Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Help to update a purge lisp
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Help to update a purge lisp (Read 1859 times)
mhy3sx
Newt
on:
December 20, 2023, 02:00:59 AM »
Hi. This code works fine in Autocad. I use ZWCAD now and some lisp codes don't work the same. I use this code to have a better purge. The problem is when I use this lisp in ZWCAD every time gives me this error (look the image), and all the time I have to press enter to continue. Can anyone know why?
The code is
Code - Auto/Visual Lisp:
[Select]
defun
c:myprg
Layer
p results
setvar
"clayer"
"0"
setvar
"cmdecho"
0
command
"._UNDO"
"BEGIN"
;; return boole for layer existence
defun
Layer
p
l
and
tblsearch
"LAYER"
l
setq
results
mapcar
lambda
x
Layer
p x
"layer1"
"layer2"
"layer3"
"layer4"
;end mapcar
foreach
x
list
"ZERO"
"EMPTY"
"BLOCK"
"MLINESTYLE"
"LAYER"
"LTYPE"
"VISUALSTYLES"
"MATERIALS"
if
member
't results
command
"-purge"
x
"n"
command
"-purge"
x
"n"
"-overkill"
"all"
;end if
; end foreach
command
"-purge"
"R"
"n"
command
"._UNDO"
"END"
setvar
"cmdecho"
1
princ
; end defun
Logged
PKENEWELL
Bull Frog
Re: Help to update a purge lisp
Reply #1 on:
December 20, 2023, 09:33:09 AM »
I suspect it is because there is no option in the ZWCAD purge command for "VISUALSTYLES" and "MATERIALS".
Change:
[Select]
foreach
x
list
"ZERO"
"EMPTY"
"BLOCK"
"MLINESTYLE"
"LAYER"
"LTYPE"
"VISUALSTYLES"
"MATERIALS"
to:
[Select]
foreach
x
list
"ZERO"
"EMPTY"
"BLOCK"
"MLINESTYLE"
"LAYER"
"LTYPE"
I would also check the command for any other missing or added options of the -PURGE command by manually going though it, then add or remove the appropriate strings from the above line.
Logged
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
mhy3sx
Newt
Reply #2 on:
December 20, 2023, 10:32:00 AM »
Thanks PKENEWELL, now working fine
Logged
PKENEWELL
Bull Frog
Reply #3 on:
December 20, 2023, 11:11:22 AM »
Quote from: mhy3sx on December 20, 2023, 10:32:00 AM
Your most welcome
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
