Author Topic: How to Trim/Remove all objects inside a selected set of Rectangle/Polygon?  (Read 390 times)
Pramodrajpandit123
  • Mosquito
Hello,
I wanted to remove all the objects that are inside the selected number of Rectangles (Remove all objects except Dimension & Polyline that is on specific layer named "Undelete").
I tried Extrim command but it deletes objects only one at a time. Also there is no option to not remove polyline ( that is on "Undelete" layer) which is inside a rectangle.
Similar case for "Cookiecutter".
Is there a lisp routine that :
1.Ask for selecting multiple rectangles.
2.Remove every objects inside rectangle except Dimension.
Thank you!
danAllen
Check out this thread for selecting inside polylines. Combine with SSGET filter to exclude what you want.
https://www.cadtutor.net/forum/topic/56720-polyline-as-a-selection-fence/
JohnCamper
  • Mosquito
Try this Extrim for Multiple Selection (found on other Forum)!
;Extrim Multiple
;Original code posted by marko_ribar to http://www.cadtutor.net/forum/showthread.php?68144-how-trim-many-line-inside-multi-circle-on-one-step/page2&p=#19
;Edited by benhubel to suit his frivolous desires
;Please forgive the code hacks, I don't actually know what I'm doing.
(defun c:et () ;normal extrim shortcut for quick access
(c:extrim)
) ;end et
(defun c:eti () ;shortcut to extrim on the inside of all selected and closed polylines
(setq etside 1)
(c:etm)
) ;end eti
(defun c:eto () ;shortcut to extrim on the outside of all selected and closed polylines
(setq etside 2)
(c:etm)
) ;end eto
(defun c:etm ( / rnd GroupByNum ptonline ptinsideent highlight
                    ss n en ed enA minpt maxpt dx dy pt dxx dyy ) ;extrim multiple
 (load "extrim.lsp")
 (defun rnd (/ modulus multiplier increment rand)
   (if (not seed)
     (setq seed (getvar "DATE"))
   (setq modulus    65536
         multiplier 25173
         increment  13849
         seed  (rem (+ (* multiplier seed) increment) modulus)
         rand     (/ seed modulus)
 (defun GroupByNum ( l n / f )
   (defun f ( a b )
     (if (and a (< 0 b))
       (cons (car a) (f (setq l (cdr a)) (1- b)))
   (if l (cons (f l n) (GroupByNum l n)))
 (defun ptonline ( pt pt1 pt2 / vec12 vec1p d result )
   (setq vec12 (mapcar '- pt2 pt1))
   (setq vec12 (reverse (cdr (reverse vec12))))
   (setq vec1p (mapcar '- pt pt1))
   (setq vec1p (reverse (cdr (reverse vec1p))))
   (setq vec2p (mapcar '- pt2 pt))
   (setq vec2p (reverse (cdr (reverse vec2p))))
   (setq d (distance '(0.0 0.0) vec12) d1 (distance '(0.0 0.0) vec1p) d2 (distance '(0.0 0.0) vec2p))
   (if (equal d (+ d1 d2) 1e- (setq result T) (setq result nil))
   result
 (defun ptinsideent ( pt ent / msp ptt xlin int k kk tst result )
   (setq msp (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
   (setq ptt (vlax-curve-getclosestpointto ent pt))
   (setq xlin (vla-addxline msp (vlax-3d-point pt) (vlax-3d-point ptt)))
   (setq int (GroupByNum (vlax-invoke (if (eq (type ent) 'ENAME) (vlax-ename->vla-object ent)) 'intersectwith xlin acExtendBoth) 3))
   (setq int (vl-sort int '(lambda (a b) (< (vlax-curve-getparamatpoint xlin a) (vlax-curve-getparamatpoint xlin b)))))
   (setq k 0)
   (while (< (setq k (1+ k)) (length int))
     (if (and (eq (rem k 2) 1) (ptonline pt (nth (- k 1) int) (nth k int))) (setq tst (cons T tst)) (setq tst (cons nil tst)))
   (setq tst (reverse tst))
   (setq k 0)
   (mapcar '(lambda (x) (setq k (1+ k)) (if (eq x T) (setq kk k))) tst)
   (vla-delete xlin)
   (if kk
     (if (eq (rem kk 2) 1) (setq result T) (setq result nil))
     (setq result nil)
   result
 (setq highlight (getvar "HighLight"))
 (acet-error-init (list
                    (list   "cmdecho" 0
                          "highlight" highlight
                          "regenmode" 1
                             "osmode" 0
                            "ucsicon" 0
                         "offsetdist" 0
                             "attreq" 0
                           "plinewid" 0
                          "plinetype" 1
                           "gridmode" 0
                            "celtype" "CONTINUOUS"
                          "ucsfollow" 0
                           "limcheck" 0
                    T     ;flag. True means use undo for error clean up.
                    '(if redraw_it (redraw na 4))
                   );list
 );acet-error-init
 (prompt "\nSelect closed entities: ")
 (if (setq ss (ssget (append (list '(-4 . "<or") '(0 . "CIRCLE") '(-4 . "<and") '(0 . "*POLYLINE") '(-4 . "<not") '(-4 . "&=") '(70 .  '(-4 . "not>") '(-4 . "&=") '(70 . 1) '(-4 . "and>") '(-4 . "<and") '(0 . "SPLINE") '(-4 . "&=") '(70 . 1) '(-4 . "and>") '(-4 . "<and") '(0 . "ELLIPSE") '(41 . 0.0)) (list (cons 42 (* 2 pi))) (list '(-4 . "and>") '(-4 . "or>")))))
     (setq n (sslength ss))
     (while (>= (setq n (1- n)) 0)
       (setq en (ssname ss n) ed (entget en) enA (vlax-ename->vla-object en))
         (vla-getboundingbox enA 'minpoint 'maxpoint)
       (setq
        minpt (vlax-safearray->list minpoint)
        maxpt (vlax-safearray->list maxpoint)
       (setq dx (- (car maxpt) (car minpt)))
       (setq dy (- (cadr maxpt) (cadr minpt)))
       (setq pt '(0.0 0.0 0.0)) ;I think this was originally put here to initialize pt. I don't actually see why it's needed.
(if(= etside nil)(setq etside (getint "\nDo you want to trim inside or outside? (1)Inside or (2)Outside: ")));Ask if this is an inside job or if we need our forces outside the curves.
(if(= etside 2) ;If the variable etside has been set to (2)Outside
(setq pt '(9999999.0 9999999.0 9999999.0));get a point in the middle of nowhere. The unlucky ******* who puts his geometry around this point will have problems. Poor guy.
;else  -  setting the etside int to (1)Inside is a placebo, it could've been set to 93. We probably need some error handling of some sort here
(while (not (ptinsideent pt en));get a point inside the polyline. marko_ribar did far better with this part than I know how to do.
(setq dxx (* dx (rnd)))
(setq dyy (* dy (rnd)))
(setq pt (list (+ (car minpt) dxx) (+ (cadr minpt) dyy) 0.0))
);end if
       (etrim en pt)
 (setq etside nil) ;reset etside to nil just to make sure an error doesn't slip through on second run. I'm not sure if it actually helps or not.
 (acet-error-restore)
Pramodrajpandit123
  • Mosquito
Thank you @danAllen. Got the idea on how to solve it.
Also, @Johncamper, the code gives an error when trying to use it.
