Author Topic: Dialog box for OPEN not showing - FILEDIA=1  (Read 2060 times)
David Hall
  • Automatic Duh Generator
« on: May 18, 2023, 09:12:04 AM »
After a quick search, I did not find a current post on this.
AutoCAD 2022 - after running a script where I set FILEDIA=0, did my thing, and set FILEDIA=1, the dialog box does not show up.  Checking FILEDIA at the command line shows = 1.
Hitting the ' ~ ' at command prompt does not bring up the box either.  Has anyone else had this happen?  The only way to get the dialog box back is to quit AutoCAD and re-open.
Lonnie
Re: Dialog box for OPEN not showing - FILEDIA=1
« Reply #1 on: May 18, 2023, 10:54:03 AM »
I have found and I don't know why sometimes the CMDDIA gets flipped to 0 also.
David Hall
« Reply #2 on: May 19, 2023, 02:50:32 PM »
yeah, my script sets and un-sets that one as well.  Both are set to 1, and the file box wont open.  Not the end of the world, but annoying
Bryco
« Reply #3 on: May 22, 2023, 03:10:54 PM »
Does changing the "expert" sysvar help David. I doubt it but maybe.
David Hall
« Reply #4 on: May 23, 2023, 09:15:54 AM »
I did set it to 5 in the script, I will try setting it back
David Hall
« Reply #5 on: May 23, 2023, 12:28:53 PM »
Of all things, it was because I needed to set my file type as ACAD2013
As soon as I set back to 2018, problem went away
