Author Topic: Insert block without opening drawing file.  (Read 1468 times)
vincent.r
« on: August 25, 2023, 08:11:12 AM »
I trying to insert a block & explode it, without opening the drawing. I am using Lee Mac's ODBX Wrapper. Modified as -
  1. (defun c:test1 (/)
  2.   (LM:ODBX
  3.     (function
  4.       (lambda (doc)
  5.                 (vla-insertblock
  6.                   (vla-get-modelspace
  7.                     (vla-get-activedocument (vlax-get-acad-object)))
  8.                   (vlax-3d-point '(0 0 0))
  9.                   "C:\\Users\\vincent.r\\Desktop\\blocks\\REVERSIBLE.dwg"
  10.                   1
  11.                   1
  12.                   1
  13.                   0
  14.                 )
  15.       )
  16.     )
  17.     nil
  18.     t
  19.   )
  20.   (princ)
  21. )
It's not working & returning message - Duplicate definition of block THV  ignored.
Duplicate definition of block MAINS_CONNECTION  ignored.
I am okay by keeping block inside the drawing (not purged) and insert it.
Anybody knows, how to get it done? Drawing file and block attached.
Thanks in advance.
Vincent
EDIT (John): Added code tags.
« Last Edit: August 25, 2023, 11:19:05 AM by JohnK »
Re: Insert block without opening drawing file.
« Reply #1 on: August 25, 2023, 09:34:36 AM »
You are invoking the insertblock method on the activedocument object (i.e. the current drawing), not the ODBX document.
Change:
To:
  1. doc
Though, if I recall correctly, you may need to access the layout container block via the layouts collection (then vla-get-block) or blocks collection.
ribarm
  • Marko Ribar, architect
« Reply #2 on: August 25, 2023, 11:56:19 AM »
You mean this, Lee...
  2.       (LM:ODBX
  3.         (function
  4.           (lambda (doc)
  5.                     (vla-insertblock
  6.                       (vla-get-block
  7.                         (vla-get-activelayout doc))
  10.                       1
  11.                       1
  12.                       1
  13.                       0
  14.                     )
  15.           )
  16.         )
  17.         nil
  18.         t
  19.       )
  20.       (princ)
  21.     )
  22.
M.R. on Youtube
« Reply #3 on: August 25, 2023, 12:04:43 PM »
The activelayout may not necessarily correspond to Modelspace.
vincent.r
« Reply #4 on: August 25, 2023, 01:30:37 PM »
  2.       (LM:ODBX
  3.         (function
  4.           (lambda (doc)
  5.                     (vla-insertblock
  6.                       (vla-get-block
  10.                       1
  11.                       1
  12.                       1
  13.                       0
  14.                     )
  15.           )
  16.         )
  17.         nil
  18.         t
  19.       )
  20.       (princ)
  21.     )
  22.
Thanks Ribarm. Instead of full path & the blockname I just mentioned the block name "REVERSIBLE". It works great.
vincent.r
« Reply #5 on: August 25, 2023, 01:49:18 PM »
Change:
To:
  1. doc
Thanks Lee. Now I am able to insert block in unopened drawing. but not able get just inserted or last inserted block. I want to set visibility to it.
Earlier block is now a dynamic block. Block named "REVERSIBLE" is in the attached drawing.
Any help on set visibility will be much appreciated.
« Last Edit: August 25, 2023, 01:54:34 PM by vincent.r »
« Reply #6 on: August 25, 2023, 07:46:25 PM »
Change:
To:
  1. doc
The vla-insertblock method will return the inserted block reference object.
vincent.r
« Reply #7 on: August 26, 2023, 04:12:12 AM »
Change:
To:
  1. doc
Thanks Lee. I will work on it & let you know the results.
