Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Layer creation not working in if statement
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Layer creation not working in if statement (Read 2122 times)
Windsor
Mosquito
on:
December 12, 2023, 11:16:42 AM »
I have an AutoLisp script which I have created to plot a crossed out box on a non printable guide layer, I have incorperated an if statement to check if this layer is already within the current drawing and if not to create it. However if the layer is not present the script doesn't work.
Is there a way to resolve this problem at all? (probably something I haven't noticed as of yet)
Code - Auto/Visual Lisp:
[Select]
; Creates box on unprintable guide layer which has a
; cross trough it to denote an unused area of the drawing
defun
c:UNUSED
P1 P2 P3 P4 Change
vl-load-com
setq
CL
getvar
"clayer"
;Checks if 1 - Guide layer is already in drawing, if not creates it
if
tblsearch
"layer"
"1 - Guide"
;Statement
;if true
command
"_.LAYER"
"M"
"1 - Guide"
"C"
"Magenta"
"P"
"N"
;if false
;Inputs
setq
P1
getpoint
\n
Specify First Point:"
P3
getpoint
\n
Specify Second Point:"
;Calculations
setq
P2
list
car
P3
cadr
P1
setq
P4
list
car
P1
cadr
P3
;Change to 1 - Guide function
defun
change
command
"_.change"
entlast
"p"
"LA"
"1 - Guide"
;Box Plot
Command
"PLINE"
P1 P2 P3 P4
"c"
change
command
"LINE"
P1 P3
change
command
"LINE"
P2 P4
change
setvar
"clayer"
CL
prompt
\n
\t
Box Created!"
princ
Is there also a method for having a real-time preview of the shape from the first point until the second (opposite corner) is clicked?
Logged
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
class keyThumper<T>:ILazy<T>
Re: Layer creation not working in if statement
Reply #1 on:
December 12, 2023, 02:06:02 PM »
Have a look at
(getcorner pt [msg])
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-21BE8290-7F11-400B-AC39-62A110F07545
Logged
Called Kerry in my other life
I live at UTC + 13.00
Seagull
London, England
WWW
Reply #2 on:
December 12, 2023, 03:46:23 PM »
You're missing an extra enter in your command expression:
[Select]
command
"_.LAYER"
"M"
"1 - Guide"
"C"
"Magenta"
"P"
"N"
Logged
Lee Mac Programming
Twitter
Exchange App Store
Seagull
London, England
WWW
Reply #3 on:
December 12, 2023, 04:01:43 PM »
A few other points to note:
You can use
(if (not (tblsearch "layer" "1 - Guide"))
followed by your command expression to avoid the empty list forming the 'then' argument, to improve readability.
You should either disable OSMODE during the execution of the PLINE command or prefix the point input with "_non" point modifiers to avoid Object Snap affecting the supplied point input.
is not required here as you are not using COM.
You could use entmake to create both the layer and the polyline & lines to automatically assign the layer and avoid having to assign it after the object has been created (it will also be much faster and will be immune to the effect of Object Snap), here is an example to help:
[Select]
defun
c:unused
lay ocs pt1 pt2 pt3 pt4
setq
lay
"1 - Guide"
;; Layer Name
if
and
setq
pt1
getpoint
\n
Specify 1st point: "
setq
pt3
if
zerop
getvar
'worlducs
getpoint
getcorner
pt1
\n
Specify opposite corner: "
progn
if
not
tblsearch
"layer"
lay
entmake
list
000 .
"LAYER"
100
"AcDbSymbolTableRecord"
100
"AcDbLayerTableRecord"
070 .
0
;; on/unlocked
062 .
6
;; magenta colour
290
0
;; non-plotting
cons
2
lay
setq
pt2
cons
car
pt3
cdr
pt1
pt4
cons
car
pt1
cdr
pt3
ocs
trans
0
0
1
1
0
t
entmake
list
000 .
"LWPOLYLINE"
100
"AcDbEntity"
100
"AcDbPolyline"
090 .
4
;; 4 vertices
070 .
1
;; closed
cons
008 lay
;; layer
cons
010
trans
pt1
1
ocs
cons
010
trans
pt2
1
ocs
cons
010
trans
pt3
1
ocs
cons
010
trans
pt4
1
ocs
cons
210
ocs
entmake
list
000 .
"LINE"
cons
008 lay
cons
010
trans
pt1
1
0
cons
011
trans
pt3
1
0
entmake
list
000 .
"LINE"
cons
008 lay
cons
010
trans
pt2
1
0
cons
011
trans
pt4
1
0
princ
Logged
Lee Mac Programming
Twitter
Exchange App Store
Windsor
Mosquito
Reply #4 on:
December 14, 2023, 09:01:12 AM »
Thanks Kdub for the link, good reference for attempting again in the fiture.
Thanks Lee, something I had completely overlooked in my original attempt. And Thanks for the rewrite, many good points which I wouldn't have even thought to attempt!
Logged
Seagull
London, England
WWW
Reply #5 on:
December 14, 2023, 06:00:38 PM »
You're most welcome Windsor, happy to help.
Logged
Lee Mac Programming
Twitter
Exchange App Store
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
