Author Topic: hepl : Search duplicate text, change color  (Read 4670 times)
mhy3sx
Re: hepl : Search duplicate text, change color
« Reply #15 on: September 28, 2023, 10:57:51 AM »
I try this
  1. (defun C:TFD (/ *error* doc mss n tc tclist duplist tcss); = Text [& Mtext] Find Duplicates
  2.       (defun *error* (errmsg)
  3.         (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
  4.           (princ (strcat "\nError: " errmsg))
  5.         ); if
  6.         (setvar cmdecho 1)
  7.         (vla-endundomark doc)
  8.         (princ)
  9.       ); defun - *error*
  10.     ;;;     (if (setq mss (ssget "_X" (list '(0 . "*TEXT") '(8 . "PST")(cons 410 (getvar 'ctab)))))
  11.         (if (setq mss  (ssget "_X" '((0 . "*TEXT") (8 . "PST") (1 . "#####[~.][~.]#####") (cons 410 (getvar 'ctab)))))
  12.          (progn ; then
  13.           (setvar 'cmdecho 0)
  14.           (setq TFDss (ssadd)); initially empty duplicates selection set
  15.           (repeat (setq n (sslength mss))
  16.             (setq tc (cdr (assoc 1 (entget (ssname mss (setq n (1- n)))))))
  17.               ; = text content of each
  18.             (cond
  19.               ((member tc duplist))
  20.                 ; = already in duplicates list [do nothing]
  21.               ((member tc tclist) (setq duplist (cons tc duplist)))
  22.                 ; = already in content list [put in duplicates list]
  23.               ((setq tclist (cons tc tclist)))
  24.                 ; = first instance of it [put in content list]
  25.             ); cond
  26.           ); repeat
  27.
  28.
  29.           (setq col 0); base value for counting color numbers upward
  30.
  31.           (foreach tc duplist ; assign colors to sets of duplicates
  32.     ;;;     (setq tcss (ssget "_X" (list '(0 . "*TEXT")'(8 . "PST") (cons 1 tc))))
  33.             (setq tcss (ssget "_X" '((0 . "*TEXT") (8 . "PST") (1 . "#####[~.][~.]#####") (cons 1 tc))))
  34.     ;;;     (command "_.layer" "_make" "Text" "_color" 7 "" "")
  35.     ;;;     (command "_.chprop" tcss "" "_color" (setq col (1+ col)) "")
  36.     ;;;     (command "_.chprop"  tcss "" "_layer" "Text" "")
  37.             (command "_.chprop" tcss "" "_color" 230 "")
  38.             (repeat (setq n (sslength tcss)) (ssadd (ssname tcss (setq n (1- n))) TFDss))
  39.               ; put in collective duplicates selection set
  40.           ); foreach
  41.           (setvar 'cmdecho 1)
  42.           (if (> (sslength TFDss) 0)
  43.             (sssetfirst nil TFDss); select/grip/highlight
  44.             (prompt "\nNo Text/Mtext objects with duplicate text content found."); else
  45.           ); if
  46.         ); progn
  47.       ); if
  48.       (vla-endundomark doc)
  49.       (princ)
  50.     ); end defun
  51.
  52.
  53.
and gives me this error
Error: bad SSGET listbad argument type: (or stringp symbolp): nil
CAn any one fix it ?
danAllen
« Reply #16 on: September 28, 2023, 11:04:31 AM »
Change the quote ' symbols to list. Quotes won't allow you to use cons with a variable
mhy3sx
« Reply #17 on: September 28, 2023, 03:49:27 PM »
I did the change
  5.             ); if
  8.             (princ)
  11.             (if (setq mss  (ssget "_X" (list (0 . "*TEXT") (8 . "PST") (1 . "#####[~.][~.]#####") (cons 410 (getvar 'ctab)))))
  12.              (progn ; then
  18.                 (cond
  25.                 ); cond
  26.               ); repeat
  27.
  28.
  30.
  33.                 (setq tcss (ssget "_X" (list (0 . "*TEXT") (8 . "PST") (1 . "#####[~.][~.]#####") (cons 1 tc))))
  40.               ); foreach
  45.               ); if
  46.             ); progn
  47.           ); if
  49.           (princ)
  50.         ); end defun
  51.
  52.
and gives me this error now
; error: bad argument type: consp "*TEXT"
how to fix it?
thanks
« Reply #18 on: September 28, 2023, 03:51:15 PM »
  1. ;; change this
  2. (setq mss  (ssget "_X" (list (0 . "*TEXT") (8 . "PST") (1 . "#####[~.][~.]#####") (cons 410 (getvar 'ctab)))))
  3. ;; to this
  4. (setq mss  (ssget "_X" (list '(0 . "*TEXT") '(8 . "PST") '(1 . "#####[~.][~.]#####") (cons 410 (getvar 'ctab)))))
BIGAL
  • 40 + years of using Autocad
« Reply #19 on: September 28, 2023, 09:01:16 PM »
Like Ronjonp I find sometimes rather than mix and match use 1 method. I am a bit old school
(setq mss  (ssget "_X" (list (cons 0 "*TEXT") (cons 8  "PST") (cons 1  "#####[~.][~.]#####") (cons 410 (getvar 'ctab)))))
danAllen
« Reply #20 on: September 29, 2023, 12:10:22 AM »
after beating my head figuring out the ' vs cons problem, I just use cons & list now to be safe. And I still double quote getvars
  1. (setq mss  (ssget "_X" (list (cons 0 "*TEXT") (cons 8  "PST") (cons 1  "#####[~.][~.]#####") (cons 410 (getvar "ctab")))))
« Reply #21 on: September 29, 2023, 03:41:14 AM »
Perhaps this can help?
danAllen
« Reply #22 on: September 29, 2023, 11:07:35 AM »
Lee - thanks for that reference. I think my past challenge resulted from most sources of ssget filters use of (' / apostrophe / single quote) instead of list. And then if cons is substituted to use a variable in the filter, the ' must be replaced with list, which is not intuitive. For my own programming I think it is better to limit use of ' for easier substitution of variables (that get evaluated) instead of constants.
mhy3sx
« Reply #23 on: October 09, 2023, 03:44:28 AM »
I have to explain again what I am looking for.
I don't want to select all the text in the layer.
I have two types of text. The form of the text is like   061676614011 (12 numbers) or something like this 06167AG01949. The numbers are changing but the text AG if exist in the text is all the time the same and in the same possition (in the midle of the text).
I already have a code that select all the duplicate text in the drawing (from PST layer) and change color.
I want an extra check for this texts in PST Layer, and the check is
To search if in this layer exist a text with problem in spelling. If a text is not like  061676614011 (12 numbers) or something like this 06167AG01949 , is something alse for example
06167661401G , 06167AK01949, O6167AG01949, D6167AG01949 etc  the select and this spesific text and change the color to this text .
  5.         ); if
  8.         (princ)
  10.          (if (setq mss (ssget "_X" (list '(0 . "*TEXT") '(8 . "PST")(cons 410 (getvar 'ctab)))))
  11.          (progn ; then
  12.           (setvar 'cmdecho 0)
  13.           (setq TFDss (ssadd)); initially empty duplicates selection set
  14.           (repeat (setq n (sslength mss))
  15.             (setq tc (cdr (assoc 1 (entget (ssname mss (setq n (1- n)))))))
  16.               ; = text content of each
  17.             (cond
  18.               ((member tc duplist))
  19.                 ; = already in duplicates list [do nothing]
  20.               ((member tc tclist) (setq duplist (cons tc duplist)))
  21.                 ; = already in content list [put in duplicates list]
  22.               ((setq tclist (cons tc tclist)))
  23.                 ; = first instance of it [put in content list]
  24.             ); cond
  25.           ); repeat
  26.
  27.
  28.           (setq col 0); base value for counting color numbers upward
  29.
  30.           (foreach tc duplist ; assign colors to sets of duplicates
  31.            (setq tcss (ssget "_X" (list '(0 . "*TEXT")'(8 . "PST") (cons 1 tc))))
  32.     ;;;     (command "_.layer" "_make" "Text" "_color" 7 "" "")
  33.     ;;;     (command "_.chprop" tcss "" "_color" (setq col (1+ col)) "")
  34.     ;;;     (command "_.chprop"  tcss "" "_layer" "Text" "")
  35.             (command "_.chprop" tcss "" "_color" 230 "")
  36.             (repeat (setq n (sslength tcss)) (ssadd (ssname tcss (setq n (1- n))) TFDss))
  37.               ; put in collective duplicates selection set
  38.           ); foreach
  39.           (setvar 'cmdecho 1)
  40.           (if (> (sslength TFDss) 0)
  41.             (sssetfirst nil TFDss); select/grip/highlight
  42.             (prompt "\nNo Text/Mtext objects with duplicate text content found."); else
  43.           ); if
  44.         ); progn
  45.       ); if
  46.       (vla-endundomark doc)
  47.       (princ)
  48.     ); end defun
  49.
  50.
  51.
