Hi ronjonp,
Thank you for your response. As I say I can get the result by selecting the block as you have done. What I'm looking for is something along the lines of:
(tblsearch "block" myblk) if my myblk exists then test if it is dynamic. I suppose a work around would be to insert the block, test it, then delete entlast. Just trying to find the cleanest solution possible.
