Author Topic: xdrx-curve-join  (Read 1106 times)
domenicomaria
xdrx-curve-join
« on: November 23, 2023, 12:47:30 PM »
(defun C:J ()   (setq ss (ssget) ) (xdrx-curve-join ss) )
xdcad
Re: xdrx-curve-join
« Reply #1 on: November 25, 2023, 12:28:58 PM »
I haven't had any problems here
Upload the DWG in question and let me take a look.
[XDrx-Sub Forum]
https://www.theswamp.org/index.php?board=78.0
https://github.com/xdcad/XDrx-API
http://bbs.xdcad.net
domenicomaria
Re: xdrx-curve-join
« Reply #2 on: November 25, 2023, 01:39:15 PM »
The first time it works well.
After, you have to explode it,
and join it again using
The dwg is exactly the same.
No need to upload it again.
xdcad
Re: xdrx-curve-join
« Reply #3 on: November 25, 2023, 02:28:16 PM »
I haven't reproduced the problem you encountered here.
It may still have something to do with the type of object you are operating on.
Upload the DWG and take a look
« Last Edit: November 25, 2023, 03:48:25 PM by xdcad »
[XDrx-Sub Forum]
domenicomaria
Re: xdrx-curve-join
« Reply #4 on: November 26, 2023, 04:17:50 AM »
... the dwg is always the same ...
ask someone else to test the dwg with this function
domenicomaria
Re: xdrx-curve-join
« Reply #5 on: November 26, 2023, 04:24:20 AM »
again !
allways !
xdcad
Re: xdrx-curve-join
« Reply #6 on: November 26, 2023, 12:01:41 PM »
thanks...
Found the reason,
At the location marked below in your picture, after re-exploding, there will be an extra LINE with a length of 0. This is caused by it.
In the next version, the API will be corrected to handle the case where the length is 0.
[XDrx-Sub Forum]
domenicomaria
Re: xdrx-curve-join
« Reply #7 on: November 26, 2023, 12:49:26 PM »
Well !
xdcad
Re: xdrx-curve-join
« Reply #8 on: November 26, 2023, 02:26:25 PM »
Well !
Updated API, re-uploaded, try downloading
The xdrx-curve-join function is dedicated to batch processing of various curves line, *polyline, arc, ellipse, spline, circle....
Supports gap tolerance, overlap...
It is currently known that when there are some special arc combinations, the arcs may produce unwanted results. If you encounter such problems during testing, please post and upload the DWG. Thank you.
[XDrx-Sub Forum]
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: xdrx-curve-join
« Reply #9 on: November 26, 2023, 02:36:17 PM »
@xdczd,
very nice !
Called Kerry in my other life
I live at UTC + 13.00
