Author Topic: Bricscad parametric block - Set parameter value  (Read 183 times)
Kralj_klokan
« on: November 04, 2023, 06:04:37 PM »
Hello there,
I 'm trying to get all possible values of a block parameter and also set the parameter value to one of them.
Is that possible in the Bricscad .NET API?
When I try doing this on AutoCAD I 'm just getting the dynamic block properties.
I found the Parameter.GetByName() method in the Bricscad.Parametric namespace but what I get from it is not really of any use.
Is there somebody who might have an idea?
Thank you.
Update:
I figured out how to set the paramater value:
        BlockParameter par = Utility.GetBlockParameter(per.ObjectId, "W");
         resValue = par.Value;
        expr = par.Expression;
         par.Expression = "100";
One thing I would like still is to have a list of all possible values you can have inside this parameter.
« Last Edit: November 05, 2023, 04:56:27 AM by Kralj_klokan »
