Author Topic: UCS move with object. Thinking out loud.  (Read 687 times)
jlogan02
« on: February 23, 2023, 06:53:12 PM »
Let's say you have a saved named view after creating a new UCS at a the corner of a piece of sheet metal. Could you create a routine (I think it just popped into my head) where the UCS would, for lack of a better term, stick to the corner of the sheet metal as you moved the two lines that make up that corner of the sheet metal.
My thought is...
A move command that asks the user to select all objects to move
After the move is completed the user is prompted to pick the new location for the UCS...
  1.    (if
  2.         (and
  3.             (setq ent (car (entsel "\nSelect Line: ")))
  4.             (= "LINE" (cdr (assoc 0 (setq enx (entget ent)))))
  5.         )
  6.         (command
  7.             "_.ucs"
  8.             "_non"
  9.             (trans (cdr (assoc 10 enx)) 0 1)
  10.             "_non"
  11.             (trans (cdr (assoc 11 enx)) 0 1)
  12.             "\\" ;; Pause for user input
  13.         ) ;; end COMMAND
  14.     ) ;; end IF
A new named view is saved.
Old named view is deleted.
This is more manual than my question about a sticky UCS I think it's doable.
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
danAllen
Re: UCS move with object. Thinking out loud.
« Reply #1 on: February 23, 2023, 07:48:50 PM »
why not use command UCS > entity ?
BIGAL
  • 40 + years of using Autocad
« Reply #2 on: February 24, 2023, 09:40:54 PM »
Same answer UCS OB
