Author Topic: Extrude along path  (Read 1133 times)
David Hall
  • Automatic Duh Generator
Extrude along path
« on: April 20, 2023, 03:17:33 PM »
I am trying to use some code that I think Bryco helped me with years ago to extrude a circle along a spline path.  I cannot figure out why this doesn't work
Public Sub DrawCable()
      On Error GoTo err_control
'      Dim InsPt As Variant, dblRot As Double, strPrompt As String, intBusCenterLine As Integer
      Dim dblBusDia As Double
      Dim oLayer As AcadLayer, oLine As AcadSpline, objPath As Object
Dim newPT1(2) As Double
Dim newPT2(2) As Double
Dim P1, P2
Dim V(2) As Double, Unit As Double, Vn(2) As Double
Dim oCyl As Acad3DSolid, oCircle As AcadCircle
Dim regent(0) As AcadEntity
Dim oReg As Variant
Start:
      dblBusDia = 1.45
      Set oLayer = ThisDrawing.Layers.Add("3D-BUSS-CALC")
      oLayer.color = 234
      Dim objSelected As Object
      Dim objSelSet As AcadSelectionSet
      Set oLayer = ThisDrawing.Layers.Add("3D-BUSS")
      oLayer.color = 3
      Set objSelSet = ThisDrawing.SelectionSets.Add("Bus")
      objSelSet.SelectOnScreen
For Each objSelected In objSelSet
            If Not TypeOf objSelected Is AcadSpline Then
                  MsgBox "That was not a Layout Line"
                  Exit Sub
            End If
            Set oLine = objSelected
            Set objPath = objSelected
            newPT1(0) = oLine.FitPoints(0): newPT1(1) = oLine.FitPoints(1): newPT1(2) = oLine.FitPoints(2)
            newPT2(0) = oLine.FitPoints(3): newPT2(1) = oLine.FitPoints(4): newPT2(2) = oLine.FitPoints(5)
            P1 = newPT1
            P2 = newPT2
            V(0) = P2(0) - P1(0): V(1) = P2(1) - P1(1): V(2) = P2(2) - P1(2)
      'Normalise the vector(It's length=1)
            Unit = Sqr(V(0) * V(0) + V(1) * V(1) + V(2) * V(2))
            Vn(0) = V(0) / Unit: Vn(1) = V(1) / Unit: Vn(2) = V(2) / Unit
            Set oCircle = ThisDrawing.ModelSpace.AddCircle(P1, dblBusDia / 2)
            oCircle.Normal = Vn    ' Vn or V both work here.
            Set regent = oCircle
            oReg = ThisDrawing.ModelSpace.AddRegion(regent)
            Set oCyl = ThisDrawing.ModelSpace.AddExtrudedSolidAlongPath(oReg(0), objPath)
            oCyl.Layer = "3D-BUSS"
            oCircle.Delete
            oReg(0).Delete
      Next
      ThisDrawing.SelectionSets.Item("Bus").Delete
      ThisDrawing.Application.Update
Exit_Here:
      ThisDrawing.SetVariable "INSUNITS", 1
      Unload frmBus
      Exit Sub
err_control:
      Select Case Err.Number
      Case "-2145320851"
            Err.Clear
            Resume
      Case Else
            MsgBox Err.Description
                        oCircle.Delete
            oReg(0).Delete
            Resume Exit_Here
      End Select
« Last Edit: April 20, 2023, 03:37:36 PM by David Hall »
They say money can't buy happiness, but it can buy Bacon and that's a close second
David Hall
Re: Extrude along path
« Reply #1 on: April 20, 2023, 03:21:12 PM »
It works all the way to this line
David Hall
« Reply #2 on: April 20, 2023, 03:25:46 PM »
And if I stop the code after the region is created, I can manually extrude the region along the spline, so I know it can be done.
David Hall
« Reply #3 on: April 28, 2023, 03:10:51 PM »
Any takers?
El Jefe
« Reply #4 on: April 29, 2023, 06:10:47 PM »
you're wanting to extrude a region? did you try with just a circle?
ThisDrawing.ModelSpace.AddExtrudedSolidAlongPath(oReg(0), oCircle )
Retired
David Hall
« Reply #5 on: May 01, 2023, 08:37:31 AM »
I didn't try that, but I will.
David Hall
« Reply #6 on: May 01, 2023, 08:41:51 AM »
didnt work
David Hall
« Reply #7 on: May 01, 2023, 08:43:40 AM »
works if I manually do it, but not through code
David Hall
« Reply #8 on: May 01, 2023, 03:10:15 PM »
I verified I had what you put, and it still does not work.  I am beginning to think it wont work.  I have found the example from Adesk doesn't work either
El Jefe
« Reply #9 on: May 02, 2023, 01:36:32 AM »
I was just guessing, I don't have VBA to test with
Retired
