Author Topic: Can't clear my osnaps  (Read 2777 times)
bman
« on: July 12, 2005, 08:48:18 AM »
Why aren't my osnaps setting to 0 prior to executing the circle command?
(defun c:cr3 (/ oldsnap)
     (setq oldsnap (getvar "osmode"))
       (setvar "osmode" 0)
       (setvar "osmode" 256)
         (command "circle" "3p")
(setvar "osmode" oldsnap)
Re: Can't clear my osnaps
« Reply #1 on: July 12, 2005, 08:53:28 AM »
Quote from: bman
       (setvar "osmode" 0)
       (setvar "osmode" 0)
       (setvar "osmode" 256)   ;; <-----------
« Reply #2 on: July 12, 2005, 09:07:40 AM »
bman
I don't understand your routine?
It appears as though you want to exit the routine before picking the three points. Is that true?
If not you need to pause to allow the user to pick the points else the osnaps will be reset
when the leave the routine.
You would need this:
   (setvar "osmode" 0)
   (command "circle" "3p" pause pause pause)
Or this:
             "non" pause
             "non" pause
             "non" pause
« Reply #3 on: July 12, 2005, 09:17:06 AM »
I was thinking more along these lines....
    (setvar "osmode" 0)
    (command "circle" "3p" pause)
    (while
      (< 0 (getvar "CMDACTIVE"))
       (command pause)
bman
« Reply #4 on: July 12, 2005, 10:01:45 AM »
I was trying to set the osmode to 0 & then to 256 prior to the circle command
This seems to work well
   (setvar "osmode" 0)
   (prompt "\nSelect first tangent point: ")
CADaver
« Reply #5 on: July 12, 2005, 12:18:05 PM »
There is no need to set OSMODE to 0 prior to setting it to 256.
daron
« Reply #6 on: July 12, 2005, 01:45:38 PM »
As well, there's probably no reason to set it to anything except maybe zero as osmode's can all be overridden and if the user misses or snaps to the wrong point, he may have to escape & restart the routine.
