Author Topic: 3dpoly to 3dface (with 3 vertices or 4 vertices with the first and last equal)  (Read 998 times)
mariolino0099
This AutoLISP code is used to convert closed 3D polylines into 3D faces. It will check a selection set of polylines and convert any polylines that are closed 3D polylines into 3D faces. In order for a polyline to be considered a 3D polyline, it must have at least four vertices (first and last equal). The code will output the number of 3D polylines that were converted and the number that were ignored.
But here are something wrong... can anyone help me ? Thanks
  1. (defun c:polytoface (/ ss cnt1 cnt2)
  2.   (setq ss (ssget '((0 . "POLYLINE") (-4 . "&") (70 . 8))))
  3.   (setq cnt1 0
  4.         cnt2 0
  5.   )
  6.   (if ss
  7.     (progn
  8.       (repeat (sslength ss)
  9.         (setq ent (entget (ssname ss (setq cnt1 (1+ cnt1)))))
  10.         (if (= (cdr (assoc 10 ent)) (cdr (assoc 11 (last ent))))
  11.           (if (= (- (length (cdr (assoc 10 ent)))) 3)
  12.             (progn
  13.               (command "._3dface"
  14.                        (cdr (assoc 10 ent))
  15.                        (cdr (assoc 20 ent))
  16.                        (cdr (assoc 30 ent))
  17.                        (cdr (assoc 40 ent))
  18.               )
  19.               (setq cnt2 (1+ cnt2))
  20.             )
  21.           )
  22.           (if (= (- (length (cdr (assoc 10 ent)))) 4)
  23.             (if (= (cdr (assoc 10 ent)) (nth 1 (cdr (assoc -1 ent))))
  24.               (progn
  25.                 (command "._3dface"
  26.                          (cdr (assoc 10 ent))
  27.                          (cdr (assoc 20 ent))
  28.                          (cdr (assoc 30 ent))
  29.                          (cdr (assoc 40 ent))
  30.                 )
  31.                 (setq cnt2 (1+ cnt2))
  32.               )
  33.             )
  34.           )
  35.         )
  36.       )
  37.       (princ (strcat "\n"
  38.                      (itoa cnt2)
  39.                      " 3dpoly converted, "
  40.                      (itoa (- cnt1 cnt2))
  41.                      " ignored."
  42.              )
  43.       )
  44.     )
  45.     (princ "\nNo 3dpoly found.")
  46.   )
  47.   (princ)
  48. )
  49.
  50.
  51.
ribarm
  • Marko Ribar, architect
Untested, but it should work...
  1. (defun c:polytoface ( / vertlst ss ent pl cnt1 cnt2 )
  2.
  3.   (defun vertlst ( poly / v vx pl )
  4.     (setq v poly)
  5.     (while (= (cdr (assoc 0 (setq vx (entget (setq v (entnext v)))))) "VERTEX")
  6.       (setq pl (cons (cdr (assoc 10 vx)) pl))
  7.     )
  8.     (reverse pl)
  9.   )
  10.
  11.   (setq cnt1 -1
  12.         cnt2 0
  13.   )
  14.   (if (setq ss (ssget '((0 . "POLYLINE") (-4 . "<or") (70 . 8) (70 . 9) (-4 . "or>"))))
  15.     (progn
  16.       (repeat (sslength ss)
  17.         (setq ent (ssname ss (setq cnt1 (1+ cnt1))))
  18.         (setq pl (vertlst ent))
  19.         (if (= (length pl) 4)
  20.           (if (equal (car pl) (last pl) 1e-6)
  21.             (progn
  22.               (command "._3dface"
  23.                  "_non" (car pl)
  24.                  "_non" (cadr pl)
  25.                  "_non" (caddr pl)
  26.                  "_non" (cadddr pl)
  27.                  ""
  28.               )
  29.               (setq cnt2 (1+ cnt2))
  30.             )
  31.           )
  32.           (if (= (length pl) 3)
  33.             (progn
  34.               (command "._3dface"
  35.                  "_non" (car pl)
  36.                  "_non" (cadr pl)
  37.                  "_non" (caddr pl)
  38.                  "_non" (caddr pl)
  39.                  ""
  40.               )
  41.               (setq cnt2 (1+ cnt2))
  42.             )
  43.           )
  44.         )
  45.       )
  46.       (princ (strcat "\n"
  47.                      (itoa cnt2)
  48.                      " 3dpoly converted, "
  49.                      (itoa (- (1+ cnt1) cnt2))
  50.                      " ignored."
  51.              )
  52.       )
  53.     )
  54.     (princ "\nNo 3dpoly found.")
  55.   )
  56.   (princ)
  57. )
  58.
HTH.
M.R.
« Last Edit: April 12, 2023, 02:57:55 PM by ribarm »
M.R. on Youtube
BIGAL
  • 40 + years of using Autocad
Have you looked into Triangulation lisp used in civil engineering to take points and make 3dface's for surface representations.
Do a google for Triangulation YMG.
mariolino0099
many thanks for the response,
unfortunately it doesn't work..... I get this error:
Command: POLYTOFACE
Select objects: Specify opposite corner: 346 found
Select objects: ; error: bad argument type: lentityp ((-1 . <Entity name: 1280f370470>) (0 . "POLYLINE") (330 . <Entity name: 128112b0080>) (5 . "E0F") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDb3dPolyline") (66 . 1) (10 0.0 0.0 0.0) (70 . 8) (40 . 0.0) (41 . 0.0) (210 0.0 0.0 1.0) (71 . 0) (72 . 0) (73 . 0) (74 . 0) (75 . 0))
ribarm
Command: POLYTOFACE
Try now...
IMHO it was cnt1 variable - should be starting -1 and (setq ent (entget (ssname ... should have been (setq ent (ssname ... and there should be "" after (command "_.3dface" "_non" p1 "_non" p2 "_non" p3 "_non" p4 "")
« Last Edit: April 12, 2023, 08:22:39 AM by ribarm »
M.R. on Youtube
mariolino0099
many thanks for the response....
thanks for new code.... with this modification
  1.
  2.   (setq cnt1 -1
  3.         cnt2 0
  4.   )
  1.             (progn
  3.                  "_non" (car pl)
  4.                  "_non" (cadr pl)
  7.                  ""
  8.               )
  9.
this error:
Command:  POLYTOFACE
Select objects:  ; error: bad argument type: lentityp ((-1 . <Entity name: 20d8a53ece0>) (0 . "POLYLINE") (330 . <Entity name: 20db1273080>) (5 . "E16") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDb3dPolyline") (66 . 1) (10 0.0 0.0 0.0) (70 . 8) (40 . 0.0) (41 . 0.0) (210 0.0 0.0 1.0) (71 . 0) (72 . 0) (73 . 0) (74 . 0) (75 . 0))
PS: in previous post attached DXF for test conversion
« Last Edit: April 12, 2023, 08:44:50 AM by mariolino0099 »
ribarm
@mariolino
This was an issue (setq ent (entget (ssname ss (setq cnt1 (1+ cnt1)))))
Should be : (setq ent (ssname ss (setq cnt1 (1+ cnt1))))
You have tested the code in the meantime I haven't changed that line...
M.R. on Youtube
mariolino0099
it works !!!!!
many thanks !!!!!  :smitten:
PS it's just a little slow....
ribarm
You could alternatively use (entmake) instead of command calls :
  2.
  4.     (setq v poly)
  7.     )
  8.     (reverse pl)
  9.   )
  10.
  11.   (setq cnt1 -1
  12.         cnt2 0
  13.   )
  15.     (progn
  21.             (progn
  22.               (entmake
  23.                 (list
  24.                   (cons 0 "3DFACE")
  25.                   (cons 10 (car pl))
  26.                   (cons 11 (cadr pl))
  27.                   (cons 12 (caddr pl))
  28.                   (cons 13 (cadddr pl))
  29.                 )
  30.               )
  32.             )
  33.           )
  34.           (if (= (length pl) 3)
  35.             (progn
  36.               (entmake
  37.                 (list
  38.                   (cons 0 "3DFACE")
  39.                   (cons 10 (car pl))
  40.                   (cons 11 (cadr pl))
  41.                   (cons 12 (caddr pl))
  42.                   (cons 13 (caddr pl))
  43.                 )
  44.               )
  45.               (setq cnt2 (1+ cnt2))
  46.             )
  47.           )
  48.         )
  49.       )
  50.       (princ (strcat "\n"
  51.                      (itoa cnt2)
  52.                      " 3dpoly converted, "
  53.                      (itoa (- (1+ cnt1) cnt2))
  54.                      " ignored."
  55.              )
  56.       )
  57.     )
  58.     (princ "\nNo 3dpoly found.")
  59.   )
  60.   (princ)
  61. )
  62.
HTH.
M.R.
« Last Edit: April 12, 2023, 02:57:36 PM by ribarm »
M.R. on Youtube
