Author Topic: Getting 'System.AccessViolationException' occurred in Acdbmgd.dll using Overrule  (Read 113 times)
sh3rlck
  • Mosquito
 I am getting the Exception above when running an overrule to display raster images in a per viewport basis. I am using Kean example: https://www.keanw.com/2015/10/displaying-different-entities-in-autocad-viewports-using-net.html to simulate the same behavior but for raster images. Here is my viewport draw where the issue is happening.
        public override void ViewportDraw(Drawable drawable, ViewportDraw vd)
            try
                if (!IsVisible(vd.Viewport.AcadWindowId))
                    return;
                var pd = new PassthroughDraw(vd);
                if (!base.WorldDraw(drawable, pd))
                    try
                        base.ViewportDraw(drawable, vd);
                    } catch(Exception ex)
                        Console.WriteLine(ex);
            } catch
                // ignored
here is the passthroughDraw class
            public class PassthroughDraw : WorldDraw
        private readonly PassthroughGeometry _pg;
        private readonly ViewportDraw _vd;
        /// <summary>
        /// Constructor
        /// </summary>
        /// <param name="vd"></param>
        public PassthroughDraw(ViewportDraw vd)
            _vd = vd;
            _pg = new PassthroughGeometry(vd.Geometry);
        /// <summary>
        /// WorldDraw protocol
        /// </summary>
        public override WorldGeometry Geometry => _pg;
        /// <summary>
        /// CommonDraw protocol
        /// </summary>
        public override Context Context => _vd.Context;
        public override bool IsDragging => _vd.IsDragging;
        public override int NumberOfIsolines => _vd.NumberOfIsolines;
        public override Geometry RawGeometry => _vd.RawGeometry;
        public override bool RegenAbort => _vd.RegenAbort;
        public override RegenType RegenType => _vd.RegenType;
        public override SubEntityTraits SubEntityTraits => _vd.SubEntityTraits;
        public override double Deviation(DeviationType deviationType, Point3d pointOnCurve)
            return _vd.Deviation(deviationType, pointOnCurve);
Here is the PassthroughGeometry class
private readonly ViewportGeometry _vg;
        /// <summary>
        /// ctor
        /// </summary>
        /// <param name="vg"></param>
        public PassthroughGeometry(ViewportGeometry vg)
            _vg = vg;
        public override void SetExtents(Extents3d extents) { }
        public override void StartAttributesSegment() { }
        /// <summary>
        /// Geometry protocol
        /// </summary>
        public override Matrix3d ModelToWorldTransform => _vg.ModelToWorldTransform;
        public override Matrix3d WorldToModelTransform => _vg.WorldToModelTransform;
        public override bool Circle(Point3d center, double radius, Vector3d normal) => _vg.Circle(center, radius, normal);
        public override bool Circle(Point3d firstPoint, Point3d secondPoint, Point3d thirdPoint) => _vg.Circle(firstPoint, secondPoint, thirdPoint);
        public override bool CircularArc(Point3d start, Point3d point, Point3d endingPoint, ArcType arcType) => _vg.CircularArc(start, point, endingPoint, arcType);
        public override bool CircularArc(Point3d center, double radius, Vector3d normal, Vector3d startVector, double sweepAngle, ArcType arcType) => _vg.CircularArc(center, radius, normal, startVector, sweepAngle, arcType);
        public override bool Draw(Drawable value) => _vg.Draw(value);
        public override bool Edge(Curve2dCollection e) => _vg.Edge(e);
        public override bool EllipticalArc(Point3d center, Vector3d normal, double majorAxisLength, double minorAxisLength, double startDegreeInRads, double endDegreeInRads, double tiltDegreeInRads, ArcType arcType) => _vg.EllipticalArc(center, normal, majorAxisLength, minorAxisLength, startDegreeInRads, endDegreeInRads, tiltDegreeInRads, arcType);
        public override bool Image(ImageBGRA32 imageSource, Point3d position, Vector3d u, Vector3d v) => _vg.Image(imageSource, position, u, v);
        public override bool Image(ImageBGRA32 imageSource, Point3d position, Vector3d u, Vector3d v, TransparencyMode transparencyMode) => _vg.Image(imageSource, position, u, v, transparencyMode);
        public override bool Mesh(int rows, int columns, Point3dCollection points, EdgeData edgeData, FaceData faceData, VertexData vertexData, bool bAutoGenerateNormals) => _vg.Mesh(rows, columns, points, edgeData, faceData, vertexData, bAutoGenerateNormals);
        public override bool OwnerDraw(GdiDrawObject gdiDrawObject, Point3d position, Vector3d u, Vector3d v) => _vg.OwnerDraw(gdiDrawObject, position, u, v);
        public override bool Polygon(Point3dCollection points) => _vg.Polygon(points);
        public override bool Polyline(AcGi.Polyline polylineObj) => _vg.Polyline(polylineObj);
        public override bool Polyline(AcDb.Polyline value, int fromIndex, int segments) => _vg.Polyline(value, fromIndex, segments);
        public override bool Polyline(Point3dCollection points, Vector3d normal, IntPtr subEntityMarker) => _vg.Polyline(points, normal, subEntityMarker);
        public override bool Polypoint(Point3dCollection points, Vector3dCollection normals, IntPtrCollection subentityMarkers) => _vg.Polypoint(points, normals, subentityMarkers);
        public override bool PolyPolygon(UInt32Collection numPolygonPositions, Point3dCollection polygonPositions, UInt32Collection numPolygonPoints, Point3dCollection polygonPoints, EntityColorCollection outlineColors, LinetypeCollection outlineTypes, EntityColorCollection fillColors, TransparencyCollection fillOpacities) => _vg.PolyPolygon(numPolygonPoints, polygonPoints, numPolygonPoints, polygonPoints, outlineColors, outlineTypes, fillColors, fillOpacities);
        public override bool PolyPolyline(PolylineCollection polylineCollection) => _vg.PolyPolyline(polylineCollection);
        public override void PopClipBoundary() => _vg.PopClipBoundary();
        public override bool PopModelTransform() => _vg.PopModelTransform();
        public override bool PushClipBoundary(ClipBoundary boundary) => _vg.PushClipBoundary(boundary);
        public override bool PushModelTransform(Matrix3d matrix) => _vg.PushModelTransform(matrix);
        public override bool PushModelTransform(Vector3d normal) => _vg.PushModelTransform(normal);
        public override Matrix3d PushOrientationTransform(OrientationBehavior behavior) => _vg.PushOrientationTransform(behavior);
        public override Matrix3d PushPositionTransform(PositionBehavior behavior, Point2d offset) => _vg.PushPositionTransform(behavior, offset);
        public override Matrix3d PushPositionTransform(PositionBehavior behavior, Point3d offset) => _vg.PushPositionTransform(behavior, offset);
        public override Matrix3d PushScaleTransform(ScaleBehavior behavior, Point2d extents) => _vg.PushScaleTransform(behavior, extents);
        public override Matrix3d PushScaleTransform(ScaleBehavior behavior, Point3d extents) => _vg.PushScaleTransform(behavior, extents);
        public override bool Ray(Point3d point1, Point3d point2) => _vg.Ray(point1, point2);
        public override bool RowOfDots(int count, Point3d start, Vector3d step) => _vg.RowOfDots(count, start, step);
        public override bool Shell(Point3dCollection points, IntegerCollection faces, EdgeData edgeData, FaceData faceData, VertexData vertexData, bool bAutoGenerateNormals)
            // To avoid a null argument exception, faces need to be transfered across to a new collection
            var faces2 = new IntegerCollection(faces.Count);
            foreach (int face in faces)
                faces2.Add(face);
            return _vg.Shell(points, faces2, edgeData, faceData, vertexData, bAutoGenerateNormals);
        public override bool Text(Point3d position, Vector3d normal, Vector3d direction, string message, bool raw, TextStyle textStyle) => _vg.Text(position, normal, direction, message, raw, textStyle);
        public override bool Text(Point3d position, Vector3d normal, Vector3d direction, double height, double width, double oblique, string message) => _vg.Text(position, normal, direction, height, width, oblique, message);
        public override bool WorldLine(Point3d startPoint, Point3d endPoint) => _vg.WorldLine(startPoint, endPoint);
        public override bool Xline(Point3d point1, Point3d point2) => _vg.Xline(point1, point2);
Here is how I am adding the overrule:
        public void Add()
            AddOverrule(GetClass(typeof(RasterImage)), this, false);
            Overruling = true;
        public void Remove()
            RemoveOverrule(GetClass(typeof(RasterImage)), this);
            Dispose();
Any ideas on why this my be happening?
UPDATE: GOT IT TO WORK BUT IT IS NOT WORKING FOR DIFFERENT VISUAL STYLES, ONLY FOR 2D WIREFRAME, ANY IDEAS?
« Last Edit: March 05, 2023, 02:18:22 AM by sh3rlck »
