Using Vl is probably easiest as look at 2 properties
; Linetype = "DASHED"
; LinetypeScale = 2.5
You can change both of these, you can also get the length of an object just be aware for a Circle it is "Cicumference" others "length" should work.
(setq obj (vlax-ename->vla-object (car (entsel "Pick obj"))))
(setq lt (vlax-get obj 'Linetype))
(setq sc (vlax-get obj 'LinetypeScale))
(if (= (vlax-get obj 'Objectname) "AcDbCircle")
(setq len (vlax-get obj 'Circumference))
(setq len (vlax-get obj 'Length))
; do your thing here use PUT to change value
if i use this to setting , must be set many cond. have else better code?
(cond ((and (> len 0) (<= len 2))
(setq leg 2)
((and (> len 2) (<= len 5))
(setq leg 2.5)
((and (> len 5) (<= len 50))
(setq leg 4)
((and (> len 50) (<= len 120))
(setq leg 15)
((and (> len 120) (<= len 1000))
(setq leg 20)
((and (> len 1000) (<= len 1500))
(setq leg 40)
((and (> len 1500) (<= len 2500))
(setq leg 80)
) ;end cond
(setq sca (/ leg scale lts 10))
(command "change" nam "" "p" "s" SCA "")
lts is ltscale.
scale is setting numerical value by myself.
use repeat to change ltscale.
different linetype and linetype 2 or X2 must be use different setting.
and if the drawing had linetype ,how to know it is inch or mm?
This will also affect ltscale too.
