global-fitarc-tol (/ (xd::doc:getpickboxheight) 3.0))
  (if (setq
tol (getreal (xdrx-prompt
       (xdrx-string-formatex
(xdrx-string-multilanguage
   "\n输入长度容差<%.2f>"
   "\nEnter the arc seg length tol<%.2f>"
       t
    (setq #xd-var-global-fitarc-tol tol)
  (if (setq ss (xdrx-ssget
   "\n选择带弧段的多段线<退出>:"
   '((0 . "*polyline"))
      (mapcar
'(lambda (x)
   (setq pts   nil
numverts (xdrx-getpropertyvalue x "numverts")
   (setq inx  0
ents nil
   (repeat (1- numverts)
     (if (setq seg (xdrx-polyline-getlinesegat x inx))
(if (< (apply 'distance seg)
   (setq pts (append pts seg))
     (if pts
(setq _arc (xdrx-points->circle pts t)
       garc (xdge::constructor _arc)
       ents (cons garc ents)
       pts  nil
(xdrx-entity-delete _arc)
     (setq ents (cons (xdge::constructor "kLineSeg3d" seg) ents))
       pts  nil
     (setq inx (1+ inx))
   (if pts
     pts  nil
   (setq ents (reverse ents))
   (setq gpl (xdge::constructor "kCompositeCrv3d" ents))
   (xdrx-entity-make gpl)
   (xdrx-entity-matchprop x (entlast))
   (xdrx-object-swapid x (entlast))
   (xdrx-entity-delete (entlast))
(xdrx-ss->ents ss)
  (xdrx-end)
https://github.com/xdcad
http://bbs.xdcad.net
