Author Topic: clean up the formatting of a MTEXT string  (Read 3850 times)
BIGAL
  • 40 + years of using Autocad
Re: clean up the formatting of a MTEXT string
« Reply #15 on: December 13, 2023, 05:27:26 PM »
My $0.05
Edit mtext replace "\n" with "-"
Strip mtext re Lee-mac
Parse to list "-" re Lee-mac. ie use 45 is "-"
; thanks to Lee-mac for this defun
;renamed to suit delimeter value in this case -
(defun csv->lst45  ( str / pos )
(if (setq pos (vl-string-position 45 str))
    (cons (substr str 1 pos) (csv->lst (substr str (+ pos 2))))
    (list str)
xdcad
« Reply #16 on: December 13, 2023, 06:55:31 PM »
  1. Command: (XD::MTEXT:UNFORMATSTRING (entlast))
  2. ("agafsg34" "fsfga" "ggggggg")
  3.
  1. (defun XD::Mtext:UnformatString (mtxt / data)
  2.   (defun groupbykey (lst / tmp out)
  3.     (setq
  4.       lst (vl-sort lst
  5.                    (function (lambda (x1 x2) (> (car x1) (car x2))))
  6.           )
  7.     ) ;_sort
  8.     (setq tmp (list (cdar lst) (caar lst))) ;_first
  9.     (foreach item (cdr lst)
  10.       (if (= (car item) (last tmp))
  11.         (setq tmp (cons (cdr item) tmp))
  12.         (setq out (cons (reverse tmp) out)
  13.               tmp (list (cdr item) (car item))
  14.         )
  15.       )
  16.     )
  17.     (cons (reverse tmp) out) ;_last
  18.   )
  19.   (if (setq data (xdrx-mtext-fragments mtxt))
  20.     (progn
  21.       (setq data (mapcar '(lambda (x)
  22.                              (list (cadr (cadr (assoc "kLocation" x)))
  23.                                    (car (cadr (assoc "kLocation" x)))
  24.                                    (cadr (assoc "kTextString" x))
  25.                              )
  26.                            )
  27.                           data
  28.                   )
  29.             data (reverse (groupbykey data))
  30.       )
  31.       (mapcar
  32.         '(lambda (x) (apply 'strcat x))
  33.           (mapcar '(lambda (x) (mapcar 'cadr x)) (mapcar 'cdr data))
  34.       )
  35.     )
  36.   )
  37. )
« Last Edit: December 13, 2023, 08:10:45 PM by xdcad »
https://github.com/xdcad
http://bbs.xdcad.net
It's Alive!
  • Retired
  • AKA Daniel
« Reply #17 on: December 13, 2023, 07:23:17 PM »
@xdcad
You can also add something like this as a utility to strip mtext formatting
Code - C++: [Select]
  1.         //.formatted string
  2.         AcValue acval(val);
  3.         acutPrintf(acval.format(AcValue::kIgnoreMtextFormat));
  4.
xdcad
« Reply #18 on: December 13, 2023, 08:11:58 PM »
@xdcad
  4.
Thank you, I'll try
xdcad
« Reply #19 on: December 13, 2023, 09:40:07 PM »
@xdcad
  4.
  1. Command: (setq a (xdrx-mtext-unformat a))
  2. "agafsg34\r\n\r\n\nfsfga\r\n\r\n\nggggggg"
  3. Command: (xdrx-string-regexps "[^\\r\\n]+" a)
  4. ("agafsg34" "fsfga" "gggggggg")
  1. int MTextUnformat()
  2. {
  3.         resbuf* rb = ads_getargs();
  4.         if (!rb)
  5.         {
  6.                 return RSRSLT;
  7.         }
  8.         AcDbObjectId id;
  9.         const TCHAR* str = NULL;
  10.         if (rb->restype == RTENAME)
  11.         {
  12.                 if (acdbGetObjectId(id, rb->resval.rlname) == eOk)
  13.                 {
  14.                         AcDbMText* pMtext;
  15.                         if (acdbOpenObject(pMtext, id, kForRead) == eOk)
  16.                         {
  17.                                 str = pMtext->contents();
  18.                                 pMtext->close();
  19.                         }
  20.                 }
  21.         }
  22.         else if (rb->restype == RTSTR)
  23.         {
  24.                 str = rb->resval.rstring;
  25.         }
  26.         else {
  27.                 return RSRSLT;
  28.         }
  29.         AcValue acval(str);
  30.         ads_retstr(acval.format(AcValue::kIgnoreMtextFormat));
  31.         return RSRSLT;
  32. }
« Reply #20 on: December 14, 2023, 09:57:20 AM »
@xdcad
While passing by I noticed your function and had a few quick questions.
  1. int MTextUnformat() {                                   // Add function header!!
  2.         // MTextUnformat
  3.         // Unformats a text string. ...
  4.         //
  5.         // ARGS:
  6.         //
  7.         // RETURNS:
  8.         resbuf* rb = ads_getargs();
  9.         if (!rb) {
  10.                 return RSRSLT;
  11.         }
  12.         AcDbObjectId id;
  13.         const TCHAR* str = NULL;
  14.         if (rb->restype == RTENAME) {                   // Should you consider
  15.                                                         // a separate function
  16.                                                         // to replace nested
  17.                                                         // if's below?
  18.                 if (acdbGetObjectId(id, rb->resval.rlname) == eOk) {
  19.                         AcDbMText* pMtext;
  20.                         if (acdbOpenObject(pMtext, id, kForRead) == eOk) {
  21.                                 str = pMtext->contents();
  22.                                 pMtext->close();
  23.                         }
  24.                 }
  25.         }
  26.         else if (rb->restype == RTSTR) {                // Should this be IF?
  27.                 str = rb->resval.rstring;
  28.         }
  29.         else {                                          // Is this ELSE needed? -i.e. checked already.
  30.                 return RSRSLT;
  31.         }
  32.         AcValue acval(str);
  33.         ads_retstr(acval.format(AcValue::kIgnoreMtextFormat));
  34.         return RSRSLT;
  35. }
  36.
dwaschnia
  • Mosquito
« Reply #21 on: December 14, 2023, 10:53:29 AM »
low iq version :)
  1. (defun c:uform ( / l len en start i ss x )
  2.   (setq len (entlast))
  3.   (setq en (car (entsel)))
  4.   (command "_copybase" "_non" "0,0" en "")
  5.   (command "_pasteclip" "_non" "0,0")
  6.   (command "_explode" (entlast))
  7.   (setq start (entnext len))
  8.         (setq ss (ssadd))
  9.         (while start
  10.                 (setq ss (ssadd start ss))
  11.                 (setq start (entnext start))
  12.         )
  13.   (repeat (setq i (sslength ss))
  14.     (setq l (append l (list "\\P")))
  15.     (setq l (append l (list (vla-get-textstring (setq x (vlax-ename->vla-object (ssname ss (setq i (1- i)))))))))
  16.     (vla-delete x)
  17.   )
  18.   (vla-put-textstring (vlax-ename->vla-object en) (apply 'strcat (reverse (cdr l))))
  19. )
xdcad
« Reply #22 on: December 14, 2023, 06:43:08 PM »
@xdcad
  2.         // MTextUnformat
  4.         //
  5.         // ARGS:
  6.         //
  7.         // RETURNS:
  9.         if (!rb) {
  10.                 return RSRSLT;
  11.         }
  17.                                                         // if's below?
  23.                         }
  24.                 }
  25.         }
  28.         }
  30.                 return RSRSLT;
  31.         }
  34.         return RSRSLT;
  35. }
  36.
  1. else if (rb->restype == RTSTR) {                // Should this be IF?
  2.                 str = rb->resval.rstring;
  3.         }
Supports two types of parameters, one is the MTEXT entity name, and the other is a formatted string
  1. else {                                          // Is this ELSE needed? -i.e. checked already.
  2.                 return RSRSLT;
  3.         }
If it is not an entity name or a string, other parameters given to the function will not be processed and will exit directly.
« Last Edit: December 14, 2023, 06:48:27 PM by xdcad »
xdcad
« Reply #23 on: December 14, 2023, 06:58:45 PM »
  2. {
  3.         //param:
  4.         // 1:mtext entity name
  5.         // or
  6.         // 2:formatted string
  7.         // t or nil: t return list,
  8.         //           nil return unformatted string
  9.         resbuf* rb = ads_getargs();
  10.         if (!rb)
  11.         {
  12.                 return RSRSLT;
  13.         }
  14.         AcDbObjectId id;
  15.         const TCHAR* str = NULL;
  16.         bool bRetList = true;
  17.         if (rb->restype == RTENAME)
  18.         {
  19.                 if (acdbGetObjectId(id, rb->resval.rlname) == eOk)
  20.                 {
  21.                         AcDbMText* pMtext;
  22.                         if (acdbOpenObject(pMtext, id, kForRead) == eOk)
  23.                         {
  24.                                 str = pMtext->contents();
  25.                                 pMtext->close();
  26.                         }
  27.                 }
  28.                 else {
  29.                         return RSRSLT;
  30.                 }
  31.         }
  32.         else if (rb->restype == RTSTR)
  33.         {
  34.                 str = rb->resval.rstring;
  35.         }
  36.         else {
  37.                 return RSRSLT;
  38.         }
  39.         rb = rb->rbnext;
  40.         if (rb && rb->restype == RTT)
  41.         {
  42.                 bRetList = false;
  43.         }
  44.
  45.         AcValue acval(str);
  46.         const TCHAR *str1 = acval.format(AcValue::kIgnoreMtextFormat);
  47.         if (bRetList)
  48.         {
  49.                 XdRbList strArr1;
  50.                 if (XdGeUtils::XDRegExpS(str1, _T("[^\r\n]+"), strArr1, 14, true, true))
  51.                 {
  52.                         strArr1.toLisp(0, 1);
  53.                 }
  54.         }
  55.         else {
  56.                 ads_retstr(str1);
  57.         }
  58.         return RSRSLT;
  59. }
  60.
  1. Command: !str
  2. "a{\\fMS UI Gothic|b1|i1|c0|p34;\\C32;\\c2648525;gaf}sg34\\Pfsf{\\L\\Oga\\P}ggggggg"
  3. Command: (xdrx-mtext-unformat str)
  4. ("agafsg34" "fsfga" "ggggggg")
  5. Command: (xdrx-mtext-unformat str t)
  6. "agafsg34\r\n\r\n\nfsfga\r\n\r\n\nggggggg"
  7.
  8. Command: (xdrx-mtext-unformat (car (entsel)))
  9. Select object: ("agafsg34" "fsfga" "ggggggg")
  10.
  11. Command: (xdrx-mtext-unformat (car (entsel)) t)
  12. Select object: "agafsg34\r\n\r\n\nfsfga\r\n\r\n\nggggggg"
  13.
« Reply #24 on: December 14, 2023, 08:15:39 PM »
  3.         }
  2.                 return RSRSLT;
  3.         }
You and I have very different coding styles. I was only trying to point out that most times you can eliminate the if-else-ifelse construct. Most of my code looks like this (I make a lot of small single use functions which preform specific things). I cannot keep all those nested if statements straight, myself.
  1. //-------------------------------------------------------------------
  2. // process_path
  3. // This function will decide whether a file is a regular file or a
  4. // directory and pass it to the proper function for handling.
  5. //
  6. // ARGS
  7. //  char* directory     :   Path of a file
  8. //
  9. // RETURN
  10. // void
  11. //-------------------------------------------------------------------
  12. void process_path(char *path) {
  13.   /* Process files as files, directories as directories, and skip
  14.    * everything else. */
  15.   struct stat sbuf;
  16.   if (stat(path, &sbuf)) {
  17.     perror("Failed to open directory");
  18.     return;
  19.   }
  20.   if (S_ISREG(sbuf.st_mode)) {
  21.     process_file(path);
  22.   }
  23.   if (S_ISDIR(sbuf.st_mode)) {
  24.     process_directory(path);
  25.   }
  26. }
It's Alive!
  • Retired
  • AKA Daniel
« Reply #25 on: December 14, 2023, 10:30:02 PM »
From a performance perspective,
if , else if , else may be faster because the compiler can build a jump table instead of having a bunch of branches
It’s not so pretty from a code readability perspective. I tend to use a switch statement for checking ints, it’s fast and its pretty.
I would use a smart pointer for AcDbMText
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #26 on: December 14, 2023, 10:50:47 PM »
Quote from:  Dan
Is it possible that a lot of this code was generated before smart pointers were available ??
[added]
. . . and the code base is probably used for multiple acad versions
[/added]
Would this be a case of "it's not broken so don't fix it" ?
or are there discernable advantages ?
« Last Edit: December 14, 2023, 11:14:39 PM by kdub_nz »
Called Kerry in my other life
I live at UTC + 13.00
xdcad
« Reply #27 on: December 15, 2023, 12:02:24 AM »
Quote from:  Dan
[added]
[/added]
yes, autocad 2004-2024
vc7-vs2022
It's Alive!
  • Retired
  • AKA Daniel
« Reply #28 on: December 15, 2023, 02:06:03 AM »
Quote from:  Dan
[added]
[/added]
Good questions
I don’t know when AcDbObjectPointer was added to ARX. I’m guessing that it’s been in forever.
If it’s not in ARX2000, it’s just a header…
  1. AcDbObjectPointer<AcDbMText> pMtext (id, AcDb::kForRead);
This line tells the reader:
A, the pointer is guaranteed to be an object derived from AcDbMText.
B, that the object is guaranteed to be closed, even if there’s an exception.
This is a newly created function, you’re in the code, might as well improve it
Of course, it’s not my project, just my opinion
kdub_nz
  • SuperMod
« Reply #29 on: December 15, 2023, 02:51:23 AM »
ahh, yes good point.
wait, wouldn't one of the old compliers spit the dummy ??
