Author Topic: Random Thought. How does Save all/ close all work.  (Read 3670 times)
Lonnie
« on: May 24, 2023, 11:44:52 AM »
I was looking back at this Autodesk thread
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-to-reload-xrefs-in-all-open-drawings/m-p/11778941#M444191
It got me to wondering how does Autodesk do the "Save all" "close all" command.
Could the same method be used for other commands?
Re: Random Thought. How does Save all/ close all work.
« Reply #1 on: May 24, 2023, 01:24:18 PM »
Yes and no.
Here is a saveall.
NOTE: The "vlxx" prefix I believe was ACADX.
  1. (defun vlxx-SaveAllDocs ( / item cur)
  2.     (vla-Save item)
  3.   )
  4. )
Here is another method for doing a closeall. This is more of a framework for doing "other things" but doesn't always work and I never read up on the Vla-SendCommand function to comment much more.
  1. (defun vl-CloseAllDocs ( / item cur)
  2.   (vlax-for item (vla-Get-Documents (vlax-get-object "AutoCAD.Application"))
  3.     (if (= (vla-Get-Active item) :vlax-False)
  4.       (vla-Close item :vlax-False)
  5.       (setq cur item)
  6.     )
  7.   )
  8.   (vla-SendCommand cur "_.CLOSE")
  9. )
You can perform a DUMP on the document and the documentS object to see what you can/cannot do.
Lonnie
« Reply #2 on: May 24, 2023, 01:50:27 PM »
Sorry for the confusion.
What I was wondering is if AutoCAD does the save all and close all commands. Does that mean it has a way around LISP functions losing focus and ceasing evaluations, if so could that be piggy backed to do other things like scmallory ask.
I can think of a few times I would have liked to run the same routine on all opened dwg's. Now I just run them in each tab and be done with it. (An easy example I did just last week was when my title block insert. (Sheet name, number drafter and EOR.) added a disclaimer. Then they wanted the disclaimer to move. Then they wanted the disclaimer to say something different.) I just did a
(command "insert" "Title block insert=.\\..\\..\\Title block insert" "0,0" "1" "1" "0")
(command "erase" "l" "")
drag and drop in each dwg to redefine it.
That was 96 projects 4 dwg (Sheets) each. 3 separate times.
But if I had a technique I could repeat. I'd be able to do this with a lot of things.
MSTG007
« Reply #3 on: May 24, 2023, 03:33:30 PM »
Thanks for sharing that. Good reference. I would have not thought about the sendcommand.
Civil3D 2020
57gmc
« Reply #4 on: May 24, 2023, 04:27:03 PM »
Lisp runs in the document context, not the application context. To do what you want with lisp, you need another method of running in the application context. One work around is the program ScriptPro. You write an scr file, which can include lisp. Then the program runs your script on a batch of drawings. The other thing you can do is switch to a language that can run in the application context, like VBA or .NET.
« Reply #5 on: May 24, 2023, 04:50:26 PM »
> script pro
The cool kids play with better toys.
https://www.theswamp.org/index.php?topic=56891.0
Although, the thought of multiple tabs sounds fun to play with.
57gmc
« Reply #6 on: May 24, 2023, 05:22:07 PM »
> script pro
LOL I thought about mentioning accorconsole, but forgot. thanks.
Lonnie
« Reply #7 on: May 24, 2023, 06:08:14 PM »
Thanks all.
I consider myself barely a duffer in lisp. I guess I really should expand my horizons.
When I have time I will play with the new toys you all have suggested.
