Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
XDRX-API
Topic:
[XDrX-PlugIn(30)] Modify MLeaer text Color
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [XDrX-PlugIn(30)] Modify MLeaer text Color (Read 949 times)
xdcad
Swamp Rat
WWW
on:
December 03, 2023, 08:31:53 AM »
Code - Auto/Visual Lisp:
[Select]
defun
c:tt
if
and
or
setq
clr
getint
\n
sEnter Color Index <select color>:"
setq
clr
xdrx
ui
getcolor
"Select Color"
1
setq
ss
xdrx
ssget
\n
Select The MLeader <Exit>:"
0
"m*leader"
progn
xdrx
begin
setq
nums
sslength
ss
xdrx
setpropertyvalue ss
"textcolor"
clr
xdrx
prompt
\n
Successfully Processing "
nums
"Mleader Leaderline."
xdrx
end
princ
Logged
https://github.com/xdcad
http://bbs.xdcad.net
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
XDRX-API
Topic:
