Author Topic: CURVE-TAKE-OUT-THE-INSIDE  (Read 1818 times)
domenicomaria
« on: November 28, 2023, 08:32:40 AM »
  1. (defun C:CURVE-TAKE-OUT-THE-INSIDE ( / en es i-ss int-lst offset-v-lst ss ss-en-lst v-lst )
  2.    (and
  3.       (setq es (xdrx-entsel "\nselect a 2d closed curve < exit> : ") )
  4.       (setq en (car es))
  5.       (setq v-lst (xdrx-curve-getsamplepoints en))
  6.
  7.       (setq offset-v-lst (xdrx-curve-getoffsetcurves en 0.15 t) )  ; 0.15 ???    T  ???
  8.       (entdel (entlast) )
  9.
  10.       (setq ss (ssget "f" v-lst) )
  11.       (setq ss (ssdel en ss) )
  12.       (setq ss-en-lst (xdrx-pickset->ents ss) )
  13.
  14.       (xdrx-begin)
  15.       (foreach x ss-en-lst
  16.          (if (setq int-lst (xdrx-entity-intersectwith x en) )
  17.              (xdrx-curve-getsplitcurves x int-lst)
  18.          )
  19.       )
  20.
  21.       (setq i-ss (ssget "wp" offset-v-lst) )
  22.       (setq i-ss (ssdel en i-ss) )
  23.       (setq i-ss (ssadd (xdrx-object-clone en) i-ss) )
  24.       (xd::drag:simplemove i-ss  "\nInsert Point:" 5 t)
  25.       (xdrx-end)
  26.    )
  27. )
  28.
  29.
  30. (defun C:XXX () (C:CURVE-TAKE-OUT-THE-INSIDE) )
If you can't see the video, please wait a while
https://drive.google.com/file/d/1S0oReQEMkufkboNnVd2_An5JfigWX7Z_/view?usp=sharing
xdcad
Re: CURVE-TAKE-OUT-THE-INSIDE
« Reply #1 on: November 28, 2023, 08:47:32 AM »
Can’t see the video and can’t download it
https://github.com/xdcad
http://bbs.xdcad.net
domenicomaria
« Reply #2 on: November 28, 2023, 08:52:37 AM »
Wait 1 hour
Is there a way to get only
the offset point list,
without xdrx-curve-getoffsetcurves
draws also an offset curve ?
Explain the arguments of xdrx-curve-getoffsetcurves ,
please.
« Last Edit: November 28, 2023, 08:59:01 AM by domenicomaria »
xdcad
« Reply #3 on: November 28, 2023, 08:56:29 AM »
  2.    (and
  3.
Is this what you want to do?
domenicomaria
« Reply #4 on: November 28, 2023, 09:00:22 AM »
Yes
More or less ...
xdcad
« Reply #5 on: November 28, 2023, 09:05:43 AM »
I have written two before
1. Cutting
2. Take Out
Can handle BLOCK
« Last Edit: November 28, 2023, 09:10:26 AM by xdcad »
domenicomaria
« Reply #6 on: November 28, 2023, 09:14:24 AM »
if you think my post is superfluous, delete it... don't worry...
xdcad
« Reply #7 on: November 28, 2023, 09:38:26 AM »
Wait 1 hour
please.
The usage is written in this post.
http://www.theswamp.org/index.php?topic=58803.0
xdcad
« Reply #8 on: November 28, 2023, 09:42:36 AM »
 :smitten: :smitten:
No, you may have misunderstood, English is not my mother tongue
I didn’t see your video, so I guessed that you wanted to do this, so I posted a few animations.
I want to say that xdrx-curve-getsplitcurves may have more uses, such as processing the inside of block. I want to discuss it with you more.
I want to thank you for posting here and would be happy to see more in the future
xdcad
« Reply #9 on: November 28, 2023, 09:45:52 AM »
Wait 1 hour
please.
The point table (for multiple) is not returned normally when given the T parameter. I will check the code and modify it.
xdcad
« Reply #10 on: November 28, 2023, 09:51:12 AM »
Command: (xdrx-curve-offset1 (entlast) 100.0)
((6955.29 550.873 0.0) (7455.96 550.873 0.0) (7455.96 896.79 0.0))
You can use this first, it doesn’t have as many functions as xdrx-curve-offset
This xdrx-curve-offset1 is from the original manual
ribarm
  • Marko Ribar, architect
« Reply #11 on: November 28, 2023, 02:19:15 PM »
Isn't this behaviour similar to CLIPIT on blocks geometry... Are those lines all inside block? If that's so then XDRX is nothing special...
M.R. on Youtube
domenicomaria
« Reply #12 on: November 28, 2023, 03:16:58 PM »
XDRX has many functions, very powerful and special,
which allow VLisp users to do things that could not even be imagined before.
domenicomaria
xdcad
« Reply #14 on: November 28, 2023, 11:14:08 PM »
