No! not a number at all.
See this explanation. <---<< correction from this expiation.
;; This one will exclude any object on the layers listed and any Solid Hatches
(setq ss
(ssget ; Get a selection set
"x" ; Entire database. If you specify the X selection method and do not provide a filter-list,
;; ssget selects all entities in the database, including entities on layers that are off,
;; frozen, and out of the visible screen.
;; ssget Filter follows
'((-4 . "<NOT") ; start of NOT, the following are exculded from the selection set
(-4 . "<OR") ; Start of OR, any match of any of the following will be excluded
(2 . "SOLID") ; any "SOLID" Hatch patterns will be excluded
(8 . "-pouche,-pouche253,-hat,defpoints") ; anything on these layers are excluded
(-4 . "OR>")
(-4 . "NOT>")
;; Here is one the excludes only Solid pattern Hatchs on the layers listed.
(setq ss
(-4 . "<AND") ; Start of AND, to match objects must meet all of the following to be excluded
(2 . "SOLID")
(0 . "HATCH")
(-4 . "AND>")
(-4 . "NOT>")
