Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
XDRX-API
Topic:
[XDrX-PlugIn(35)] Polyline coordinate point information statistics table
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [XDrX-PlugIn(35)] Polyline coordinate point information statistics table (Read 685 times)
xdcad
Swamp Rat
WWW
on:
December 04, 2023, 08:01:30 AM »
Code - Auto/Visual Lisp:
[Select]
defun
c:XDTB_PLSegList
#xd_table_res_z _lengths _format _writebulges _mergecell bulge bulges
verts i j c val lens lst r gl g
defun
_lengths
setq
g
xdge::constructor e
gl
xdge::getpropertyvalue g
"getcurvelist"
setq
lens
mapcar
lambda
x
xdge::getpropertyvalue x
"length"
gl
xdge::free g gl
lens
defun
_writebulges
tb
setq
rows
xdrx_table_numrows tb
setq
i
3
j
0
while
i
1-
rows
setq
bulge
_format
nth
j bulges
4
if
bulge
"0.0"
setq
bulge
xdrx_setpropertyvalue
tb
"textstring"
list
list
i
4
bulge
list
i
5
_format
nth
j lens
#xd_table_txt_bits
"textheight"
list
list
i
4
#xd_table_txt_height
list
i
5
setq
j
1+
j
i
i
2
defun
_format
str bit
if
equal
str
0.0
1e
3
"0.0"
rtos
str
2
bit
defun
_mergecell
tb startCol endCol startRow
setq
rows
setq
c startCol
while
startCol c endCol
setq
r startRow
while
r
1-
rows
xdrx_table_mergecells tb r
1+
r
c c
setq
r
2
r
setq
c
1+
c
xdrx_begin
xdrx_sysvar_push '
"dimzin"
0
if
1
xdrx_yesorno
\n
Keep Z Coordinate"
0
setq
#xd_table_res_z t
if
not
setq
3.5
if
setq
val
getreal
xdrx_prompt
\n
Text Height<"
t
setq
#xd_table_txt_height val
if
not
#xd_table_txt_bits
setq
#xd_table_txt_bits
1
if
setq
val
getint
xdrx_prompt
\n
Keep the number of decimal places for lengths<"
#xd_table_txt_bits
t
setq
#xd_table_txt_bits val
if
setq
e
car
xdrx_entsel
\n
Pick a Polyline<Exit>:"
0
"LWPOLYLINE"
progn
setq
verts
xdrx_getpropertyvalue e
"vertices"
"bulges"
lens
_lengths
bulges
cadr
verts
verts
car
verts
setq
lst
mapcar
lambda
x
list
_format
car
x
4
_format
cadr
x
4
_format
caddr
x
4
verts
setq
lst
xd::table:celltile
"Number"
"Coord X"
"Coord Y"
"Coord Z"
"Bulge"
"Length"
1
lst
setq
i
0
lst
mapcar
lambda
x
if
i
0
progn
setq
i
1+
i
list
x
list
x x
lst
lst
cons
list
"Polyline Coordinate information table"
nil
nil
nil
nil
nil
apply
append
lst
xd::text:init
1
setq
tb
xd::table:makefromlist lst pt #xd_table_txt_height
0.0
xd::table:begin tb
_mergecell tb
0
3
2
_mergecell tb
4
5
3
_writebulges tb
if
not
#xd_table_res_z
xdrx_table_deletecolumns tb
3
1
xdrx_table_setrowheight tb
0
2.0
1
2.0
tb
"color"
7
"HorzCellMargin"
2.0
"autosize"
t
xd::table:end tb
xd::drag:simplemove
entlast
\n
Table Insert:"
8
t
xdrx_sysvar_pop
xdrx_end
princ
Last Edit: December 04, 2023, 08:04:51 AM by xdcad
Logged
https://github.com/xdcad
http://bbs.xdcad.net
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
XDRX-API
Topic:
