Author Topic: Can Python replace the LISP !!  (Read 2091 times)
d2010
« on: May 20, 2023, 04:54:53 AM »
Hello.
The VLisp is slow as speed.
The LISP for Python, named Hy is slow.
The Python is slow internal AutoCad.
The  app.exe with python is 30%normal without  Autocad.
The C# is normal-speed.
The C++ is good-speed.
 :grumpy:
If the speed of Python is slower that VLISP.fas
--then is not future inside Python?
LISP stands for List Processing.
Quora==As far as I can see, Hy has no discernable benefits.
 If you want to use Python, you’d just use Python.
If you want to use Lisp, there are many excellent versions, including Clojure,
Scheme, Racket and Common Lisp. Common Lisp has many
free versions, including SBCL, CCL, Portacle and community
versions of commercial software such as LispWorks
Anyway try the speed of Go or Julia?
Perhaps > Using the function (list "many-types-of-objects") decrease the speed.lsp  too much.
Alles gutes.
« Last Edit: May 20, 2023, 05:16:15 AM by d2010 »
Re: Can Python replace the LISP !!
« Reply #1 on: May 20, 2023, 08:32:09 PM »
Interesting, I was thinking of making a test for this using Delaunator, a Delaunay triangulation routine that has been ported to Python, C# and C++, so it’s a good test.
When measuring how fast these languages are with CAD, you’re really just measuring how fast these languages interoperate with ARX
 .NET, Python and lisp all interface with CAD via some sort of wrapper.
From a CAD perspective, I think Python can be as fast as .Net, or close to it.
Python https://www.theswamp.org/index.php?topic=58234.0
C# https://www.theswamp.org/index.php?topic=57121.msg606834#msg606834
C++ https://www.theswamp.org/index.php?topic=57122.msg606896#msg606896
Python wasn't designed to be a high performance language. But I think it can be a really good language for CAD since it has a TON
of external libraries
« Reply #2 on: May 20, 2023, 08:42:55 PM »
I know my python skills suck
but here's an example of reading excel into a table.
in C++, you'd have to find a library and go through the hassle of compiling it
easier in .NET, but now all the libraries are moving to Core
lisp, you'd have to party on COM, about at fun as driving a F250 with a toilet bowl plunger as the gearshift.
python, just pip openpyxl and it's ready to use.
one drawback of python is deploying, users need to setup their own environment
Code - Python: [Select]
  1. from openpyxl import load_workbook
  2.
  3. def PyRxCmd_pydoit():
  4.     try:
  5.         table = PyDb.Table()
  6.         table.setSize(22,8)
  7.         table.generateLayout()
  8.         table.setDatabaseDefaults()
  9.
  10.         wb  = load_workbook('sample.xlsx')
  11.         sheet = wb.active
  12.         for icol in range(7):
  13.             for irow in range(20):
  14.                 val = sheet.cell(row=irow+1, column=icol+1)
  15.                 table.setTextString(irow,icol,"{}".format(val.value))
  16.
  17.         db = PyAp.Application().docManager().curDocument().database()
  18.         model = PyDb.BlockTableRecord(db.modelSpaceId(), PyDb.OpenMode.kForWrite)
  19.         model.appendAcDbEntity(table)
  20.
  21.     except Exception as err:
  22.         PyRxApp.Printf(err)
  23.
« Reply #3 on: May 20, 2023, 08:45:15 PM »
post a lisp, and I'll measure it against Python
BIGAL
  • 40 + years of using Autocad
« Reply #4 on: May 20, 2023, 08:59:41 PM »
How fast is fast, I did a project manual version of task around 4 hours, 1st go using command for most of it about 36 minutes, current version is about 2 minutes. That includes 4 (alert "step 1 has been completed") so user can know something has been done. I could remove the alerts but at about 1.5 minutes seems still worthwhile, but compare 4 Hours.
Excel to table should be almost instant, using VL, the clue here is to turn off table regen, and turn it back on once the table is made, this is a massive change in speed, I have seen like 2 seconds v's a minute plus. (vla-put-regeneratetablesuppressed tableobj :vlax-false)
I have select a range in Excel or just get all used cells. The latter no user input.
« Reply #5 on: May 20, 2023, 09:39:10 PM »
The routine I posted is instant, just reading 7 X 20 cells though
Openpyxl, operates on the .XLSX file itself, so it never launches Excel.
https://openpyxl.readthedocs.io/en/stable/ under performance shows 50 X 1000 cells in 1.14 seconds
Tables would get wonky at that size
for ranges, maybe a named range would work?
My guess is that Python vs Lisp, with COM would be about the same, and you would need to suppress table regen with both.
caveat, my wrappers are still in progress, so yeah, lisp is still faster :)
BIGAL
« Reply #6 on: May 21, 2023, 10:08:29 PM »
That is a choice you can operate on it without seeing it open.
(vla-put-visible myXL :vlax-true)
« Reply #7 on: May 22, 2023, 07:17:03 AM »
It’s not the same, setting the visibility, still launches Excel in the background.
A .XLSX is a zip file containing XML parts. Rename a sample .XLSX file, change the extension and unzip it.
Inside of the folder, you’ll see a bunch of .XML parts. These XML parts are documented by Microsoft.
https://learn.microsoft.com/en-us/dotnet/api/documentformat.openxml.spreadsheet?view=openxml-2.8.1
Openpyxl directly reads the file, whereas VLA functions ask Excel to open the file, then send you the data parts you want.
Openpyxl, OpenXLSX can read millions of cell values per second, where operating via COM is probably in the thousands.
Caveat, if you need at runtime formula evaluation, then you need to use excel, if you just need the formula value, or the formula itself, Openpyxl will get you that
« Reply #8 on: May 22, 2023, 07:45:35 AM »
here's the file I use to test the performance of my field evaluator, 450,000 cells
in python
  1. from timeit import default_timer as timer
  2. from openpyxl import load_workbook
  3.
  4. def PyRxCmd_pydoit():
  5.     try:
  6.         start = timer()
  7.         wb  = load_workbook('M:\\Dev\\Projects\\XlsxFields\\TestData\\SampleXLSFile_50000.xlsx')
  8.         sheet = wb.active
  9.
  10.         all_rows = []
  11.         for row in sheet.rows:
  12.             all_rows.append([data.value for data in row])
  13.
  14.         end = timer()
  15.         print(len(all_rows))
  16.         print(end - start)
  17.     except Exception as err:
  18.         PyRxApp.Printf(err)
  19.
4.14696879999974 seconds
not in the millions, but reasonable for such a large data set ... just to give you an idea
VovKa
  • Ukraine
« Reply #9 on: May 22, 2023, 08:14:08 AM »
i use ms office 2003, so i converted xlsx to xls
COM lisp read it in 3.323 seconds on my >10 years old pentium e6600
« Reply #10 on: May 22, 2023, 08:33:39 AM »
nice!! care your post your code?
VovKa
  • Ukraine
« Reply #11 on: May 22, 2023, 09:03:03 AM »
(defun vk_Excel-GetData (FileName SheetName Range / ExcelObj IsExcelRunning IsFileOpenned BooksObj BookObj SheetsObj SheetObj CellsObj LastCellObj
OutList *error*)
  (if (and (or (and (not FileName) (setq ExcelObj (vlax-get-object "Excel.Application")) (setq IsExcelRunning t))
       (and FileName (findfile FileName) (setq ExcelObj (vlax-create-object "Excel.Application")))
   (or IsExcelRunning (not (vlax-put-property ExcelObj "Visible" :vlax-false)))
   (if FileName
     (and (setq BooksObj (vlax-get-property ExcelObj "WorkBooks"))
  (not (vl-catch-all-error-p (setq BookObj (vk_CatchMethod (list BooksObj "Open" FileName nil t)))))
     (and (setq BookObj (vlax-get-property ExcelObj "ActiveWorkbook")) (setq IsFileOpenned t))
   (setq SheetObj (if SheetName
    (if (setq SheetsObj (vlax-get-property BookObj "Sheets"))
      (vlax-get-property SheetsObj "Item" SheetName)
    (vlax-get-property BookObj "ActiveSheet")
   (or Range (setq CellsObj (vlax-get-property SheetObj "UsedRange")))
    (setq
      OutList (mapcar (function (lambda (row)
  (mapcar (function (lambda (cell)
      (if (setq cell (vlax-variant-change-type cell vlax-vbString))
(vlax-variant-value cell)
  row
      (vk_VariantToLst
(vlax-get-property
     "Range"
     (cond (Range)
   ((strcat "A1:"
    (vk_ExcelNumToAbc (vlax-get-property (vlax-get-property CellsObj "Columns") "Count"))
    (itoa (vlax-get-property (vlax-get-property CellsObj "Rows") "Count"))
  "Value"
  (foreach Obj (list (list LastCellObj)
     (list CellsObj)
     (list SheetObj)
     (list SheetsObj)
     (list BookObj
   (lambda ()
     (if (not IsFileOpenned)
       (vk_CatchMethod (list BookObj "Close" :vlax-false))
     (list BooksObj)
     (list ExcelObj
   (lambda ()
     (if (not IsExcelRunning)
       (vk_CatchMethod (list ExcelObj "Quit"))
    (if (and (car Obj) (not (vl-catch-all-error-p (car Obj))))
      (progn (eval (cdr Obj)) (vlax-release-object (car Obj)))
  (gc)
  OutList
no dependencies because boring
« Reply #12 on: May 22, 2023, 09:14:33 AM »
 :lol:
« Reply #13 on: May 22, 2023, 09:38:11 AM »
read only is
  1.  wb  = load_workbook('M:\\Dev\\Projects\\XlsxFields\\TestData\\SampleXLSFile_50000.xlsx',read_only=True)
Command: PYDOIT
50000
2.3242195999991964
