Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Help me to fix a code : Connect attribiute points with line by point number
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: Help me to fix a code : Connect attribiute points with line by point number (Read 1876 times)
mhy3sx
Newt
Re: Help me to fix a code : Connect attribiute points with line by point number
Reply #15 on:
March 10, 2023, 05:30:40 AM »
Hi, is it possible to zoom every time to the given point area . I want to say not to zoom in to the given block point number but to a close area of the point.
Logged
mhy3sx
Newt
Reply #16 on:
March 11, 2023, 10:55:49 AM »
Hi I try to add
Code:
[Select]
(vl-cmdf "mspace" "zoom" 20 pv)
To zoom near the select attribute number so ,I can see the next points. For the first point works but for the next points don't working. Any ideas?
Code - Auto/Visual Lisp:
[Select]
defun
c:lineat2
data AllPointnumber stop pts data i p pv pts_
vl-load-com
setq
ped
getvar
'peditaccept
setvar
'peditaccept
1
if
setq
AllPointnumber
nil
stop
nil
pts
nil
data
ssget
"_X"
list
0
"INSERT"
66
1
2
"Point,KORYFES,station,trigonom,KOKAEK,KOROT,Ktir"
cons
410
getvar
'Ctab
progn
repeat
setq
i
sslength
data
if
setq
p
vl-some
lambda
x
if
eq
vla-get-tagstring
x
"POINT"
list
vla-get-textstring
x
vlax-get
e 'Insertionpoint
vlax-invoke
setq
e
vlax
ename
vla-object
ssname
data
setq
i
1-
i
'GetAttributes
setq
AllPointnumber
cons
p AllPointnumber
setq
allpointnumber
vl
remove
if
function
lambda
x
eq
car
x
allpointnumber
setq
2bjoin
ssadd
while
null
Stop
setq
pv
getstring
\n
Give point number <Space to continue or Enter to finish and convert to polyline> :"
vl-cmdf
"mspace"
"zoom"
20
pv
; <--- I add it here
cond
setq
a
assoc
strcase
pv
AllPointnumber
setq
pts
cons
cadr
a
pts
pts_
cons
cadr
a
pts_
if
length
pts
2
progn
entmakex
list
cons
0
"LINE"
cons
10
car
pts
cons
11
cadr
pts
setq
pts
list
car
pts
ssadd
entlast
2bjoin
eq
pv
setq
stop
"Done"
eq
strcase
pv
"U"
entdel
setq
del
ssname
2bjoin
1-
sslength
2bjoin
ssdel
del 2bjoin
setq
pts_
cdr
pts_
pts
list
car
pts_
null
a
princ
\n
<<Point value not found>>"
initget
"Yes No"
setq
convert
cond
getkword
\n
Convert to polylines? [Yes/No] <N>: "
"No"
if
eq
"Yes"
convert
command
"_.pedit"
"_M"
2bjoin
"_J"
setvar
'peditaccept ped
princ
Logged
mhy3sx
Newt
Reply #17 on:
March 12, 2023, 03:42:48 AM »
Is It possible?
Logged
mhy3sx
Newt
Reply #18 on:
March 12, 2023, 12:38:56 PM »
I find this code. This code Find block by attribute value. Unfortunately, didn't work for multiple blocks. Find one attribute tag and stop. Can anyone fix it to work for multiple block tags and join it with lineat2 lisp code? The idea is when I use leanatt2 lisp code and give eatch attribute tag number to join with line , to zoom center to each block (by given number), so I can see the block numbers nearby .
[Select]
defun
c:fatt
ov ss i en ed an ad
while
not
ov
setq
ov
getstring
t
\n
ATTRIB Value To Search For: "
and
setq
ss
ssget
"X"
list
cons
0
"INSERT"
cons
66
1
if
getvar
"CTAB"
cons
410
getvar
"CTAB"
cons
67
1
getvar
"TILEMODE"
setq
i
sslength
ss
while
not
minusp
setq
i
1-
i
setq
en
ssname
ss i
ed
entget
en
an
entnext
en
ad
entget
an
while
"seqend"
cdr
assoc
0
ad
if
strcase
ov
strcase
cdr
assoc
1
ad
progn
command
"_.zoom"
"_c"
cdr
assoc
10
ed
getstring
\n
Press Enter To Continue Searching..."
setq
an
entnext
an
ad
entget
an
prin1
[Select]
defun
c:lineat2
vl-load-com
setq
ped
getvar
'peditaccept
setvar
'peditaccept
1
if
setq
AllPointnumber
nil
stop
nil
pts
nil
data
ssget
"_X"
list
0
"INSERT"
66
1
2
cons
410
getvar
'Ctab
progn
repeat
setq
i
sslength
data
if
setq
p
vl-some
lambda
x
if
eq
vla-get-tagstring
x
"POINT"
list
vla-get-textstring
x
vlax-get
e 'Insertionpoint
vlax-invoke
setq
e
vlax
ename
vla-object
ssname
data
setq
i
1-
i
'GetAttributes
setq
AllPointnumber
cons
p AllPointnumber
setq
allpointnumber
vl
remove
if
function
lambda
x
eq
car
x
allpointnumber
setq
2bjoin
ssadd
while
null
Stop
setq
pv
getstring
\n
cond
setq
a
assoc
strcase
pv
AllPointnumber
setq
pts
cons
cadr
a
pts
pts_
cons
cadr
a
pts_
if
length
pts
2
progn
entmakex
list
cons
0
"LINE"
cons
10
car
pts
cons
11
cadr
pts
setq
pts
list
car
pts
ssadd
entlast
2bjoin
eq
pv
setq
stop
"Done"
eq
strcase
pv
"U"
entdel
setq
del
ssname
2bjoin
1-
sslength
2bjoin
ssdel
del 2bjoin
setq
pts_
cdr
pts_
pts
list
car
pts_
null
a
princ
\n
initget
"Yes No"
setq
convert
cond
getkword
\n
"No"
if
eq
"Yes"
convert
command
"_.pedit"
"_M"
2bjoin
"_J"
setvar
'peditaccept ped
princ
Logged
kasmo
Newt
Reply #19 on:
March 12, 2023, 01:10:27 PM »
[Select]
defun
c:lineat2
vl-load-com
setq
ped
getvar
'peditaccept
setvar
'peditaccept
1
if
setq
AllPointnumber
nil
stop
nil
pts
nil
data
ssget
"_X"
list
0
"INSERT"
66
1
2
cons
410
getvar
'Ctab
progn
repeat
setq
i
sslength
data
if
setq
p
vl-some
lambda
x
if
eq
vla-get-tagstring
x
"POINT"
list
vla-get-textstring
x
vlax-get
e 'Insertionpoint
vlax-invoke
setq
e
vlax
ename
vla-object
ssname
data
setq
i
1-
i
'GetAttributes
setq
AllPointnumber
cons
p AllPointnumber
setq
allpointnumber
vl
remove
if
function
lambda
x
eq
car
x
allpointnumber
setq
2bjoin
ssadd
while
null
Stop
setq
pv
getstring
\n
cond
setq
a
assoc
strcase
pv
AllPointnumber
setq
pts
cons
cadr
a
pts
pts_
cons
cadr
a
pts_
command
"_zoom"
"_c"
car
pts
20
if
length
pts
2
progn
entmakex
list
cons
0
"LINE"
cons
10
car
pts
cons
11
cadr
pts
setq
pts
list
car
pts
ssadd
entlast
2bjoin
eq
pv
setq
stop
"Done"
eq
strcase
pv
"U"
entdel
setq
del
ssname
2bjoin
1-
sslength
2bjoin
ssdel
del 2bjoin
setq
pts_
cdr
pts_
pts
list
car
pts_
null
a
princ
\n
initget
"Yes No"
setq
convert
cond
getkword
\n
"No"
if
eq
"Yes"
convert
command
"_.pedit"
"_M"
2bjoin
"_J"
setvar
'peditaccept ped
princ
Logged
mhy3sx
Newt
Reply #20 on:
March 12, 2023, 02:15:19 PM »
Thank you
kasmo
Logged
Print
Pages:
1
2
All
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
