Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Help: Export coordinates from block attribute
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Help: Export coordinates from block attribute (Read 617 times)
mhy3sx
Newt
on:
April 06, 2023, 03:19:07 AM »
Hi, I use this code to export coordinates from my attibute blocks. Is it possible to change the code to work only for one block with name STATION.dwg (ignore all the other blocks)?
Code - Auto/Visual Lisp:
[Select]
defun
c:PXYZD
*error*
del des ent idx lst obj ord out rtn sel
defun
*error*
msg
if
'file
type
des
close
des
if
not
wcmatch
strcase
msg t
"*break,*cancel*,*exit*"
princ
strcat
\n
Error: "
msg
princ
setq
ord '
"POINT"
POINT
X POINT
Y
"ELEV"
"DESC"
out
LM:uniquefilename
strcat
getvar
'dwgprefix
vl-filename-base
getvar
'dwgname
".crd"
del
if
setq
sel
ssget
0
"INSERT"
66
1
if
setq
des
open
out
"w"
progn
repeat
setq
idx
sslength
sel
setq
ent
ssname
sel
setq
idx
1-
idx
obj
vlax
ename
vla-object
ent
setq
lst
append
mapcar
lambda
a b
cons
a
rtos
b
point
x point
y point
z
trans
cdr
assoc
10
entget
ent
ent
0
mapcar
lambda
x
cons
strcase
vla-get-tagstring
x
vla-get-textstring
x
append
vlax-invoke
obj 'getattributes
vlax-invoke
obj 'getconstantattributes
;(setq rtn (cons (vl-remove 'nil (mapcar '(lambda ( x ) (cdr (assoc x lst))) ord)) rtn))
if
and
setq
pnt
assoc
"POINT"
lst
cdr
pnt
setq
rtn
cons
mapcar
lambda
x
v
if
and
setq
v
cdr
assoc
x lst
v
v
"0.00"
ord
rtn
foreach
idx
LM:alphanumsort
i
mapcar
car
rtn
write-line
LM:lst
str
nth
idx rtn
del
des
setq
des
close
des
princ
strcat
\n
Unable to open file:
out
for writing."
princ
;; List to String - Lee Mac
;; Concatenates each string in a list, separated by a given delimiter
defun
LM:lst
str
lst del
if
cdr
lst
strcat
car
lst
del
LM:lst
str
cdr
lst
del
car
lst
;; Unique Filename - Lee Mac
;; Returns a unique filename for a given path & file extension
defun
LM:uniquefilename
pth ext
fnm tmp
if
findfile
setq
fnm
strcat
pth ext
progn
setq
tmp
1
while
findfile
setq
fnm
strcat
pth
itoa
setq
tmp
1+
tmp
ext
fnm
;; Alphanumerical Sort-i - Lee Mac
;; Sorts a list of strings containing a combination of alphabetical & numerical characters and returns the indices.
defun
LM:alphanumsort
i
lst
vl-sort-i
mapcar
'LM:splitstring lst
function
lambda
a b
x y
while
and
setq
x
car
a
setq
y
car
b
x y
setq
a
cdr
a
b
cdr
b
cond
null
x
b
null
y
nil
and
numberp
x
numberp
y
x y
numberp
x
numberp
y
nil
x y
;; Split String - Lee Mac
;; Splits a string into a list of text and numbers
defun
LM:splitstring
str
lambda
l
read
strcat
vl
list
string
apply
append
mapcar
function
lambda
a b c
cond
or
34
b
92
b
list
32
34
92
b
34
32
or
47
b
58
;(and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
and
46
b
47
a
58
47
c
58
list
b
list
32
34
b
34
32
cons
nil
l
l
append
cdr
l
vl
string
list
str
vl-load-com
princ
Logged
kozmos
Newt
Re: Help: Export coordinates from block attribute
Reply #1 on:
April 06, 2023, 03:30:13 AM »
simply change
(setq sel (ssget '((0 . "INSERT") (66 . 1))))
into
(setq sel (ssget '((0 . "INSERT")(2 . "STATION") (66 . 1))))
Logged
KozMos Inc.
Seagull
London, England
WWW
Reply #2 on:
April 17, 2023, 07:18:37 PM »
Original source
You may also wish to include anonymous references in the selection (using the filter
"`*U*"
) and then check the ActiveX
effectivename
property within the
repeat
loop if your blocks are dynamic, otherwise they won't be selected if their dynamic parameters have been altered following insertion.
Logged
Lee Mac Programming
Twitter
Exchange App Store
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
