Hello everyone,
I am looking for help updating this lisp.
I need it to create a layer by picking an item(s) on that layer, using the same name of that existing layer but adding ABC~-CHGD and a number starting with 1 and advancing by 1 at the end of it, then asking do I want to use the same layer color or select a new layer color. when I have picked all the items that I need to change, it places them on that new layer. If I use the command again it knows to go to the next unused number if I have picked that original layer again.
The way the code is written now, it creates a new layer for every item that is picked.
(defun c:LAYCHA (/ i l n s x c y r d e)
(and (setq s (ssget "_:L" '((8 . "~*ABC~-CHGD0"))))
(setq r
(getstring
"\nSpeficy a number from 01-10 <enter to exit> :"
;;;;"\nSpeficy a number from [1-9] or [01-09] <enter to exit> :"
(or (numberp (read r))
(progn (princ "\nInvalid input!. Please try again.") nil)
(setq y (and (= (strlen r) 2) (wcmatch r "0*"))
c (acad_colordlg 256)
(repeat (setq i (sslength s))
(setq x (ssname s (setq i (1- i)))
e (entget x)
l (assoc 8 e)
n (strcat (cdr l) "_ABC~-CHGD" r)
d (list '(290 . 1) (cons 62 c))
r (1+ (atoi r))
r (if (and y (< r 10))
(strcat "0" (itoa r))
(itoa r)
(if (tblsearch "LAYER" n)
(entmod (append (entget (tblobjname "LAYER" n)) d))
(entmake (append (list '(0 . "LAYER")
'(100 . "AcDbSymbolTableRecord")
'(100 . "AcDbLayerTableRecord")
(cons 2 n)
'(70 . 0)
d
(entmod (subst (cons 8 n) l e))
Thanks,
