Author Topic: create zip windows 11  (Read 2446 times)
dgpuertas
« on: October 15, 2023, 02:29:42 PM »
I need to create a zip file for any files no create only one file.
I used (setq fso (vlax-create-object "Scripting.FileSystemObject")) to doit
But in windows 11 is not running. (i thinks so)
I try to use PowerShell with this command
(startapp "powershell.exe" (strcat "-Command Compress-Archive -path " filename " -Update -DestinationPath "fileZIP " -CompressionLevel Fastest"))
But in any computers does not run. I think that is the Execution police is restricted
But command Set-ExecutionPolicy -ExecutionPolicy Unrestricted -Scope CurrentUser
I try to create a ps1 file whit instructions but PowerShell said
No se puede cargar el archivo ps1 porque la ejecuci󮠤e scripts está deshabilitada en este sistema. Para obtener más informaci󮬠consulta el tema
about_Execution_Policies en https:/go.microsoft.com/fwlink/?LinkID=135170.
    + CategoryInfo          : SecurityError: (:) [], ParentContainsErrorRecordException
    + FullyQualifiedErrorId : UnauthorizedAccess
Anyone knows a simple version to create zip file.
The command must be executed in three party computer.  I wouldn't like to force you to install 7zip or any other software
BIGAL
  • 40 + years of using Autocad
Re: create zip windows 11
« Reply #1 on: October 15, 2023, 07:45:30 PM »
This is unzip to a directory, note the single quote  ' '" may be what you want.
(vl-mkdir "c:\\CAD-TOOLS")
(setq filename (getfiled "Select the File \"Cad tools 12-09-2023\"" "" "ZIP" 16))
; unzip
(startapp (strcat "powershell -command Expand-Archive -Path '" filename "' -DestinationPath 'C:/CAD-TOOLS' -FORCE"))
(alert "programs unzipped to C:/VFT-CAD-TOOLS")
dgpuertas
« Reply #2 on: October 16, 2023, 06:48:32 AM »
Thanks Bigal,
Its de opposite task, varius files convert into a one zip (and delete the files)
PowerShell i dont know if it works because the Execution police is restricted
kozmos
« Reply #3 on: October 16, 2023, 10:26:43 AM »
My code using Shell.application is still working under Windows 11, maybe you can give it a try.
  1. (Defun vldcl-EmptyZIP (fnn / VAL)
  2.   (and (or fnn (setq fnn (strcat (vl-filename-mktemp) ".zip")))
  3.        (setq val (open fnn "w"))
  4.        (progn
  5.          (foreach abc '(80 75 5 6) (write-char abc val))
  6.          (repeat 18 (write-char 256 val))
  7.          (close val)
  8.        )
  9.   )
  10.   (findfile fnn)
  11. )
  12. ;;; SRC CAN BE FOLDER/FILE OR FOLDERLIST/FILELIST OR MIXED
  13. (Defun vldcl-AddToZIP (src fnn / VLO ZIP)
  14.   (and (= (type src) 'str) (setq src (list src)))
  15.   (and (or (findfile fnn) (setq fnn (vldcl-EmptyZIP fnn)))
  16.        (setq vlo (vlax-create-object "Shell.Application")
  17.              zip (vlax-invoke vlo "NameSpace" fnn)
  18.        )
  19.        (progn
  20.          (foreach abc src
  21.            (and (setq abc (cond ((vl-file-directory-p abc)
  22.                                  (vlax-invoke vlo "NameSpace" abc)
  23.                                 )
  24.                                 ((findfile abc))
  25.                           )
  26.                 )
  27.                 (vlax-invoke zip "CopyHere" abc)
  28.            )
  29.          )
  30.          (vlax-release-object zip)
  31.          (vlax-release-object vlo)
  32.        )
  33.   )
  34.   (findfile fnn)
  35. )
  36.
Unzip code can be found @ http://www.theswamp.org/index.php?topic=58631.0
« Last Edit: October 16, 2023, 11:12:28 AM by kozmos »
KozMos Inc.
dgpuertas
« Reply #4 on: October 17, 2023, 08:22:38 AM »
Thanks a lot,
Ill try.
BIGAL
« Reply #5 on: October 17, 2023, 08:26:51 PM »
My $0.05 2 lines note the use of single quote as stated earlier.
(setq filename "D:/acadtemp/*.lsp" filezip "D:/acadtemp/lispzip.zip")
(startapp (strcat "powershell -Command Compress-Archive -path '" filename "' -Update -DestinationPath '" fileZIP "' -CompressionLevel Fastest"))
dgpuertas
« Reply #6 on: October 18, 2023, 12:38:02 PM »
Thaks Bigal
Another question
if I need to zip diferent files how do it?
Example:
File1.ddy  file1.da1   file1.par
All in the same Folder.
into file1.zip
and rename to
File1.mex
Thanks again
kozmos
« Reply #7 on: October 18, 2023, 11:07:36 PM »
Thaks Bigal
Another question
Example:
into file1.zip
and rename to
File1.mex
Thanks again
Very easy task using my code, just one line.
If the files are in "d:\\dir":
(vldcl-AddToZIP (list "d:\\dir\\File1.ddy" "d:\\dir\\file1.da1" "d:\\dir\\file1.par") "d:\\File1.zip")
If  "d:\\dir" only has these files and you want to zip the folder:
(vldcl-AddToZIP "d:\\dir"  "d:\\File1.zip")
If the files/folder are big, you may need to wait for a few seconds before renaming the zip file.
« Last Edit: October 19, 2023, 05:18:48 AM by kozmos »
KozMos Inc.
dgpuertas
« Reply #8 on: October 19, 2023, 09:54:36 AM »
Hi Kosmos,
Thanks a lot. For me vldcl-AddToZIP works fine.
But other colegues said that it not work in their computers, and i dont know why.
For this reason i want to try other method by PowerShell.
Thanks again Kosmos, for me is useful
57gmc
« Reply #9 on: October 19, 2023, 10:20:35 AM »
Have you added the vldcl-AssToZip function to the other pc's?
dgpuertas
« Reply #10 on: October 23, 2023, 10:25:37 AM »
Hi kosmos,
yes, i create a .fas file with all funcions.
Create a empty zip file but i dont know why.
In my computer works fine.
kozmos
« Reply #11 on: October 23, 2023, 10:58:34 AM »
Hi kosmos,
It seemed the empty ZIP is created. If you can directly drag files into the empty ZIP file, the program should also be able to do it. However, I will suggest you to test the source code on the not-working PC to find out which line of code failed.
« Last Edit: October 23, 2023, 11:11:44 AM by kozmos »
KozMos Inc.
BIGAL
« Reply #12 on: October 23, 2023, 08:10:05 PM »
Had another go with 2 files. Hope this makes sense.
(setq filename (strcat (chr 39) "D:/acadtemp/test.lsp" (chr 39) ", " (chr 39) "D:/acadtemp/mypdfs.scr" (chr 39)) filezip "D:/acadtemp/lispzip.zip")
(setq fo (open (setq fname "D:\\acadtemp\\alan.bat") "w"))
(write-line (strcat "powershell -Command Compress-Archive -path " filename " -Update -DestinationPath '" fileZIP "' -CompressionLevel Fastest") fo)
(close fo)
(startapp "D:\\acadtemp\\alan.bat")
