Author Topic: Error in 'CreateFloatingViewport' help sample  (Read 1506 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« on: March 09, 2023, 04:03:41 PM »
in https://help.autodesk.com/view/OARX/2023/ENU/?guid=GUID-61C22902-F63B-4204-86EC-FA37312D1B6E
Create Paper Space Viewports (.NET)
The Dll Import should be from "accore.dll" NOT from "acad.exe"
and the entry point is incorrect.
The following options work for me in ac2023
Code - C#: [Select]
  1.      //---------------------------------------------------------------------------
  2.       [DllImport("accore.dll", CallingConvention = CallingConvention.Cdecl,
  3.          EntryPoint = "?acedSetCurrentVPort@@YA?AW4ErrorStatus@Acad@@PEBVAcDbViewport@@@Z")]
  4.       extern static private int acedSetCurrentVPort(IntPtr AcDbVport);
  5.       //---------------------------------------------------------------------------
  6.       [DllImport("accore.dll", CallingConvention = CallingConvention.Cdecl,
  7.          EntryPoint = "?acedSetCurrentVPort@@YA?AW4ErrorStatus@Acad@@H@Z")]
  8.       private static extern int acedSetCurrentVPort(int acDbVportNumber);
  9.       //---------------------------------------------------------------------------
  10.
  11.
I imagine there are a few others that have been incorrect for about 9 years or so.
The current Dumpbin output is here:
https://www.theswamp.org/index.php?topic=41527.msg613345#msg613345  if anyone is interested.
live long and prosper.
Called Kerry in my other life
I live at UTC + 13.00
kdub_nz
  • SuperMod
Re: Error in 'CreateFloatingViewport' help sample
« Reply #1 on: March 09, 2023, 07:08:20 PM »
Alternate solution from Gilles
and revised code for multiple Viewport creation ( to avoid Acad crash )
https://forums.autodesk.com/t5/net/error-in-createfloatingviewport-help-sample/m-p/11811120/thread-id/76182#M76185
