Author Topic: Public wrapping for 'Internal' SDK namespaces  (Read 2777 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« on: August 14, 2023, 08:48:24 PM »
Does anyone have any wishlists for making Classes/Methods  that are currently in 'Internal' namespaces public and officially fit for consumption. ??
Any requests will be passed on, but no promises regarding action.
Regards,
Called Kerry in my other life
I live at UTC + 13.00
kdub_nz
  • SuperMod
Re: Public wrapping for 'Internal' SDK namespaces
« Reply #1 on: August 14, 2023, 08:49:01 PM »
Regards,
All ? , but seriously . . .
BlackBox
Hanauer
  • Mosquito
« Reply #3 on: August 23, 2023, 07:43:24 AM »
I have avoided using Autodesk.AutoCAD.Internal as much as possible since you never know if it will still be available in future updates, but there are situations where there are no alternatives, such as the case of AcAeUtilities.IsInBlockEditor() and AcAeUtilities.GetBlockName().
What I have seen most used:
Autodesk.AutoCAD.Internal.Utils.EntLast()
Autodesk.AutoCAD.Internal.Utils.WcMatch(string, string)
Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView()
Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt()
Autodesk.AutoCAD.Internal.Utils.GetBlockImage()
Autodesk.AutoCAD.Internal.Utils.VpMaxCommand()
Autodesk.AutoCAD.Internal.AcAeUtilities.IsInBlockEditor()
Autodesk.AutoCAD.Internal.AcAeUtilities.GetBlockName()
« Last Edit: August 23, 2023, 07:48:37 AM by Hanauer »
BlackBox
« Reply #4 on: August 23, 2023, 09:50:18 AM »
Those are good ones.
Don't recall when, but sometime after Core Console was introduced, I know that Autodesk.AutoCAD.Internal.Utils.WcMatch() was moved to Autodesk.AutoCAD.Internal.CoreUtils.WcMatch().
Autodesk also deprecated Autodesk.AutoCAD.Internal.Utils.GetAcadResourceIcon(), when they should have enhanced it - originally it searched Acad CUI for resource icons only, and completely ignored vertical-specific icons, so I ended up having to write an extension method that iterates whatever Main & Enterprise CUI were, but don't think I ever finished it to also iterate any attached partials - would love it if Autodesk would do so in ARX.
« Reply #5 on: August 23, 2023, 11:27:09 AM »
Autodesk.AutoCAD.Internal.ObjectContexts : for adding Annotative scale to Objects
Autodesk.AutoCAD.Internal.RegenEntity()
Autodesk.AutoCAD.Internal.GetCommandAtLevelForDocument() : useful when creating a Transparent command, can notify user it must be called from within a running command.
kdub_nz
  • SuperMod
« Reply #6 on: August 23, 2023, 10:16:49 PM »
Thanks guys.
Passed them on.
Any more from anyone ??
