Author Topic: wblock in a previous version  (Read 984 times)
domenicomaria
« on: March 31, 2023, 04:03:10 AM »
Is it possible to create DWGs in a previous version with the wblock command?
For example I use the Acad 2022 version
and I want to create DWGs in the ACAD 2000 version
with WBLOCK ...
... is it possible?
ribarm
  • Marko Ribar, architect
Re: wblock in a previous version
« Reply #1 on: March 31, 2023, 04:15:22 AM »
I think it's not possible...
Instead 2 steps :
1. WBLOCK
2. OPEN -> SAVEAS -> A2000 format
M.R. on Youtube
domenicomaria
« Reply #2 on: March 31, 2023, 05:11:31 AM »
Marc'Antonio Alessi
  • Marco
« Reply #3 on: March 31, 2023, 05:21:21 AM »
For Acad >= 2007 look for vla-Put-SaveAsType
domenicomaria
« Reply #4 on: March 31, 2023, 06:37:25 AM »
@Marco
I don't want SAVEAS . . .
I want that WBLOCK creates a DWG in a previous version
I add
(setenv "DefaultFormatForSave" "12")
before WBLOCK
but the final DWG format, is the current version
and not ACAD2000 ("DefaultFormatForSave" = "12")
« Last Edit: March 31, 2023, 06:42:47 AM by domenicomaria »
domenicomaria
« Reply #5 on: March 31, 2023, 06:41:58 AM »
And before use WBLOCK, I added
(vla-put-saveastype (vla-get-opensave (vla-get-preferences (vlax-get-acad-object) ) ) ac2000_dwg )
instead of
but nothing is changed !
Marc'Antonio Alessi
  • Marco
« Reply #6 on: March 31, 2023, 10:45:17 AM »
Works... tested in AutoCAD 2013
domenicomaria
« Reply #7 on: March 31, 2023, 10:51:31 AM »
thank you Marco
I will give it a try
(again)
... monday !
ciao
domenicomaria
« Reply #8 on: April 03, 2023, 03:58:50 AM »
1
2
  1. (defun :VLA-WBLOCK (ss full-dwg-file-name / active-doc )
  2.    (:SS-MAKE-PREVIOUS- ss)
  3.    (and
  4.       ss
  5.       full-dwg-file-name
  6.       (setq active-doc (:ACTIVE-DOCUMENT) )
  7.       (not
  8.          (vl-catch-all-error-p
  9.               (vl-catch-all-apply 'vla-WBlock
  10.                (list active-doc full-dwg-file-name (vla-get-ActiveSelectionSet active-doc) )
  11.               )
  12.          )
  13.       )
  14.    )
  15. )
3
  1. LM:DWGVERSION
Marco, it seems that it does not work !
domenicomaria
« Reply #10 on: April 03, 2023, 06:55:02 AM »
Have you tried wblock command?
Yes.
With wblock command, it works !
Thank you.
Marc'Antonio Alessi
  • Marco
« Reply #11 on: April 03, 2023, 08:23:47 AM »
Yes.
Thank you.
Your question: Is it possible to create DWGs in a previous version with the wblock command?
domenicomaria
« Reply #12 on: April 03, 2023, 08:35:14 AM »
Yes!
"Is it possible to create DWGs in a previous version with the wblock command?"
this is the right way to express the concept!
