Sphere as 3DSOLID entity has center point (vla-get-center VLA-OBJECT)... But if you need to create SPHERE, you haven't answered to my question - 3 points in WCS give circle - do you want sphere from that circle, or 4 points not coplanar whereas each triangle has normal xline through center of circumscribed triangle and at intersections of those XLINEs, you obtain center point... Radius is pretty easy : R=(distance cenpt pttriang)
