Hello,
I didn't fully grasp the question where you mention "deviendront alors désynchronisées" (will become desynchronized).
The Lisp program RENAMETAG is designed to modify attribute label names. When I execute this program, it first asks me for the old label name, for example, "XXXXXXXXXXXXXX". Then, it prompts me for the new label name, which I choose to be "DESIGNATION". After that, I select all the relevant blocks, and the program replaces all the labels. However, the issue lies in the fact that I need to repeat this process multiple times, once for each label. For instance, if I have 4 labels, I need to repeat the process 4 times. If there are 3 labels, then I need to do it 3 times, and so on.
The goal is to be able to replace the label names with their new names simultaneously in a single operation.
