Author Topic: Run multi LISP with Check boxes in DCL  (Read 904 times)
PPETROS
« on: February 21, 2023, 05:10:57 AM »
Good morning everyone,
I am trying to create a lisp with a dialogue window (DCL), which would be capable of running different lisp commands and remembering/storing the last made command.
For this reason, I used as an example a part of the lisp's StripMtext v3 code and tried to adjust it in mine.
However, I did not manage to make it work, and I need your help.
Can someone help me to make the following lisp work correctly?
The truth is I really needed it.
I thank you in advance for your help and time.
(defun c:RLSP( /
  ;; functions
  *error*
  acceptbutton
  clearallbutton
  maindialog
  selectallbutton
  setup
  ;;stripmtext <- global sub function, see end of file
  ;;unformat   <- global sub function, see end of file
dclfile
dcl#
action
lsprun
  ;; variables:
  dcl_id
  dclfilemsg
  dclfilename
  dialogmsg
  docobj
  keylist
  modcnt
  off
  on
  save
  settings
  ss
  stripmtextkey
  tilemsg
  versionmsg
  ;;; Local functions
  (defun *error* (msg)
    (vla-endundomark
      (vlax-get-property
        (vlax-get-acad-object)
        "ActiveDocument"
      ((member msg
         '("Function cancelled"
           "quit / exit abort"
           "console break"
      ((princ (strcat " Error: " msg)))
  (defun SelectAllButton ()
    (foreach key keylist (set_tile key on))
    (set_tile "error" "")
    (mode_tile "accept" 2)
  (defun ClearAllButton ()
    (foreach key keylist (set_tile key off))
    (set_tile "error" tilemsg)
  (defun AcceptButton ()
    ;Build string to be passed later to the unformat function
    ;Strcat key character for each checkmarked key
    (setq settings "")
      (if (= (get_tile key) on)
        (setq settings (strcat settings key))
    ;If no keys are checkmarked, show error message
    ;Else if save is enabled, save settings to registry
    (if (= settings "")
        (if (= (get_tile "save") on)
            (vl-registry-write StripMtextKey "Settings" settings)
            (vl-registry-write StripMtextKey "Save" on)
          (vl-registry-write StripMtextKey "Save" off)
        (if (= (strlen settings) (length keylist))
          (setq settings "*")
      );progn
  (defun MainDialog ( / status done)
    ;Display checkbox default values and define checkbox callbacks
    (set_tile "save" save)
      (if (vl-string-search key settings)(set_tile key on))
      (action_tile key "(set_tile \"error\" \"\" )" )
    ;Define button callbacks
    (action_tile "clearall" "(ClearAllButton)")
    (action_tile "selectall" "(SelectAllButton)")
    (action_tile "accept" "(AcceptButton)(done_dialog 1)")
    (action_tile "cancel" "(done_dialog 0)")
    (setq status (start_dialog))
    (unload_dialog dcl_id)
    ;Return key used to close dialog
    ;If status = 0 , then Cancel button hit
    ;If status = 1 , then Accept button hit
    status
  (defun Setup ()
    (setq
      ;--- Set Constants ---
      ;Toggles for dcl checkbox status
      on  "1"
      off "0"
      ;Error messages
      tilemsg     "Select one or more settings or press \"Cancel\" to exit"
      versionmsg  "StripMtext error:\nRequires AutoCAD 2000 or higher"
      dialogmsg   "StripMtext error:\nUnable to load dialog"
      dclfilemsg  "StripMtext error:\nCannot load DCL file \"StripMtext[3].dcl\""
      ;DCL file
      dclfilename "runlisp.DCL"
      ;List of dcl checkbox key names
      ;Must correspond with DCL keys and Unformat function
      keylist '("ck1" "ck2" "ck3" "ck4")
      ;Registry path for storing user's settings
      StripMtextkey "HKEY_CURRENT_USER\\SOFTWARE\\StripMtext\\"
      ;--- Set Defaults ---
      ;Get user's default settings from registry if exist
      ;If user has not saved default settings, use coded default
      settings (cond
                 ((vl-registry-read StripMtextKey "Settings"))
                 ((vl-registry-write StripMtextKey  "Settings" "CFH"))
      save    (cond
                 ((vl-registry-read StripMtextKey "Save"))
                 ((vl-registry-write StripMtextKey "Save" "1"))
    );setq
  (Setup)
    ;Find dcl file
    ((< (setq dcl_id (load_dialog dclfilename)) 0)
    ; (alert dclfilemsg)
    ;Successful dcl load
    ((not (new_dialog "runlisp" dcl_id))
      (alert dialogmsg)
    ;If user exits dcl using Accept button, process pickset
   ((= (MainDialog) 1)
      ;Process
      ; (setq modcnt (StripMtext ss settings))
       ;Display count of stripped objects
  );cond
);program
  (defun get_checks(/ result)
    (if (= (get_tile "ck1") "1")
      (setq result (cons "Unlock all layers" result))
    (if (= (get_tile "ck2") "1")
      (setq result (cons "Layer to Layer 0-OLD" result))
    (if (= (get_tile "ck3") "1")
      (setq result (cons "CBL_ColorByLayer" result))
    (if (= (get_tile "ck4") "1")
      (setq result (cons "Layer color 9" result))
  result
  ;;                    Start of Routine
 (setq dclfile "runlisp.dcl")
    ((< (setq dcl# (load_dialog dclfile)) 0) (prompt (strcat "\nCannot load " dclfile ".")))
    ((not (new_dialog "runlisp" dcl#)) (prompt (strcat "\nProblem with " dclfile ".")))
    (t ; No DCL problems:
      ;;  set actions
      (action_tile "accept" ; DCL OK exit action
                   "(setq lsprun (get_checks)) (done_dialog 1)")
       (setq action (start_dialog))
       (unload_dialog dcl#)
       (if (= action 1) ; OK was pressed
           (print "OK was pressed")
           ;;  do you scripr files here
           ;; lsprun = a list of checked items
           (if (member "Unlock all layers" lsprun)
             (C:LUA)
           (if (member "Layer to Layer 0-OLD" lsprun)
             (C:0T0)
           (if (member "CBL_ColorByLayer" lsprun)
             (C:CBL)
           (if (member "Layer color 9" lsprun)
             (C:LA9)
         (print "User Quit.")
  ) ; end cond
;(prompt "\nALL OK.")
BIGAL
  • 40 + years of using Autocad
Re: Run multi LISP with Check boxes in DCL
« Reply #1 on: February 21, 2023, 05:58:08 PM »
Just a stab in the dark toggles are 0 or 1,  on or off ?
PPETROS
« Reply #2 on: February 22, 2023, 04:39:37 AM »
Good Morning my Friend,
Thank you very much for your notice! I will try to fix it.
If you have marked in which paragraph of the code the error exists, can you please send me an example in order to fix it?
I am grateful for your effort and time spent.
