Author Topic: New Project Step 2 Layers  (Read 22189 times)
daron
« Reply #30 on: July 25, 2005, 09:08:42 AM »
Thanks for answering that Keith. I have always found vba to be somewhat limiting in that respect. I guess it has to do with keeping things structured.
David Hall
  • Automatic Duh Generator
« Reply #31 on: July 25, 2005, 02:49:47 PM »
Everybody ready to move on?
jonesy
  • SuperMod
« Reply #32 on: July 25, 2005, 03:43:20 PM »
I think so.
David Hall
« Reply #33 on: July 26, 2005, 02:32:43 PM »
OK, before we do a function for if the layer exists, I wanted to talk about OverLoading.  VBA does not Overload like C#, (which is where I got this from), but it does allow us to kinda-not really-sorta-maybe maybe not overload a function.  I know that none of that made any sense.  Thats OK, humor me.  I'm sure someone will correct me, but thats ok too.
Public Sub LLayer(ByRef Lname As String, Lcolor As Integer, Ltype As String)
    Dim objLayer As AcadLayer
    Set objLayer = ThisDrawing.Layers.Add(Lname)
    objLayer.color = Lcolor
    objLayer.Linetype = Ltype
    Set objLayer = Nothing
    Exit Sub
End Sub
What if you knew the name and color, but not the linetype?  Name and Linetype, but not color?  What happens if you leave out a value that the function is expecting?  Where I'm going with this is we could have 3-5 versions of this code to accomplish each version we could think of.
Public Sub LLayer(ByRef Lname As String)
    Exit Sub
End Sub
Public Sub LLayer(ByRef Lname As String, Lcolor As Integer)
    Exit Sub
End Sub
Public Sub LLayer(ByRef Lname As String, Ltype As String)
    Exit Sub
End Sub
    Exit Sub
End Sub
« Last Edit: January 11, 2006, 08:10:01 AM by CmdrDuh »
David Hall
« Reply #34 on: July 26, 2005, 02:40:53 PM »
Does everybody understand the 4 versions I loaded?  What if we could do the same thing with ONLY 1 version of the code?
Birdy
« Reply #35 on: July 26, 2005, 02:49:30 PM »
The main difference I see (quick glance) is the
Public Sub LLayer(ByRef...)
line. Am I on the right track?
daron
« Reply #36 on: July 26, 2005, 02:53:23 PM »
Are you saying you need optional arguments or default to what's current?
« Reply #37 on: July 26, 2005, 02:53:41 PM »
heh  David.
must admit my ears pricked up when I saw VBA and overloading in the same sentence
.. for a  bit anyway.
David Hall
« Reply #38 on: July 26, 2005, 02:58:03 PM »
Here is a bit of code that uses the Keyword Optional.
Private Sub LLayer(ByRef Lname As String, Optional Lcolor As Integer, Optional Ltype As String)
    On Error GoTo ErrorHandler
    If DoesLayerExist(Lname) = False Then
        'SHOW 2 WAYS TO ERROR TRAP THIS
     '   If Lcolor <> 0 Then
     '   End If
     '   If Ltype <> "" Then
     '   End If
    End If
    GoTo Clean_Up
ErrorHandler:
    Select Case Err
        Case -2145320939:
            Err.Clear
            MsgBox "Invalid Color call"
            Resume Next
        Case -2145386493:
            Err.Clear
            MsgBox "Invalid Linetype call"
            Resume Next
        Case Else:
            Err.Raise Err.Number, Err.Source, Err.Description, Err.HelpFile, Err.HelpContext
    End Select
Clean_Up:
   Lcolor = 0
   Lname = ""
   Ltype = ""
   Exit Sub
End Sub
When we CALL this code, we can pass our arguments normally, but now if we do not know one of them or we do not wish to change from the default, we do not have too.
Here is 4 examples of code using the optional arguments
Public Sub SetupDwgWithLayersAndLinetypes()
    LLINE
    Call LLayer("Layer1", acRed, "HIDDEN")
    Call LLayer("Layer2")
    Call LLayer("Layer3", acBlue)
    Call LLayer("Layer4", , "DASHED")
End Sub
Each of the arguments must be separated by commas (,).
For Layer1, we are using all 3 arguments.  Layer2 is just the name.  Layer3 uses Name and Color. and Layer4 is Name and Linetype.
Notice in Layer4, we added a comma (,) to show that color was blank.
David Hall
« Reply #39 on: July 26, 2005, 02:59:45 PM »
Quote from: Kerry Brown
heh  David.
Please correct me where I'm wrong.  Im hoping you and MickD steer me straight on this.  I know the terminology is wrong, but its what I know.
Birdy
« Reply #40 on: July 26, 2005, 03:02:23 PM »
btw, I'm trying to combine the layers and linetypes by doing this:
Public Sub LLINE()
ThisDrawing.Linetypes.Load "HIDDEN", "ACAD.LIN"
ThisDrawing.Linetypes.Load "DASHED", "ACAD.LIN"
Exit Sub
ErrorHandler:
Select Case Err
Case -2145386405:
Err.Clear
Resume Next
Case Else:
End Select
End Sub
    Exit Sub
End Sub
Public Sub test()
    Call LLayer("Layer2", acGreen, "DASHED")
End Sub
but it seems that I have to alt+f8 two seperate times (that is.. two seperate files?) to get it to work as I'd expect.  Am I missing something in how I'm saving and/or loading these? (will re-review the primers this evening, DOH!)
One minute I feel like a dope with this, the next like a bright and shiny light bulb.... and then like a dope again. :oops:
David Hall
« Reply #41 on: July 26, 2005, 03:06:53 PM »
Quote from: Birdy
Public Sub LLINE()
Exit Sub
ErrorHandler:
Select Case Err
Case -2145386405:
Err.Clear
Resume Next
Case Else:
End Select
End Sub
    Exit Sub
End Sub
Public Sub test()
Call LLine ' Cmdrduh Added this to load Linetypes before creating layers
End Sub
Look at the code for the sub TEST.  I added one line to load your linetypes just before you create your layers.  You should only have to run Test 1 time to get what you want.
Birdy
« Reply #42 on: July 26, 2005, 03:08:15 PM »
David Hall
« Reply #43 on: July 26, 2005, 03:09:32 PM »
Quote from: Birdy
btw, I'm trying to combine the layers and linetypes by doing this:...  ..... .....
You guys are getting this and making good progress, its just that your moving faster than I can type.  (Which is not a bad thing)  I just hadn't gotten to the part where we create 1 function to do all the code.  I was creating small modules to teach the concept, and we would put them all together later.
« Reply #44 on: July 26, 2005, 03:10:06 PM »
Overloading is the correct term David.
essentially having multiple method definitions, with the same name, but each with its own unique signature < Type and order of parameters >
C# does not support optional method arguments.
