Daron, *lol* Yeah I do that too.
But, that code I posted was just a stupid example. Its not very efficient, I was just trying to make a point with that code. The point being that the task can be solved about a million diff ways but if you write down what you want to do; you can code the solution almost the same way as you wrote it down.
For instance: Take what our friend "StarGazer" wrote in the request.
> What I want it to do is grab the first item in the just dump it into a
> list as the first element. Then reading the next line in I want to
> compare it to the list to see if it's the same, if it is then just
> skip it. If not append it to the list. Then go to the next line and
> compare that one to the list. Now that list can be just one or several
> elements that need to be compared.
Now take a look at my code. Im doing almost exactly what he said. (Basicy I translated his words into Autolisp code.)
Okay, im done ranting/taching/preaching/etc for da-day.
