Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
change 3Dsolid Extrude distance
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: change 3Dsolid Extrude distance (Read 3012 times)
WOWENS
Newt
on:
July 06, 2023, 05:19:50 PM »
I have a 3Dsolid and I want to change the Extrude distance with code,
any ideas on how to do this.
Logged
Bryco
Water Moccasin
Re: change 3Dsolid Extrude distance
Reply #1 on:
July 06, 2023, 07:40:23 PM »
I extrude bolts from a 2d circle by clicking 2 pts, but I am not sure there is such a thing as an extrude distance. If the shape you are trying to change is always the same shape you might have a chance to do that.
Logged
HOSNEYALAA
Newt
Reply #2 on:
July 25, 2023, 01:00:15 AM »
Hi
Can you attached example drawing
Logged
WOWENS
Newt
Reply #3 on:
July 26, 2023, 02:46:40 PM »
It's a simple beam, I can change the Height with the properties box but I want to access it with .net
Logged
Bryco
Water Moccasin
Reply #4 on:
August 01, 2023, 02:26:07 PM »
In the object browser there is a AcadExtrudedSurfaceClass that has a get,set height (see Interop.AutoCAD). It may be of some use.
Logged
gile
Gator
Marseille, France
WWW
Reply #5 on:
August 01, 2023, 05:16:42 PM »
You can use the Solid3d.ExtrudeFaces method.
To find the face to be extruded, you can use the Brep API.
Code - C#:
[Select]
private
static
void
ChangeExtrusionHeight
Solid3d solid, Vector3d extrusionDirection,
double
newHeight
var
fullPath
new
FullSubentityPath
new
solid
ObjectId
new
SubentityId
SubentityType
Null
, IntPtr
Zero
using
var
brep
new
Brep
fullPath
var
face
brep
Faces
Where
f
ExternalBoundedSurface
f
Surface
BaseSurface
is
Plane plane
plane
Normal
IsParallelTo
extrusionDirection
Select
f
var
plane
Plane
f
Surface
BaseSurface
return
new
f
SubentityPath
SubentId
, Height
Math
Abs
plane
Coefficients
D
OrderByDescending
x
x
Height
First
solid
ExtrudeFaces
new
face
SubentId
, newHeight
face
Height
0.0
Last Edit: August 02, 2023, 04:36:44 AM by gile
Logged
Bryco
Water Moccasin
Reply #6 on:
August 02, 2023, 02:28:30 PM »
Cool for cats as usual gile
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
