Author Topic: New Project Step 2 Layers  (Read 22183 times)
David Hall
  • Automatic Duh Generator
« on: July 12, 2005, 03:07:07 PM »
Ok, Lets load some layers.  Any idea how to load 2 layers, not worrying about color and linetype just yet?  I'll start us off with
Public Sub LLayer()
End Sub
Its going to use the ThisDrawing methods again, so lets see what people come up with.
Extra Credit:Create a function that checks to see if the Layer exists, therefore not re-creating it.  This will be important when we begin assiging color and linetypes to layers.
David Hall
« Reply #1 on: July 12, 2005, 03:09:26 PM »
Layer names should be 'Yellow' and 'White' for now.
« Reply #2 on: July 12, 2005, 03:21:30 PM »
For now ...
Public Sub LLayer()
    Dim Ylayer As AcadLayer
    Set Ylayer = ThisDrawing.Layers.Add("Yellow")
    Dim Wlayer As AcadLayer
    Set Wlayer = ThisDrawing.Layers.Add("White")
End Sub
David Hall
« Reply #3 on: July 12, 2005, 03:23:28 PM »
Excellent, now how about assigning the respective colors to the layers.  Any ideas?
David Hall
« Reply #4 on: July 12, 2005, 06:22:37 PM »
I am interested in what you think should be done to assign the colors.  If you try something, post what you tried.  Even if it doesn't work, post it so others can see what has been tried.
TR
« Reply #5 on: July 12, 2005, 09:01:23 PM »
Just a note: Anytime you use 'Set' you should set it to Nothing at the end of the sub.
David Hall
« Reply #6 on: July 13, 2005, 09:08:15 PM »
Quote from: Tim Riley
Tim makes an excellent point, so lets add that
Public Sub LLayer()
    Set Ylayer = Nothing
    Set Wlayer = Nothing
End Sub
TR
« Reply #7 on: July 13, 2005, 11:36:21 PM »
IMHO you should have an On Error Goto ErrorH statment and that should set everything to nothing. That way regardless of the situation the sub cleans itself.
David Hall
« Reply #8 on: July 14, 2005, 10:13:16 AM »
Im thinking Tim means something like this
Public Sub LLayer()
    On Error GoTo Error_Handler
    Exit Sub
Error_Handler:
    Err.Clear
End Sub
Now we still need to change the colors of those newly created layers.  Any ideas?
Birdy
« Reply #9 on: July 16, 2005, 08:07:47 PM »
I'm messing with this:
Public Sub LLayer()
    Dim Ycolor As ACAD_COLOR
    Set Object.Ycolor = ThisDrawing.Layers.TrueColor("Yellow")
    Set Object.Wcolor = ThisDrawing.Layers.TrueColor("White")
    Exit Sub
Error_Handler:
    Err.Clear
End Sub
But it ain't working. <shooting blanks in the dark here, Huh?>
« Reply #10 on: July 16, 2005, 09:39:18 PM »
Birdy, How about something like this ??
Remember, you can Use the Locals window to see variable values when Stepping through <F8> code.
ps: I'm not a VB'er, so this may not be 100%
Option Explicit
' Test Routine for Demo Only.
Public Sub CLLayer()
    On Error GoTo CLLayer_Error
    Dim ColorProperty As Integer
    ColorProperty = acYellow
    Ylayer.color = ColorProperty
    ' Could have used :
    ' Ylayer.color = acYellow
    ' to save the declaration and assignment
    ' Next Option
    Dim Glayer As AcadLayer
    Dim TrueColor As New AcadAcCmColor
    Call TrueColor.SetRGB(0, 255, 0)
    Set Glayer = ThisDrawing.Layers.Add("Green")
    Glayer.TrueColor = TrueColor
    ' Next Option
    Dim Newlayer As AcadLayer
    Set Newlayer = ThisDrawing.Layers.Add("FourtyOne")
    Newlayer.color = 41
    ' Added for fun
    Dim aacColor As AcadAcCmColor
    Set aacColor = Newlayer.TrueColor
    Dim strColor As String
    strColor = "Red = " & aacColor.Red & vbCrLf & _
               "Green = " & aacColor.Green & vbCrLf & _
               "Blue = " & aacColor.Blue
    MsgBox strColor
    On Error GoTo 0
    GoTo Set_To_Nothing
CLLayer_Error:
    MsgBox "Error " & Err.Number & " (" & Err.Description & _
           ") in procedure CLLayer of Module TestLayer"
Set_To_Nothing:
    Set Glayer = Nothing
    Set Newlayer = Nothing
    Set aacColor = Nothing
End Sub
David Hall
« Reply #11 on: July 21, 2005, 09:28:24 AM »
Excellent example KWB!  This example has multiple ways to color a layer.  Did everyone look at the different ways to do this?  Most people (Myself included) will probable only think of acad colors as 1-255, but there are other colors you might need.
David Hall
Update to this
« Reply #12 on: July 21, 2005, 10:31:50 AM »
Question - Is everyone familiar with the concept of passing a Sub/Function an Argument?  I ask because I want us to reduce the amount of typing that went into our code.
David Hall
« Reply #13 on: July 21, 2005, 02:27:15 PM »
^ Need a show of hands to move on.
jonesy
  • SuperMod
« Reply #14 on: July 21, 2005, 04:27:32 PM »
Getting there
