Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
XDRX-API
Topic:
[XDrX-PlugIn(34)] Generate Circle statistics table
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [XDrX-PlugIn(34)] Generate Circle statistics table (Read 786 times)
xdcad
Swamp Rat
WWW
on:
December 04, 2023, 05:47:11 AM »
Circles of the same area are coded together
Code - Auto/Visual Lisp:
[Select]
defun
c:XDTB_TJCIR1
ss a p lst v a p1 txt
if
not
#xd
var
global
table
textheight
setq
#xd
var
global
table
textheight
4.0
if
setq
v
getreal
xdrx
prompt
\n
Text height<"
#xd
var
global
table
textheight
t
setq
#xd
var
global
table
textheight v
if
not
#xd
var
global
table
textpos
setq
#xd
var
global
table
textpos
5
xdrx
initget
"1 2 3 4 5 6 7 8 9"
if
setq
v
getreal
xdrx
prompt
\n
Text label position [BottomLeft(1)/BottoMiddle(2)/BottomRight(3)/MiddleLeft (4)/Middle(5)/MiddleRight(6)/UpperLeft(7)/UpperMiddle(8)/TopRight(9)]<"
#xd
var
global
table
textpos
t
setq
#xd
var
global
table
textpos v
if
not
#xd
var
global
bits
setq
#xd
var
global
bits
1
if
setq
v
getint
xdrx
prompt
\n
Number of decimal places<"
#xd
var
global
bits
t
setq
#xd
var
global
bits v
if
and
xdrx
initssget
\n
Select the circles to be counted <Exit>:"
setq
ss
xdrx_ssget '
0
"circle"
progn
xdrx
begin
xdrx_sysvar_push '
"dimzin"
0
setq
lst
mapcar
lambda
x
list
xdrx_getpropertyvalue x
"radius"
xdrx
getpropertyvalue x
"center"
x
xdrx_pickset
ents ss
lst
xd::
list
:groupbyindex lst 1e
3
lst
vl-sort
lst '
lambda
x y
car
x
car
y
a
65
xd::text:init
1
setq
lst
mapcar
lambda
x
i
setq
i
1
mapcar
lambda
b
p p1 txt
setq
p
xdrx_getpropertyvalue b
"center"
txt
xdrx_text_make
p1
strcat
chr
a
itoa
i
#xd
var
global
table
textheight
0.0
p1
cond
#xd
var
global
table
textpos
1
setq
pos
9
polar
p
5
pi
4
car
x
1.2
#xd
var
global
table
textpos
2
setq
pos
8
polar
p
pi
2
car
x
1.2
#xd
var
global
table
textpos
3
setq
pos
7
polar
p
pi
4
car
x
1.2
#xd
var
global
table
textpos
4
setq
pos
6
polar
p
pi
car
x
1.2
#xd
var
global
table
textpos
5
setq
pos
5
p
#xd
var
global
table
textpos
6
setq
pos
4
polar
p
0.0
car
x
1.2
#xd
var
global
table
textpos
7
setq
pos
3
polar
p
3
pi
4
car
x
1.2
#xd
var
global
table
textpos
8
setq
pos
2
polar
p
pi
2
car
x
1.2
#xd
var
global
table
textpos
9
setq
pos
1
polar
p
pi
4
car
x
1.2
t
p
txt
xdrx_text_make
p1
strcat
chr
a
itoa
i
#xd
var
global
table
textheight
0.0
i
1+
i
xdrx_text_setvermode txt
3
setq
lxd txt
xdrx
entity
move txt
xd::geom:get9pt txt pos
p1
mapcar
last
vl-sort
cdr
x
lambda
x y
caar
x
caar
y
setq
a
1+
a
list
chr
1-
a
car
x
car
x
length
cdr
x
lst
setq
i
0
setq
lst
mapcar
lambda
x
list
setq
i
1+
i
car
x
strcat
"%%c"
rtos
cadr
x
2
#xd
var
global
bits
strcat
"Φ"
rtos
2
cadr
x
2
#xd
var
global
bits
rtos
2
pi
cadr
x
2
#xd
var
global
bits
rtos
pi
cadr
x
cadr
x
2
#xd
var
global
bits
last
x
lst
setq
lst
append
lst
list
list
"Sum"
nil
nil
rtos
apply
mapcar
lambda
x
atof
nth
4
x
lst
2
#xd
var
global
bits
rtos
apply
mapcar
lambda
x
atof
nth
5
x
lst
2
#xd
var
global
bits
apply
mapcar
lambda
x
nth
6
x
lst
setq
tb
XD::Table:MakeFromList
append
list
"Circle Statistics Table"
nil
nil
nil
nil
nil
nil
"Number"
"Coding"
"Radius"
"Diameter"
"Perimeter"
"Area"
"Quantity"
lst
0
0
0
#xd
var
global
table
textheight
#xd
var
global
table
textheight
3.0
xdrx_setpropertyvalue tb
"color"
7
xd::drag:simplemove
entlast
\n
>>Table insertion point:"
8
t
xdrx
sysvar
pop
xdrx
end
princ
Logged
https://github.com/xdcad
http://bbs.xdcad.net
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
XDRX-API
Topic:
