Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Routine runs straight through but not complete.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Routine runs straight through but not complete. (Read 935 times)
jlogan02
Bull Frog
on:
April 20, 2023, 11:42:02 AM »
If I separate ----Test TBs----- from the ---dcl--- & ----Scale TBs------- all works fine in two separate routines. Combining them doesn't seem to work. Debugging isn't showing me anything at all. The routine goes through (for the most part) the entire routine.
I've experienced this before with combining routines and the same thing happened, so I'm assuming I'm missing a piece of the puzzle.
Code - Auto/Visual Lisp:
[Select]
vl-load-com
defun
c:spacex
ss attvalue dimsc blk1 fld1 siz names dsty dstydata userclick x obj obj1 obj2
olay ss ss1 ss2 tag1 tag2 att
defun
*error*
msg
if
osm
setvar
'osmode osm
if
not
member
msg '
"Function cancelled"
"quit / exit abort"
princ
strcat
\n
Error: "
msg
princ
setq
osm
getvar
'osmode
setvar
'osmode
0
setvar
'cmdecho
0
defun
lm:getattributevalue
blk tag
val enx
while
and
null
val
"ATTRIB"
cdr
assoc
0
setq
enx
entget
setq
blk
entnext
blk
if
strcase
tag
strcase
cdr
assoc
2
enx
setq
val
cdr
assoc
1
enx
;;------------------test and insert TBs---------------------------
setq
ss
ssget
"x"
0
"INSERT"
2
"ATTSubCode"
66
1
setq
attvalue
LM:GetAttributeValue
ssname
ss
0
"HIDDEN_SUBJCODE"
setq
dimsc
getvar
'dimscale
cond
wcmatch
strcase
attvalue
"03,05,84,60,62,64,80,66,67,68,72,70,71,73,74,86,88,89,82,83,90,92,93,94,96,98,41,42,43,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59"
command
s
"layout"
"t"
"TBLK_BORD_STR_STD"
"ANSI-D 22x34"
command
"Clayout"
"ANSI-D 22x34"
command
"_.-insert"
"STA_STR_STANDARDS"
"0,0"
dimsc dimsc
"0"
command
"-layer"
"filter"
"s"
"All"
command
"zoom"
"all"
wcmatch
strcase
attvalue
"05,01,10,14,16,40,12,29,20,22,30,34,32,35,41,42,56,44,46,48,49,50,52,67"
command
"Clayout"
"Model"
command
"_.-insert"
"BLANK"
"0,0"
dimsc dimsc
"0"
command
"explode"
"last"
;;(command "._layer" "unlock" "TTBK_BORD_LINES" "")
;;(command "._layer" "Make" "LINE1" "C" "YELLOW" "LINE1" "")
command
"Zoom"
"Extents"
;;-----------------dcl------------------
setq
SIZ
"0"
setq
NAMES '
"NONE"
"1/4
= 1'-0
"1/2
= 1'-0
"1
= 1'-0
"1-1/2
= 1'-0
"3
= 1'-0
"6
= 1'-0
setq
dcl_id
load_dialog
"STA_Scale_TB.dcl"
;load dialog
if
not
new_dialog
"STA_Scale_TB"
dcl_id
;test for dialog
exit
;exit if no dialog
;if
start_list
"scales"
;start the list box
mapcar
add_list
NAMES
;fill the list box
end_list
;end list
action_tile
"cancel"
;if cancel button pressed
"(done_dialog) (setq userclick nil)"
;close dialog, set flag
;action_tile
action_tile
"accept"
;if O.K. pressed
strcat
;string 'em together
"(progn
(setq SIZ (get_tile
scales
;get list selection
"(done_dialog)(setq userclick T))"
;strcat
;action tile
start_dialog
;start dialog
unload_dialog
dcl_id
;unload
if
userclick
;check O.K. was selected
progn
cond
SIZ
"0"
setvar
"dimscale"
1
;;FULL
SIZ
"1"
setvar
"dimscale"
48
;;1/4"
SIZ
"2"
setvar
"dimscale"
24
;;1/2"
SIZ
"3"
setvar
"dimscale"
12
;;1"
SIZ
"4"
setvar
"dimscale"
8
;;1 1/2"
SIZ
"5"
setvar
"dimscale"
4
;;3"
SIZ
"6"
setvar
"dimscale"
2
;;6"
;cond
setq
tag1
"DRAWINGSCALE"
setq
ss
ssget
"x"
2
"TBLK_ATT_STA"
66
1
repeat
setq
x
sslength
ss
setq
obj
vlax
ename
vla-object
ssname
SS
setq
x
x
1
if
vla-get-hasattributes
obj
:vlax-true
foreach
att
vlax-invoke
obj 'getattributes
if
tag1
strcase
vla-get-tagstring
att
vla-put-textstring
att
nth
atoi
siz
names
setq
tag2
"DESIGNER"
if
setq
ss1
ssget
"_X"
0
"INSERT"
2
"TBLK_ATT_STA"
66
1
repeat
setq
idx
sslength
ss1
setq
idx
1-
idx
obj
vlax
ename
vla-object
ssname
ss1 idx
vl-some
lambda
att
if
and
tag2
strcase
vla-get-tagstring
att
vlax-write-enabled-p
att
not
vla-put-textstring
att
strcase
substr
getvar
'loginname
1
3
vlax-invoke
obj 'getattributes
;;--------------------Scale TBs------------------------
setq
dimsc
getvar
'dimscale
command
"-layer"
"unlock"
"TTBK_BORD_LINES"
setq
blk1
ssget
"x"
2
"TBLK_BORD_CTL,TBLK_BORD_MAX,TBLK_ATT_STA"
;;TBLK_BORD_CTL
command
"scale"
blk1
"0,0"
dimsc
setq
fld1
ssget
"x"
8
"TTBK_TBLK_VAULTNO"
;;Vault number field.
command
"scale"
fld1
"0,0"
dimsc
;;(command "-layer" "lock" "TTBK_BORD_LINES" "")
setvar
"fielddisplay"
0
if
tblsearch
"layer"
"TTBK_TBLK_REVINIT"
command
"-Layer"
"Make"
"TTBK_TBLK_REVINIT"
"c"
"green"
"TTBK_TBLK_REVINIT"
setq
Odyn
getvar
'dynmode
setvar
'dynmode
0
while
setq
dsty
tblnext
"dimstyle"
not
dsty
setq
dstydata
entget
tblobjname
"dimstyle"
cdr
assoc
2
dsty
if
assoc
40
dstydata
; [because not included in data if default 1.0]
entmod
subst
cons
40
dimsc
assoc
40
dstydata
dstydata
; then -- replace it
entmod
append
dstydata
list
cons
40
dimsc
; else -- add it
command
"layer"
"M"
"LINE1"
"C"
"YELLOW"
"LINE1"
command
"limits"
getvar
"extmin"
getvar
"extmax"
command
"zoom"
"e"
setvar
"CMDECHO"
0
setvar
"BLIPMODE"
0
command
".style"
"Standard"
"ipco.shx"
1.000
dimsc
"0.85"
"0"
"n"
"n"
"n"
command
".style"
"L080"
"ipco.shx"
0.0781
dimsc
"0.85"
"0"
"n"
"n"
"n"
command
".style"
"L100"
"ipco.shx"
0.0938
dimsc
"0.85"
"0"
"n"
"n"
"n"
command
".style"
"L120"
"ipco.shx"
0.1094
dimsc
"0.85"
"0"
"n"
"n"
"n"
command
".style"
"L140"
"ipco.shx"
0.1406
dimsc
"0.85"
"0"
"n"
"n"
"n"
command
".style"
"L175"
"ipco.shx"
0.1563
dimsc
"0.85"
"0"
"n"
"n"
"n"
command
".style"
"L200"
"ipco.shx"
0.1719
dimsc
"0.85"
"0"
"n"
"n"
"n"
command
".style"
"L240"
"ipco.shx"
0.2187
dimsc
"0.85"
"0"
"n"
"n"
"n"
command
".style"
"Ls080"
"ipco.shx"
0.0781
dimsc
"0.85"
"0"
"n"
"n"
"n"
command
".style"
"Ls100"
"ipco.shx"
0.0938
dimsc
"0.85"
"0"
"n"
"n"
"n"
command
".style"
"Ls120"
"ipco.shx"
0.1094
dimsc
"0.85"
"0"
"n"
"n"
"n"
command
".style"
"Ls140"
"ipco.shx"
0.1406
dimsc
"0.85"
"0"
"n"
"n"
"n"
command
".style"
"Ls175"
"ipco.shx"
0.1563
dimsc
"0.85"
"0"
"n"
"n"
"n"
command
".style"
"Ls200"
"ipco.shx"
0.1719
dimsc
"0.85"
"0"
"n"
"n"
"n"
command
".style"
"Ls240"
"ipco.shx"
0.2187
dimsc
"0.85"
"0"
"n"
"n"
"n"
;progn
setvar
"cmdecho"
1
setvar
"dynmode"
Odyn
command
"_zoom"
"e"
alert
"Way to go!!! You scaled the border."
princ
The theory is...
We have a 3rd party drawing vault where a properties card is filled out with a subject code for each drawing type. This routine would look at the subject code in the TB attribute and insert the correct title block. If the subject code is a model space code the dcl fires and asks the user for a scale (I know...why don't you use paper space?!?!? If you feel the need to discuss that, please move on.) I get the dcl to pop up and the dimscale is properly set from that selection, the line1 layer is set current but nothin else in that section is working.
Logged
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
jlogan02
Bull Frog
Re: Routine runs straight through but not complete.
Reply #1 on:
April 20, 2023, 11:57:36 AM »
forgot to attach the dcl. Sadly, I can't attach company drawings.
Logged
J. Logan
ACAD 2018
BIGAL
Swamp Rat
40 + years of using Autocad
Reply #2 on:
April 22, 2023, 08:07:35 PM »
A couple of suggestions, use a dwg template with your layouts all setup with different sizes, I dont understand why your scaling your title block, we never did that, that is what Mview is for set a scale for the view of the model objects
Re your dcl you can use this in future it only requires like 2 lines of code to make a dcl and get an answer. Look at examples in start of code, you get a string as answer form pick or for multiple choices look at the value of "but" and compare to a list.
By using a dwt all your layers are set and all your styles exist. We would get a dwg from a external source and just paste into our template so everything was there.
Last Edit: April 22, 2023, 08:11:04 PM by BIGAL
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
